Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Ways to battle CV axles failures
Old 09-25-2011, 06:26 AM
nishfish871's Avatar
Just trying to get a list together on ways we can lower the wear on cv axles when lowering the car. I've seen on B15u they have a load of options, but still no adjustable control arm. What needs to be changed so we can help re-align the cv axles.
nishfish871 is offline
Old 09-25-2011, 12:07 PM
J2FRESH's Avatar
Location: Long Beach, CA/Las Vegas, NV/Oklahoma City, OK
J2FRESH is offline
Old 09-25-2011, 12:49 PM
Straitup D
are there aftermarket parts that can be adjusted to properly aline the axel?
Old 09-25-2011, 08:23 PM
STFU n00b!
Matt93SE's Avatar
By the time you lower the car enough you have CV joint problems, you have lowered it enough you have pretty much zero suspension travel.
step 1 is to raise the car up enough so it rides and handles decent.
the other option is custom control arms and better coilovers, which nobody makes.
Matt93SE is offline
Old 09-25-2011, 08:26 PM
MoncefA33's Avatar
Raise the car up.
Wait, fck dat.
I've seen one guy on here have some kind of spacers for the motor mounts to raise the engine/trans up. This helps level out the axles a little bit.
MoncefA33 is offline
Old 09-25-2011, 08:46 PM
mista0406's Avatar
in to see what comes of this discussion
mista0406 is offline
Old 09-26-2011, 07:53 AM
Raise the car up.
Wait, fck dat.
I'm sure there's room to move the motor mounts up an inch or so. The limitations would be the trans mount and the hood. Could put some washers on the back of the hood to raise it just a little. Now to fabricating some mount raisers...I wonder if anyone on here is good with CAD and can do it.
Old 09-26-2011, 10:41 AM
Prophecy99's Avatar
working with CAD as I type this...
Prophecy99 is offline
Old 09-26-2011, 06:31 PM
MOHFpro90's Avatar
Are we referring to mount raisers for the trans mount? Or all mounts? Ive got a few spare DEK mounts in the gay-rage I could screw with, and get some drawings made up in Solidworks. It might be a week or so, Ill be at Petit Lemans this week/weekend.
MOHFpro90 is offline
Old 09-26-2011, 09:59 PM
Maxima.org Insomniac
98SEBlackMax's Avatar
You would need to raise the engine and trans up to correct the angle of the axles in relation to the wheel hubs. But you would only raise the center of gravity while still having a very low roll center = even worse handling!
So you would need custom lower control arms to correct the roll center and properly designed coilovers that have much longer suspension travel.
For my car the engine/trans spacers were used to lower the front center of gravity for better handling at the possible expense of axle life. I only have about 0.75" of suspension drop so I would rather improve handling instead of going low. Alot of people have 1.25" ~ 1.5" drops for years so my setup should be ok long term.
98SEBlackMax is offline
Old 09-27-2011, 06:04 AM
phatboislim's Avatar
screw raising it up
phatboislim is offline
Old 09-27-2011, 06:47 AM
Straitup D
what about changing the camber up front?
Old 09-27-2011, 06:50 AM
nope
Old 09-28-2011, 10:31 AM
Shift_Max's Avatar
98SeBlackMax, any more pictures available?
Shift_Max is offline
Old 09-28-2011, 01:05 PM
95naSTA's Avatar
Adding negative camber will help the outer CVs.
You could just raise the rear mount but then d/s and p/s mounting gets a little tricky as does the Y and exhaust routing.
95naSTA is offline
Old 09-29-2011, 08:08 AM
Not as of right now.
The spacers and washers are about 0.5" thick, they sit in between the center crossmember and in between the transmisson mount/trans. The center cross member bolts are long enough to re-use but they had to get four longer bolts for the transmission mount.
The passenger side engine mount sits 0.5" lower, 2JR drilled the engine mount hole lower than stock.
Meximax did this on his setup to fit the 350Z intake manifold under the hood so it isn't nothing new. 2JR did this on their car as well, I think they went over 1" lower.
Old 09-29-2011, 12:05 PM
wirelessdude04's Avatar
im going through axles every three months thank god for a lifetime warranty. Might actually raise the car up a bit.
wirelessdude04 is offline
Old 09-29-2011, 12:08 PM
^can lie i'm thinking the same thing, but i dotn daily drive mine anymore
Old 09-29-2011, 02:52 PM
SC Overspinning Swapper!!
meximax's Avatar
I went through plenty of axles when I had the 5sp until I got the aftermarket axles (I forget the name of the vendor, Raxles???). I never broke those axles. I then did the 6sp swap, and never went through those either.
Dropping the engine further increases axle triangulation. I dropped by engine about 3/4", but never had a problem with after the 6sp swap, and I wash pushing a healthy amount of power.
meximax is offline
Old 09-30-2011, 03:52 PM
My axles cry for mercy...
essential1's Avatar
Originally Posted by 98SEBlackMax
Damn, who's car is that?! That guy is slammed!
essential1 is offline
Old 10-01-2011, 04:41 AM
Old 10-02-2011, 03:20 PM
Donating i30 Owner
HomerMAC's Avatar
GET RAXLES!!!
Mine lasted about 4.5 years now (supercharged 3" pulley). and finally the boot started cracking because I left the car unused for a while with Power steering fluid leaking onto it. My clutch actually needed to be replaced before the boot, so I def. attest to their quality.
def. worth the initial investment. I will be getting a Boot kit from them if I can.
Also I lowered my cross member with two 1/8" washers at each bolt. this was for hood clearance with engine (whole dif. story). When I lowered the engine, I felt a difference in the cars handling characteristic.
I have vogtland springs up front which have a 1-1.25" drop I think. In addition I have shortened koni shocks which provide suspension travel. It is a great setup I have enjoyed for some time now. My car does not look lowered for the most part unless stading next to a stock car. then you notice the slight front rake.
HomerMAC is offline
Old 10-10-2011, 09:55 AM
speedymax99's Avatar
Lowering the engine/trans is a bad idea for ground clearance and axle wear reasons.
Custom control arms and coilovers for a track Max have been done, just not offered for sale.
Raising the whole front subframe has been done to improve suspension geometry and handling.
With track oriented camber, it does help outer joint life.
speedymax99 is offline
Old 10-20-2011, 11:33 AM
Shift_Max's Avatar
Kinda the opposite of what the OP was talking about but I finally lowered my drivetrain using custom spacers. They are 20mm in thickness. Here is one shot of the front ones and the rear ones on the center-beam.
Old 10-20-2011, 01:36 PM
J2FRESH's Avatar
whats the purpose of that? ^
J2FRESH is offline
Old 10-20-2011, 01:42 PM
Shift_Max's Avatar
For clearance issues with the hood/motor.
Old 10-21-2011, 02:06 AM
J2FRESH's Avatar
ahhh i see i see hmm thats pretty cool
J2FRESH is offline
Old 10-21-2011, 07:44 AM
ralphalain91@gmail.com's Avatar
What does it do exactly ?
ralphalain91@gmail.com is offline
Old 10-21-2011, 04:11 PM
It ruins the suspension geometry and handling in order to clear the hood.
Old 10-21-2011, 06:33 PM
MAXC's Avatar
My question is, Why all of a sudden was or is the motor not clearing the hood? Hell if I lower my cross member, I wont make it over a speed bump.
MAXC is offline
Old 10-21-2011, 07:23 PM
Lowering the engine/trans by itself lowers the front COG and shortens the roll couple. This actually helps improve handling but at the expense of axle life. Raising the suspension subframe woud help as that raises the roll center among other things.
Old 10-21-2011, 07:24 PM
350Z intake manifold swap onto a VQ35 if I had to guess.
Old 10-30-2011, 11:39 PM
IHAVEA2KMAXIMA's Avatar
I would be scared for the oil pan @_@
IHAVEA2KMAXIMA is offline
Old 10-31-2011, 08:14 AM
Lightly modded
95maxrider's Avatar
I'm on Eibachs now, and am considering getting BC coilovers in the spring. I want to make sure I'm understanding this correctly though; if I drop my engine/trans by 0.5", then I should raise my front suspension by the same or more, correct?
95maxrider is offline
Old 10-31-2011, 09:10 AM
Do you guys think those subframe reinforcement collars will help at all?
ChrisMan287 is offline
Old 11-01-2011, 06:56 AM
Shift_Max's Avatar
That is what I ended up doing. My spacers were 20mm thick so I raised the car up with the coilovers the same amount.
Old 03-09-2012, 07:04 PM
$mokey87's Avatar
Going Thur the same thing did u lift the car up? Any better?
$mokey87 is offline
Old 03-09-2012, 07:12 PM
$mokey87's Avatar
Hey were can I find those axles hit me up 305 877 6953
$mokey87 is offline
Old 03-10-2012, 12:06 PM
asand1's Avatar
Why not rotate the drive train? Raise the different while lowering the front of the engine.
Two problems would be exhaust and shift linkeage.
asand1 is offline
Old 03-10-2012, 12:37 PM
Those are small issues compared to engine and trans oiling problems...
Quick Reply: Ways to battle CV axles failures
