Rotor Compatibility?
Hey this might be a long-shot, but a local shop is clearing a set of Brembo XD/Slotted Rotors for an 05-08 Tacoma.
I am wondering where I can look-up the dimensions for these to compare them to the 13" Cobra Rotors for a BBK?
I think that the Bolt pattern is 5x114.3 if that helps any.
Here's the Link:
http://www.nlclassifieds.com/classif...essories/66058
Here's the Link:
Location: Long Beach, CA is where i live. Queens NYC is always home.
even tho the rotor had the same bolt pattern, the offset of the rotor can make your brake swap sour. Example: 13" Cobra rotor and 6th gen rotors. Cobra rotor has the same bolt pattern as a Nissan, but the holes are larger and the offset makes the rotor move outward. 6th gen rotors are more inboard.
I tried to mount a Z32 caliper w/ Jeff brackets on my 3rd. gen and it didnt clear the rims. ( Had to use Infiniti J30 calipers) I have a friend who also has a 6th gen. We mounted my rims on his car and there was no clearance issues. We even mocked up the Z32 caliper and it cleared also. A look at the cobra rotor showed that it had a different offset compared to a Nissan Rotor.
04-16-2020 05:15 AM
