jclaw traction control bar set
Is anyone here using jclaw traction control bars and if so can you post pics of them installed
All the views and nobody has jclaw traction control bars
Originally Posted by TurboA32
(Post 8880284)
You remove the two chain-down eyes from the front frame (two or three bolts) and instead bolt in a steel plate drilled for the same frame holes and one hole for the bolt thru the Heim joint on one end of the bar. The other end has another Heim joint and a bolt goes thru that into an existing hole in the control arm The front end of each bar has a lot of adjustment since the Heim joint screws into the end of each Jbar, with a locking nut to keep anything from changing. These work very well, eliminate wheel hop and improve steering stability. I looked in my Photobucket account, but I didn't see any Jbars photos there. |
© 2024 MH Sub I, LLC dba Internet Brands
