2000 vi swap pictures
Old 05-11-2005, 10:19 AM
  #41
vsamoylov
or you can contact me for the adaper plates as well cause maxs is my bro. the adapter plates are top-notch.
Old 05-11-2005, 11:13 AM
  #42
THT
Throbbing member
THT's Avatar
Nismo3112 made them and gave them to me when I bought the VI from him.
THT is offline
Old 05-11-2005, 11:38 AM
  #43
eckohb's Avatar
but i need to know if thats all i will need then. the adapter plates, and the manifold? i dont want to go there, and have to go back later. and vsamoylov, how much are these adapter plates? how many will i need?
eckohb is offline
Old 05-11-2005, 12:41 PM
  #44
THT
Throbbing member
THT's Avatar
You'll need two; one for TB and one for IACV. All you need is the upper IM. You will need to flip the DE lower IM and redrill the DEK upper IM to fit. Go to a parts store and buy several feet of vaccum hose though. Also buy caps if you decide to disable/remove the EGR.
THT is offline
Old 05-11-2005, 02:01 PM
  #45
eckohb's Avatar
is there a benefit of using the 5th gen TB over the 4th gen? I thought i remembered saying it'd be tough to use the 5th gen TB with our 4th gen IACV or something. Does disabling the EGR = CEL?
eckohb is offline
Old 05-11-2005, 02:13 PM
  #46
THT
Throbbing member
THT's Avatar
Using the 5th gen TB does cause clearance issues with EGR. And disabling the EGR does not result in a CEL as long as you leave the sensors plugged in and dangling in the engine bay.
THT is offline
Old 05-11-2005, 02:48 PM
  #47
nismology's Avatar
You'll get an 0302 EGR High/low flow code if the EGR is disabled.
nismology is offline
Old 05-11-2005, 02:51 PM
  #48
THT
Throbbing member
THT's Avatar
My EGR is disabled and I don't have a CEL. I have all the sensors still plugged in too.
THT is offline
Old 05-11-2005, 03:20 PM
  #49
nismology's Avatar
I have mine disabled with all the sensors plugged in and get the code. I don't see how you're not getting one. That's the whole point of the EGR temp sensor, to determine if there is EGR flow or not in the conditions that call for it. Check your codes or check to see if the CEL itself is blown.
Old 05-12-2005, 12:21 AM
  #50
eckohb's Avatar
why would you disable the EGR? Is there a benefit of that? Or does it just make the install easier? I dont really care about a CEL, as long as I know what its for and its not robbing my car of power.
eckohb is offline
Old 05-12-2005, 07:09 AM
  #51
THT
Throbbing member
THT's Avatar
I've checked for codes; no codes. I disabled the EGR because I didn't have a 5th gen guide tube on hand. You won't loose any power but you will run a little richer.
THT is offline
Old 05-12-2005, 07:23 AM
  #52
nismology's Avatar
This makes no sense. Are you sure your EGR is really disabled? How did you go about doing this?
Old 05-12-2005, 07:51 AM
  #53
THT
Throbbing member
THT's Avatar
Yes, I'm positive it is disabled. The guide tube is not bolt to the IM. The coolant has been bypassed. The vaccum sources were capped.
THT is offline
Old 05-12-2005, 02:11 PM
  #54
eckohb's Avatar
about how long do you think it would take to complete this project? Is it a weekend sorta deal? I'm really interested in doing, and want to inform myself before i go into something that i really know nothing about. and you said using the 5th gen TB would cause clearance issues with the EGR, but if i disabled the EGR anyways, couldnt i just remove the EGR itself and not have that problem?
eckohb is offline
Old 05-12-2005, 02:37 PM
  #55
THT
Throbbing member
THT's Avatar
Removal of IM: 1.5 hours (first time)
Installation of VI: .5 hour
Figuring out vaccum hoses: 3-4 hours
Expect to make a few trips to the auto parts store for various stuff too.
THT is offline
Old 05-12-2005, 02:49 PM
  #56
eckohb's Avatar
thats cool. but what doy ou think about the whole 5th gen tb issue? would it be possible just to eliminate the egr completely?
eckohb is offline
Old 05-12-2005, 03:30 PM
  #57
THT
Throbbing member
THT's Avatar
I'm using the 4th TB so I don't have to deal with clearance issues.
THT is offline
Old 05-12-2005, 10:48 PM
  #58
eckohb's Avatar
would the 5th gen have better gains? Did you do the VI and ECU at the same time? or did you do them seperately? I cant wait to feel the difference between my IM now and the 00 VI. Im hoping its going to definitely be noticeable.
eckohb is offline
Old 05-13-2005, 04:22 AM
  #59
THT
Throbbing member
THT's Avatar
I'm inclined to say no.
THT is offline
Old 05-13-2005, 11:44 AM
  #60
eckohb's Avatar
no to which question? what sorta hp/tq gains would i be seeing using just the VI?
eckohb is offline
Old 05-13-2005, 02:19 PM
  #61
THT
Throbbing member
THT's Avatar
No gains from 5th TB is what I meant. As for the order, I had the ECU before I got the VI. Each was like putting an aftermarket y-pipe on all over again.
THT is offline
Old 05-13-2005, 02:40 PM
  #62
eckohb's Avatar
really? wow...i cant wait. i love how i can feel the y pipe at 3500 rpms. I found one for 125 bucks...just a matter of driving down there. Probably pick it up at the next chicago meet.
eckohb is offline
Old 05-13-2005, 05:08 PM
  #63
maxS
Originally Posted by nismology
Instead of putting the elbow on the intake manifold, why didn't you just put the elbow at the bottom of the throttle body where the IACV sat before?
because of clearance problem - between 2000 tb and egr, there's only about .5" gap, that's why 2000 ivac is removed and i had to cut a plug plate and screw it in its place...
Old 05-17-2005, 06:34 PM
  #64
nismology's Avatar
Oh ok...gotcha 100%
Old 05-17-2005, 06:58 PM
  #65
Maxima.org Insomniac
98SEBlackMax's Avatar
So what switchover are you guys using for the 2k VI swaps? Ive got my 2K VI set at 4600 RPM right now via SMT-6 and it feels good, but im open to suggestions.
98SEBlackMax is offline
Old 05-18-2005, 05:37 AM
  #66
SDot82's Avatar
I would like to know this too as well as if you are using your stock ecu or upgraded ecu. Also mines is opening at about 4800 rpms.
SDot82 is offline
Old 05-18-2005, 10:27 PM
  #67
maxS
mine is not opening yet
Old 05-20-2005, 03:45 PM
  #68
THT
Throbbing member
THT's Avatar
Mine opens at 4600 and I'm using a Summit RPM switch. I've also got an upgraded ECU (no rev limit increase though) for whoever asked.
THT is offline
Old 05-20-2005, 03:55 PM
  #69
Kevlo for President
Kevlo911's Avatar
What is wrong w/ it?
Kevlo911 is offline
Old 05-20-2005, 08:27 PM
  #70
s0ber's Avatar
Do you guys know if the 4th gen and the 5th gen TPS sensor are identical?
my 5th gen TPS is cracked in the casing, and it feels weird when turning it... Guess i'll have to use my 4th gen one..
s0ber is offline
Old 05-21-2005, 07:37 AM
  #71
Kevlo for President
Kevlo911's Avatar
I would just reuse the 4th gen one.
Kevlo911 is offline
Old 05-22-2005, 07:25 AM
  #72
eckohb's Avatar
have you had a chance to get to a track yet kevlo?
eckohb is offline
Old 05-24-2005, 10:56 AM
  #73
99Maxxx's Avatar
this may be a stupid question, but are all 00-01 intake manifolds VI?
99Maxxx is offline
Old 05-24-2005, 11:02 AM
  #74
Stephen Max's Avatar
There are no stupid questions. There are only stupid people.
Just kidding!!! You may flip me the virtual bird if you want. I couldn't resist.
Yes, all 2000-01 intake manifolds are VI.
Stephen Max is offline
Old 05-24-2005, 11:06 AM
  #75
eckohb's Avatar
this is good stuff. i picked up my 00 upper IM yesterday, and ordered my rpm switch today. Then have to order the adapter plates tomorrow. Are the gains the same using just the upper as opposed to using the lower with the fuel rail, injectors, etc...? What's the significance of using the lower from the 00?
eckohb is offline
Old 05-24-2005, 11:43 AM
  #76
jmeister's Avatar
just simple ease of installation; don't have to remove, rotate & drill new holes like the 4th lower requires for the swap.
DE-K TB & injectors are larger as well.
jmeister is offline
Old 05-24-2005, 12:03 PM
  #77
Yeah, the only reason to use the 4th gen lower IM is if you have 370 cc/min or larger sidefeeds and want to keep them.
Old 05-24-2005, 08:32 PM
  #78
be the change u want2C
Ninos_Maxima's Avatar
^also its a bit cheaper
Ninos_Maxima is offline
Old 05-25-2005, 03:44 PM
  #79
Maxima Owner
MaximaSE96's Avatar
what drilling is needed on the 4th gen lower IM and who sells adapter plates needed for this swap
MaximaSE96 is offline
Old 05-25-2005, 06:10 PM
  #80
vsamoylov
maxs sells adapter plates.
Quick Reply: 2000 vi swap pictures
