AP Racing rotor
AP Racing rotor
I currently have the AP racing BBK on the front and rear. I want to upgrade the front rotor to a bigger size. Would the front rotor from the 370z 6 piston setup work with my 4 piston caliper? Is the 370 brake setups compatible with the maxima?
oh... also you would need to run larger rims! currently 17" is the minimum size you can run with the kit, if you run a bigger rotor with a relocation bracket that pushes the caliper further from the hub center 17" rims are then too small. If u decide to run a bigger rotor and upgrade your rims, get lighter rims because the larger rotor will add weight and a larger but lighter rim will counteract that added unsprung weight! Lastly, if u purchase new rims check your offset and rim to caliper clearance or you'll be hit'n yourself in the face after all your purchases :-/
04-16-2020 05:15 AM
