| brusk |
Jun 29, 2007 08:08 PM |
BBK caliper clearing problem using oem 17's
Ok I'm having a problem hopefully somebody has a solution to. I have newer maxima oem 17's the flat 7 spoke ones. BBK using 13" rotors and J30 calipers. The wheel weights hit the caliper just a little bit so I grinded them down and everything was great except the wheels were out of balance about 90 MPH. So I took them in today to get balanced and asked if they could move the wheel weights in toward the center of the wheel to clear the caliper which they did. Now the car shakes bad at 60+. I rotated wheels hoping it was only one nope still has problem. My mechanic friend says putting them in the center of the wheel is not advised. What are my options here I have to drive from Maryland to Vermont tomorrow and need this fixed in the morning. One thought was to have them put the weights back where they were and use the grinder to gring them down again and rebalance them again, or take the wheel weights and grind them in half first i dunno it's late and need help. Thanks
