Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
CNC machined bracket to bolt 370z Akebono Calipers to 95 thru 08
Old 12-02-2018, 08:36 AM
gous44ls's Avatar
This just changed my life! A bracket made to fit the Akebono Calipers to the maxima. You will either need to machine down the factory 14" 370z rotors or you can just use Mitsubishi Evo X GSR 13.78″ (350 MM) rotors. This opens up so many new possibilities!
Link to brackets:
https://www.ebay.com/itm/Front-Akebono-Big-Brake-Caliper-Rotor-Upgrade-Adapter-Bracket-For-300ZX-Z32/142692776193?fits=Model%3A300ZX&hash=item213926f90 1:g:LqAAAOSw~89ah4Fa
gous44ls is offline
Old 12-02-2018, 08:40 AM
gous44ls's Avatar
These are made for the 300zx but as most know will bolt right up to our cars.
gous44ls is offline
Old 12-03-2018, 07:54 AM
Correct. They will bolt up.
ChrisMan287 is offline
Old 12-26-2018, 04:35 PM
Father of the 00 VI
krismax's Avatar
could we use stock g37 and 370 z calipers?
krismax is offline
Old 01-08-2019, 03:43 AM
danmack34's Avatar
Any pics of them installed goul44ls
danmack34 is offline
Old 01-08-2019, 06:57 AM
@danmack34
Old 01-08-2019, 08:04 AM
danmack34's Avatar
thanks @ChrisMan287 I did the 996 front / rear calipers on the m3 with CSL rotors so for the maxima it seems fitting lol I found the calipers for $48 each (with core charge) but realistically $250 said and done if I don't return a core which im gonna have to ask about. EvoX 350mm rotors (Ill have to make sure the center bore is the same) and the adaptors is everything ? no line adaptors ? I take it now is the time to go stainless lol anyone do the rear calipers yet ? Even if I have to eliminate the E brake (since its a auto (not by choice it fell into my lap lol))
Old 01-08-2019, 08:08 AM
danmack34's Avatar
also @ChrisMan287 theres 3 other adaptors for the 300zx for "front big brake kits" for dif rotors and such, I take it I should just stick to the adaptor that was shared above and the evo 350mm rotors?
Old 01-08-2019, 08:39 AM
I can't confirm that the other brackets will work but I can assume that they will. You should be able to use stock lines but it won't hurt to switch to stainless.
No rear options that I can think of...
ac max 92
09-02-2015 06:04 AM
Dark99GLE
09-10-2008 06:34 AM
joeyd
11-17-2005 03:55 PM
AKOGAN
07-28-2005 05:12 PM
d1max2nv
06-24-2004 07:21 PM
Quick Reply: CNC machined bracket to bolt 370z Akebono Calipers to 95 thru 08
