Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Advanced Suspension, Chassis, and Braking (https://maxima.org/forums/advanced-suspension-chassis-braking-68/)
-   -   Quick Question Tokico Illumina's (https://maxima.org/forums/advanced-suspension-chassis-braking/674983-quick-question-tokico-illuminas.html)
TravisCadello Feb 13, 2014 08:47 PM
Got the Tokico's installed, My question is why is their a small black box that looks like its meant to hold the Red tip with the numbers on it? I put the Tips on and they fit pretty loosely and probably would fall off, are they supposed to stay on the rod Tightly?
And also, Why does the adjuster screw just keep turning and never stop? How do i know if im actually on 5 or not?
thx....
Amerikaner83 Feb 13, 2014 09:23 PM
it's pretty fragile and it sounds like you broke it.
Prophecy99 Feb 14, 2014 10:31 AM
no they are pretty loose, and how do you know they are on 5? with the red tips on there
you shouldn't have turned it not knowing what settings they were originally at
TravisCadello Feb 16, 2014 09:05 PM
It didnt break, they just sit on their too loosely for my liking..
TravisCadello Feb 16, 2014 09:06 PM
I had them on while i set it to 5 then removed caps.
Prophecy99 Feb 17, 2014 10:09 AM
you put them on only temporarily for the purpose of adjusting... you're not supposed leave them on there... what does it matter?
Mattx Apr 6, 2015 09:32 PM
Originally Posted by TravisCadello (Post 8915316)
Got the Tokico's installed, My question is why is their a small black box that looks like its meant to hold the Red tip with the numbers on it? I put the Tips on and they fit pretty loosely and probably would fall off, are they supposed to stay on the rod Tightly? And also, Why does the adjuster screw just keep turning and never stop? How do i know if im actually on 5 or not? thx....
I can tell you how you know when ur on 5. There's a flat spot on the top threaded piece that the selector sits on. When you are lined up on that flat spot you are on 5. It only lines up perfect one way. This is assuming your install was on point. Just to let you know, you are only supposed to turn clock wise. You should never turn counter clock wise that is the way they're designed.
ABIGBRAIN Apr 6, 2015 10:31 PM
Push down on the fender with some force.... you'll kmow right away if your on 1 or 5. Then just set them according to your personal preference.
Prophecy99 Apr 7, 2015 09:30 AM
News to me, and interesting if true???
Mattx Jun 3, 2015 10:23 PM
Yea I found it interesting as well. I can't remember his name but he's the suspension guru for maximas has his own thread. I can't believe I can't get his name anyway he's the one who told me this.
Mattx Jun 3, 2015 10:27 PM
Djfreestyle. Sorry buddy. 😄
