Sponsored by:
Sponsored by: CARiD
VQ35DE stock injector CC's?
Old Jan 19, 2006 | 12:53 PM
Fred Allen Burge's Avatar
Hey,
What is the stock VQ35 injector's flow rate? Also, are they high impedence or low?
thanks
allen
Old Jan 19, 2006 | 01:00 PM
Puppetmaster's Avatar
Injector CCs can be found here:
http://forums.maxima.org/showpost.ph...7&postcount=35
Old Jan 19, 2006 | 01:15 PM
Thanks, I think they're low impedence, don't remember seeing a resistor. Anyone know for sure?
If not I'll check one out myself sooner or later.
allen
Old Jan 19, 2006 | 02:24 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
High impedance...
Old Feb 3, 2006 | 04:19 PM
vsamoylov
what about the 350z? dont they flow more then the maxima?
Old Feb 5, 2006 | 11:14 AM
NmexMAX's Avatar
dot dot dot ...
The answer is at the click of a button ...
Originally Posted by Puppetmaster
http://forums.maxima.org/showpost.php?p=4406987&postcount=35
VQ35DE: 315cc @ 3.5 BAR (FBJC101, FWD versions)
VQ35DE: 335cc @ 3.5 BAR (FBJC100, 350z etc.)
The '05 350Z (not the rev up engine) have a different injetor part number and I do not know if they're still 335cc.
Old Feb 5, 2006 | 06:30 PM
vsamoylov
ok so the injectors are different and so is the lower im and the upper plenum on the 350z for the 03-04 model and that gives you 287 hp unless nissan programmed the ecu in a different way then the max. on the 05-06 350z nissan made the lrunners (lower part of the plunem) shorter so that changes hp rating to 300 unless they changed the ecu and the injectors again
Old Feb 12, 2006 | 01:35 PM
Charcoal95GXE's Avatar
315 cc's is the equivelent of 30/lb injectors..thats actually kinda impressive
Old Feb 12, 2006 | 01:40 PM
steven88's Avatar
Need A Light?
when it says cc...does it mean it squirts out 315 cubic centimeters of gasoline per minute?
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
