3.5 intake cams in 3.0
ok guys i did a search yesterday and the only question that wasn't answered was if the 3.5 intake cams would be a gain over the stock dek intake cams. from what i read the exhaust cams in the dek are really good and don't need to be changed. from reading i also saw that the 3.5 cams work with a spacer and cam sprocket being modified to fit and keep it in time with the 3.0 timing. so i guess my question is, is there a gain to be had with the 3.5 intake cams in my dek? thanks for any info.
Originally Posted by OOmaxSE
By somewhat, would you mean 10ish*? Sorry, I'm learning in this all motor field.
Originally Posted by LA02MAX
Get the NEW VQ35DE intake cams
Originally Posted by NmexMAX
Might as well get the eBay cams for a better price. Doubt we'll see any totaled L31's anytime soon, and getting the cams from dealer might sting a tad.. Plus tot ake full advantage of the new L31 cams, you'll need the VTC's as well.
Originally Posted by SuperStasiu
Well StephenMax makes the adapter for those with the 3.0's lookeing to run the 3.5 cams without haveing to modify anything else or without haveing to drill the cams.
Read this, catch yourself up and the latest developments, and have a coke while you're at it. http://forums.maxima.org/showthread.php?t=506342
BTW, it is post # 4 in this thread.
That's not acceptable.. You should make every humanely possible effort to do so. Believe me, you'll regret it if you don't.
Thats true, so I can see where I am am and what I've gained. I guess I'll do a baseline before the E-U, then after E-U. Then after E-U and cam install. Just to get a good judgement of what the cams can do.
Originally Posted by xlcrew
ok so go with the ebay cams or just 3.5 intake cams? is i do either do i just get ahold of stephenmax to get the adapters needed?
Originally Posted by SR20DEN
Doing just the intake cams would be a waste of time. If you're going to use VQ35 cams, use the whole set. All OE VQ35 cams > All OE VQ30 cams.
do i have to get adapters made for the exhaust cams or just the intake ones?
Just because you've been out for a while doesn't mean you have to go and post in every thread you see. This is the second time where it's obvious you haven't read any of the above posts aside from the immediate one.
Yeah i did read this hole thread AND i read that thread in post number 4 relax dude. I was just throwing out a suggestion. Oh yeah and i don't have any coke damit just F$%ken pepsi, lol. I guess i should of written out what i ment completely sorry masta
stop stalking me aaaahhhhh
