FULL 3.5 Swap questions about process and hardware
Old 04-25-2008, 12:58 PM
  #121
goldtooth's Avatar
Now, for the 02/03 PS pump, the bolt that connects the hose to the actual pump is much bigger than the 4th gen bolt. Therefore, I cannot use the 4th gen hose with the 02/03 PS pump or the 4th gen bolt with the 02/03 PS pump. Should I just put on the 4th gen PS pump? How did you guys setup the PS?
goldtooth is offline
Old 04-25-2008, 03:56 PM
  #122
nismology's Avatar
No real reason to not go with the A32 pump.
nismology is offline
Old 04-25-2008, 04:00 PM
  #123
goldtooth's Avatar
I wanted another opinion on what to do. A32 PS pump it is!
Old 04-25-2008, 04:01 PM
  #124
goldtooth's Avatar
Which belts do I want to purchase? Part number? I mounted the A32 compressor on the A33B engine with that mounting bracket... Do I want just stock A32 belts?
Old 04-25-2008, 04:26 PM
  #125
dot dot dot ...
NmexMAX's Avatar
IIRC, I've mixed / matched belts w/ my A32 & A33B.
NmexMAX is offline
Old 04-25-2008, 04:58 PM
  #126
eng92's Avatar
Those rings look like they will overlap the counterbores for your bolt heads.
You went through the effort of having them profile cut. Why did you not make the ID larger and have them cut-in some tabs for welding to your spacer?
eng92 is offline
Old 04-26-2008, 08:03 AM
  #127
goldtooth's Avatar
We will see how it turns out tomorrow, or Monday.
Now, for the ECTS, at least I think that's what it is referring to, first line on the green portion of the green and yellow spreadsheet, says SIGNAL NOT COMPATIBLE - WILL HAVE TO RETRO 98 SENSOR. What exactly am I supposed to do here? Is this the part? http://forums.maxima.org/showthread.php?t=560185 (In post #11)
Old 04-27-2008, 12:27 AM
  #128
goldtooth's Avatar
Headers installed, engine is now one with car!!
Old 04-27-2008, 12:09 PM
  #129
goldtooth's Avatar
Seems like I had some difficulty with the A33B motor mount brackets (rear one especially) on the engine, so I swapped in the A32 ones. Install went flawless, just wanted to note that. But I was doing this at 1 AM...on a parking lot. Oh well, as long as it is done.
Old 04-27-2008, 02:17 PM
  #130
goldtooth's Avatar
How will my fuel system be setup? I have a Walbro 190 ready to go in, and a sx performance AFPR(if necessary).
Old 04-28-2008, 02:03 PM
  #131
ajcool2's Avatar
Originally Posted by nismology
People looking for a write-up are looking for an easy button, IMO. A write-up won't make it any easier because what needs to be done depends on the year of the car; and in a few cases, its options. Either way you will have to dig through the FSM's to confirm where and how to make the connections.
Maybe there could be a beginner's guide to what needs to be purchased/acquired and an overview of some of the necessary connections... but the nitty-gritty of the wiring portion should be discussed with someone who knows what to do if one has NO idea where to begin.
A beginners guide would be great since theres peices that I'm still not understanding completely about the whole process. Also if and when I did decide to do the swap it would help me make the decision on which route to take according to my skills since I'm not to confident when it comes to opening up an engine.
ajcool2 is offline
Old 04-28-2008, 02:10 PM
  #132
dot dot dot ...
NmexMAX's Avatar
with a full swap you don't need to open the motor up at all.
http://forums.maxima.org/showpost.ph...2&postcount=28
NmexMAX is offline
Old 04-28-2008, 02:18 PM
  #133
ajcool2's Avatar
I meant deciding whether to do a full swap or a partial one. If the partial is that much easier than the full swap then I'll take my chances opening it up.
ajcool2 is offline
Old 04-28-2008, 02:21 PM
  #134
nismology's Avatar
Yes. The hybrid setup with 3.0 timing components is that much easier.
Old 04-28-2008, 03:20 PM
  #135
yevrah4728's Avatar
Originally Posted by eng92
I do not know what timing ring you measured at 11-3/8".
I have measured timing rings from an A32-5MT, A33B-4AT and an A33B/A34-6MT and they all measure in at a little over 11-7/8".
sorry for the super late response (computer issues) but. the timing ring i measured at 11 3/8 is the one that came off of the motor i purchased (a34 at)
ever since, I've been back and forth to the dealership and i did find out that the cps from the a33 3.5 (side) is in a different position than the a34 3.5 (bottom) the part numbers on the cps' are obviously different between the models but they are the same on each model with the 6spd and auto. my only option (i assume) is to have the spacer made with the ring that came with the motor...after i grind it off the drive plate. =(
yevrah4728 is offline
Old 04-28-2008, 04:34 PM
  #136
goldtooth's Avatar
On the ring spacer weldment, the total width (timing ring with the spacer) is .491", just wondering would it be alright if mine was off by .030". The one I had is .462". If this is not good, and I'm assuming it is not because the sensor would not be correctly aligned with the timing ring, I will just put washers under the spacer to even out the difference. What do you think?
Old 04-28-2008, 04:39 PM
  #137
eng92's Avatar
You need to distinguish between 4AT and 5AT. The CPS for an A34-6MT and 4AT are the same. The 5AT is different.
The A33B and A34 6MT flywheels are the same.
Therefore, use the 11-7/8" timing ring and a CPS from an A34 6MT (or 4AT) 23731-8J106
eng92 is offline
Old 04-28-2008, 04:49 PM
  #138
eng92's Avatar
If your spacer is made out of 3/8" material, then it will be fine as is. Your timing ring must be made out of thinner material.
Mine measured in at about 3 mm
eng92 is offline
Old 04-28-2008, 04:58 PM
  #139
goldtooth's Avatar
My spacer is made out of 3/8" material.
Old 04-29-2008, 01:51 PM
  #140
goldtooth's Avatar
For the alternator and starter, will I be using the '98 harnesses that are on the body already(engine room harness)?
Old 04-29-2008, 02:11 PM
  #141
goldtooth's Avatar
As for recharging the AC system, do I have to get it professionally done, or can I just pick a bottle of this up and do it myself?
http://www.amazon.com/Interdynamics-.../dp/B0007ZDR9Y
Old 04-30-2008, 04:39 AM
  #142
goldtooth's Avatar
And for the PS sensor, does the 02/03 engine control harness plug right into the '98 PS sensor(the one on the back of the strut tower)?
Old 04-30-2008, 05:56 AM
  #143
eng92's Avatar
Standard practice is to evacuate the system before recharging to remove any moisture and other contaminants that may have entered while it was open.
Why did you disconnect the lines from the compressor to begin with?
eng92 is offline
Old 04-30-2008, 06:01 AM
  #144
eng92's Avatar
I used the A33B pump (with built-in fpr) on mine. If you are going with a Walbro, you will need the AFPR.
If you are using the A32 starter and alternator, then use the A32 wiring.
eng92 is offline
Old 04-30-2008, 08:31 AM
  #145
goldtooth's Avatar
To be honest, I didn't realize what I was unbolting until I disconnected everything.
Old 04-30-2008, 08:48 AM
  #146
eng92's Avatar
The A32 uses a switch. (output is on or off)
The A33B uses a sensor. (output varying with pressure)
IIRC it just bumps up engine rpm to compensate for the added pumping load if you are turning the wheels when the vehicle is not moving. It is not unlike one of the functions of the A/C pressure sensor.
If you do not mind the code, just leave the connector empty.
Otherwise you will have to get a hold of an appropriate sensor.
eng92 is offline
Old 04-30-2008, 09:11 AM
  #147
goldtooth's Avatar
Now, for the Coolant log, will I be using the 02/03 or the '98? It seems like neither of the stock hoses(02/03 vs 98) that go from the coolant log to the radiator are the right size. Will using the '98 coolant log fix this problem as it seems that it sits a bit lower? Or can I just go to the Auto Parts store and ask for some Coolant lines and I can cut it to fit?
Now for the ECTS, at least I think that's what it is referring to, first line on the green portion of the green and yellow spreadsheet, says SIGNAL NOT COMPATIBLE - WILL HAVE TO RETRO 98 SENSOR. What exactly am I supposed to do here? Is this the part? http://forums.maxima.org/showthread.php?t=560185 (In post #11)
Old 04-30-2008, 06:54 PM
  #148
goldtooth's Avatar
And what am I doing about the oxygen sensors? The cattman headers I bought have only 1 bung on each, but the stock exhaust manifolds I pulled off have one before and after the precat... Where can I place simulators? Educate me please.
Old 04-30-2008, 07:05 PM
  #149
No more Maximas...
pmohr's Avatar
Sim the downstreams, they're useless (don't make me, Nmex...)
pmohr is offline
Old 04-30-2008, 07:40 PM
  #150
goldtooth's Avatar
I prefer not to be spoon fed, because I am willing to learn in case anything should happen, it would be easier to diagnose the issue with more knowledge, but in some cases, I think a quick explaination wouldn't hurt? (Thanks pmohr) I searched O2 simulators earlier in the week, but couldn't find what I was looking for. I couldn't relate others experiences to mine(although I know you're thinking wtf, since we all have the same cars...), so I only wanted a more directly specified answer. Big thanks go out to everyone that has communicated with me regarding this swap. I think the big hurdle is now done and I'm finally assembling the final pieces to the project. The maxima should be running before the weekend, if weather permits. (no garage)
Old 05-01-2008, 06:04 PM
  #151
goldtooth's Avatar
Today I tested a broken 02/03 PS sensor. What I mean is that the threading fits perfectly. So now I will just get a 02/03 PS sensor, screw it in the 4th gen lines, plug it in with the 02/03 harness and everything should be dandy!
Update: I went to Murray's Auto and just picked out a hose that fit....
I still do not understand what to do about the second part though.
BTW, I am using the 02/03 Coolant log.
Old 05-01-2008, 07:12 PM
  #152
eng92's Avatar
If you have auto climate, you will lose part of the "auto" function.
eng92 is offline
Old 05-01-2008, 07:33 PM
  #153
goldtooth's Avatar
So if I put on the '98 Coolant log, would everything run as it did?
Old 05-01-2008, 07:43 PM
  #154
No more Maximas...
pmohr's Avatar
Actually, since you're a full 3.5 swap, you should be able to just use the VQ35 stock coolant log.
I believe the ECTS thing is in reference to an A32 ECU.
pmohr is offline
Old 05-01-2008, 11:03 PM
  #155
nismology's Avatar
The A32 a/c auto amp can't do anything with the signal from the ECTS itself. The coolant temp sending unit (what sends the signal to the gauge in A32's) needs to be retained for certain functions to work.
Old 05-02-2008, 09:20 PM
  #156
goldtooth's Avatar
I've put the dash back in and plugged the A33B guage cluster in. All the lights turned on as I turned the ignition to ON. I still have all of the dash switches disconnected, but the variable windshield wiper option does not work at all on any of the settings. Normal and High speed wiper options work fine.
Question about the ignition switch thing(not sure exactly what it is called): There is a 2 pin connector, the A32 has a female connector and the A33B has a male connector. Obviously, they don't plug together(as in the A33B connector does not plug into the wiring on the A32 chassis because it would be male to male connector), do I have to cut and adapt the connectors? Does anyone know what this connector is for? or the name of the component?
Old 05-04-2008, 08:29 AM
  #157
goldtooth's Avatar
b u m p please
Old 05-06-2008, 06:51 PM
  #158
goldtooth's Avatar
Update: I found the problem, I forgot to plug the AC Auto Amp back in. Everything works perfect now.
Old 05-06-2008, 06:58 PM
  #159
goldtooth's Avatar
Is this Power to the NATS?
Old 05-06-2008, 07:14 PM
  #160
goldtooth's Avatar
Cattman exhaust is on. Axles are in. Wiring is complete.
I only have to finish fabricating custom mounting brackets for the 03 guage cluster. There's like 5-10 min of finishing the interior... nice.
Quick Reply: FULL 3.5 Swap questions about process and hardware
