3.5 swap/DEK swap with NO codes?
I just wanted to say, firstly, as someone who has done countless DEK swaps the information on here about that particular swap is the WORST. There are like 400 threads of useless clutter. I may take it upon myself at a later date to just go through with doing a write up for the DEK swap, but as far as the vac lines go, and the wiring, etc....even for the 00vi, the information in the stickys wasnt useful AT ALL to me beyond a few obvious things. Just had to get that out the way, lol. [/rant]
Now to business, I realized as I did the last 3.5 swap I did, the mounting holes on the 3.5 head for the 95-01 EGR system are there. Which lead me to believe...if you used a 95 ECU, which doesnt monitor EVAP, and you implemented the EGR system from a 95-98 (vacuum regulated EGR, not electronic like the 99s), and even blocked off the guide tube that feeds the exhaust into the IM (Instead of custom welding one, or using a 6th gen motor setup), you could plug in the EGR temp sensor and solenoid and get absolutely no codes for anything right? Are there any codeless 3.5 swaps out there? What have you done? I dont mean your CEL bulb doesnt work, or you have a wiring problem and your lights never worked. I mean hook up to a scanner and actually pass emissions. For the DEK, same thing, except you can just use the 2000 motor with EGR, and get no codes at all. I only included the DEK in my title because I wanted to legitimately rant, ha ha. If theres a thread on different ways people got around codes on these swaps, link me please. Tired of hearing of and performing 3.5 swaps with codes. |
I'm looking at doing a 3.5 swap in the next few months and I already told myself I would do whatever was necessary to walk away without any codes. I don't need to pass a code check where I live, either, I just don't want my CEL on or be uncertain about whether the codes are legitimate or swap-caused.
Originally Posted by Tatanko
(Post 6884729)
I do not have a egr code and v/i'd it with a scan tool. all I did is plug in the sensor and tied the probe next to the header and it worked. as for the evap haven't hooked up the vac lines yet lazy but everything is there and ready to go maybe when it get warmer I'll try it out and post the results
also there is a guy on here that has a codeless swap but fab'd custom brackets and mounts for the evap and egr. I'll try to find his thread since it has some really good pic's and details |
I was able to prevent any EGR codes on my old '95 with an 00VI and blocked off EGR by keeping the temp. sensor plugged in and just zip-tieing it in the engine bay. My EVAP was all in place and functioning, which IMO was easy and I didn't even need any brackets. This is exactly how I plan to proceed with a 3.5 swap (except maybe with a few nice brackets this time) and I will probably expirement with resistors or something to correct any problem codes that may arise.
This guy has no codes with his 3.5 swap. http://forums.maxima.org/6653997-post91.html
I was getting ready to post about the whole EGR issue soon. Here in WA, they just pull codes on OBDII emissions vehicles, no codes, and you pass emissions. All of the emissions testing stations are run by the state, so there is no one you can 'pay off' to pass. Having codes is not an option for me, and I am not swapping motors everytime I need to do emissions.
I have been researching ways around the EGR code in my spare time (which is not very much) for a few weeks now. Most of the advice I have seen is just plain wrong, but that is typical here. I have been waiting until I have time to download a 6th gen FSM and check out the EGR system on that car before posting. I do not know anyone with a 6th gen local to me to physically check it out myself. Here is a picture of the 4th gen EGR system: https://i47.photobucket.com/albums/f...x/100_0991.jpg Here is a 2002 motor currently sitting in my garage, no EGR system: http://i47.photobucket.com/albums/f1...lemax/EGR1.jpg Notice no mounting on the block http://i47.photobucket.com/albums/f1...lemax/EGR2.jpg Does anyone have a good picture of the 6th gen EGR system? It would be nice to have this info all in one place. If we can get some good, useful, correct info on this, I'll make this thread a sticky. |
^^^^ very very niceee
OK, firstly, I dont know how guys are just "plugging it in". I've done this on ALL my swaps and even plugged in the EGR soloenoid. You still get an EGR flow code, or other EGR related code. The reason plugging it in DOES NOT work is the ecu expects to see a change when conditions call for it. If the Temp sensor doesnt show this CHANGE in temp, the ECU throws a code. What ECU are you guys using? I just dont see how you guys have no codes with just pluggin it in. Resistor wont work unless you use a resistor that varies based on temperature and shows the same resistance values the ecu expects to see.
EVAP is SIMPLE. If you have a 95 ecu, EVAP is GONE. yes plugging everything up and implementing it, also gets rid of it, but its clutter in the bay for me. As for the guy that used the 08' motor, he cheated. That motor has everything our ECU expects to see. |
Originally Posted by TJ_Max
(Post 6884748)
Same here man. So far the guys that come to me for work all have paid extra somewhere to pass inspection, and come expecting, there to be codes after its done. So I dont go the extra mile for a codeless swap, unless its a DEK, but I'm interested in the codeless setup. Much like you. Just want to know whats unnecessary, as i think I have a clear idea of what is needed. Ive gotten rid of EVAP successfully with no codes witht he medthod mentioned above. EGR, unless EGR is in place the least I can have is a P1400 on a dek swap. Im assuming the same for the 3.5. Once I noticed you could mount the EGR valve on the 3.5 and it isnt in the way of anything, I was just curious who did this. Whats it like to implement EGR into an intake manifold or engine that isnt designed for it? Reduction of combustion chamber temps have probably been achieved via means other than pumping cooler,inert exhaust gases back into the CC. So I was wondering if the EGR temp sensor just needed to see if the EGR control solenoid and valve were working based on the temp change, and send that info back tot he ECU. If thats the case I was wondering if I could just block the EGR guide tube off that would feed the manifold.
I don't think anything negative would happen if you introduced EGR into an 02-03, because 04-07 have external EGRs. if you wanna play it safe, use a 4th gen EGR coupled with a 94 intake manifold, with a custom EGR tube (maybe the stock one works, I've never tried) However, If you're looking for big power numbers, as I know you are, forego the EGR. It's a common practice of everyone in the boosted community to bypass or blockoff the EGR as a preliminary mod. Best bet would be to look at the FSM (or let me know if you need one), an see what sort of wave or signal the EGR needs to make the ECU think it's ok. Good luck, let me know if you need anything. |
(Post 6885938)
I have scanned my car 4 times since the swap and the only code I have is evap btw as for for rigging a resistor you should be able to make a pyrometer work |
Originally Posted by t6378tp
(Post 6886049)
I am running a 97ecu and the ecu does see a change in temp from the probe thats what I have it tied to the header.
Originally Posted by grey99max
(Post 6886219)
Now the 2004 and up UIMs have an EGR passage underneath the runners with ports into each runner to feed exhaust gases. You can see it in the 2004 FSM...
(Post 6885938)
He mounted the egr hardware where it was on the 3.0--this was on an '02 or '03 engine. (Even if the bolt holes aren't there for the egr bracket, you could fab something up.) As I recall, the hardware wasn't attached to the block, but the tube coming from the rear manifold held it in place. Then, he cut the egr guide tube and attached a heater hose to the end. Next, he attached the other end of the heater hose to a T-fitting at the back of the intake manifold at the brake booster nipple. This had no impact on braking, and the EGR functioned seamlessly for years (until it was removed for Hotshot headers). |
Originally Posted by tsaulz
(Post 6886450)
Tilley did it the best way, IMO, on my brother's 3.5 swap--fully functional EGR w/ no codes:
He mounted the egr hardware where it was on the 3.0--this was on an '02 or '03 engine. (Even if the bolt holes aren't there for the egr bracket, you could fab something up.) As I recall, the hardware wasn't attached to the block, but the tube coming from the rear manifold held it in place. Then, he cut the egr guide tube and attached a heater hose to the end. Next, he attached the other end of the heater hose to a T-fitting at the back of the intake manifold at the brake booster nipple. This had no impact on braking, and the EGR functioned seamlessly for years (until it was removed for Hotshot headers). ... |
Originally Posted by tavarish
(Post 6885947)
... if you wanna play it safe, use a 4th gen EGR coupled with a 94 intake manifold, with a custom EGR tube (maybe the stock one works, I've never tried)
(Post 6885947)
(Post 6885947)
(Post 6886049)
(Post 6886219)
Me too...... EGR hardware, temp probe connected, no EGR on the 2002 manifold, no EGR codes. Now the 2004 and up UIMs have an EGR passage underneath the runners with ports into each runner to feed exhaust gases. You can see it in the 2004 FSM...
Originally Posted by oldngivout
(Post 6886360)
I was going to use the 04 intake and plumb in the A32 EGR, but there was too much stuff in the way of my fuel rails.
(Post 6886450)
(Post 6887204)
heater hose is why tilley isn't around the forums anymore.
... *DEAD* I gave him the benefit of the doubt and figured he meant something else. I cant believe exhaust temps wouldnt melt a rubber heater hose. |
(Post 6887232)
*DEAD*
this thread is very interesting
Originally Posted by KRRZ350
(Post 6880159)
I used a brass 5/8" nipple since that was the only size I could find that special high-temp hose for, it was so tough to find that hose locally or online/in catalogs, I finally found some at a mustang shop. Lucky for you though (not for me) I later found out that a '96? sohc taurus v6 uses the perfect size high-temp hose for part of its egr!!! Get that hose from the junkyard, match that up with a fitting at home depot, get a tap for that fitting and woila! OK, not really. haha.
On the back of the manifold there is one spot where it is very flat and thickest. But it's by no means thick, it's very very thin, but it worked for that car. I had to use a $30 tap for his mega-sized fitting; and like the smaller fitting you will probably get; it was tapered NPT or "national pipe thread" So drill the hole (Or holes- pilot hole ftw) very carefully, than when you start tapping keep checking the fitting so it goes in good, throw some "High temp high strength loc-tite" (FYI, not all "red" loctite is "high temp") on the threads of the fitting and use care not to overtighten. Route the hose from the fitting to a hacked up egr metal piping and your done. The 3.5 heads have holes tapped for the egr to bolt up to. |
omg screw that clutter, I hate the EGR to death. It was the reason I couldnt pass emissions and ultimately one of my excuses for doing the 3.5 swap in the first place. I don't have an EGR mounted on my 02 motor w/ 95 Manual ECU although I believe I have the temperature sensor plugged in...havent seen it in awhile though now that I think about it. Anyway, my only codes are 2 for the EGR and one for the p/n switch, one for an 02 sensor. The EGR is the only one I feel like I couldnt get rid of.
luckily the CEL doesnt matter for my inspection |
(Post 6888947)
gfbvwrgbv
Looks like the EGR temp sensor has to be mounted AFTER the electronic EGR solenoid.l I still wanna know if an EGR temp sensor reading the same voltage all the time would work. Im finding out from a lot of people that some get the codes some dont.
What up Kev! |
(Post 6889590)
What up Kev! As for that rubber hose, the super duper high temp stuff is uniqe, the aftermarket stuff I got at the mustang shop was blue on the outside and had a red inside layer, the taurus stuff was black on the outside and red on the inside also I believe, but either way tracking down a taurus in the junkyard is pretty easy to do and they have alot of that hose in the perfect size, just find it's egr hose and make it functional if you are that worried, and charge extra of course. |
Werd, its not a repost though. Your thread sucked! You gotta call me sometime dude, been a minute.
Originally Posted by PharoNDmist
(Post 6899954)
Hey TJ, who in the hell engine is that?????
Smartass. Some loser's engine. |
TJ that looks like my car in the back lol but its not it looks like my twin lol
So did a 3.5 swap on someones car and have the following code with a 95 5spd ecu in a 95.
P1400 Differential Pressure Feedback EGR Circuit Low input Nothing else. One more code away from not having to pay $100+ for illegal inspections in NY. Where are you guys hangin this sensor? |
(Post 6904583)
I don't quite understand how this sensor can be tricked into sending a variable signal to the ECU, unless it can be allowed to change temperature while operating. If simply attached to the exhaust manifold, or even inserted into the exhaust stream somehow, its value would never change while operating. According to what the ECU expects, it will not always be a constant value. If I'm not mistaken, that's how it operates in the EGR guide tube. |
I know this is an old thread but most guys I know leave the sensor in between where the knock sensor would go on the 3.0 and 3.5 swap. I think this sensor is a thermistor, which would change resistance based on temperature. If this is correct then the heat from the engine would do the trick.
My question is, does the evap purge canister and solenoid need to be left connected with vacuum? I’ll see if I throw any Egr codes when my I have my car back in my possession. I have deleted EGR in Nistune using 95 ecu and 5speed swapped. |
I tied my EGR temp sensor around a fuel or evap hose.
(Post 9204695)
is your other EGR stuff hooked up? evap canister purge valve, Evap canister solenoid valve with vac lines? what ECU are you using? Im hearing guys say a 95 FED spec doesn’t monitor evap stuff and it doesn’t know it exist. But not sure how true that is, and if it’ doesn’t monitor Evap, then why still have the EGR temp sensor tied in. |
Originally Posted by maxprivate
(Post 9204697)
Hey bud,
is your other EGR stuff hooked up? evap canister purge valve, Evap canister solenoid valve with vac lines? what ECU are you using? Im hearing guys say a 95 FED spec doesn’t monitor evap stuff and it doesn’t know it exist. But not sure how true that is, and if it’ doesn’t monitor Evap, then why still have the EGR temp sensor tied in. Of the EGR system the EGR Solenoid (green one) and EGR temp sensor are left connected. All EVAP parts are still connected. Im using a 95 ECU. EGR is a separate system from EVAP. EGR feeds exhaust gas back to the engine, where EVAP feeds fuel vapors from the gas tank back to the engine. They do similar things but work independently of each other. EGR temp sensor is left plugged in because the ECU will throw a code if it is removed. I have verified on multiple ECUs that the 95 does not have EVAP monitors. The 95 had a different 'dumber' canister located in the engine bay. |
https://cimg8.ibsrv.net/gimg/maxima....3e5bf50f0.jpeg
https://cimg9.ibsrv.net/gimg/maxima....1c4f74ada.jpeg
(Post 9204702)
Hey,
Of the EGR system the EGR Solenoid (green one) and EGR temp sensor are left connected. All EVAP parts are still connected. Im using a 95 ECU. EGR is a separate system from EVAP. EGR feeds exhaust gas back to the engine, where EVAP feeds fuel vapors from the gas tank back to the engine. They do similar things but work independently of each other. EGR temp sensor is left plugged in because the ECU will throw a code if it is removed. I have verified on multiple ECUs that the 95 does not have EVAP monitors. The 95 had a different 'dumber' canister located in the engine bay. Thanks for clearing that up, I thought they were the same. Can you tell me how you have your evap canister connected and the evap canister purge control valve? I think they still need vacuum if 3.5 swapped. Included a pic of it. I’m missing the black purge control valve, I’m trying to find one. Not sure if I even need it to not throw a code. I know that green EGR solenoid needs vacuum too, I have that plugged in too. Why does Evap stuff have to be connected if the 95 ECU doesn’t monitor that? How will it throw a code if it doesn’t monitor that Evap stuff or know it exists? He ( krismax) also said he wired in 2, 100 ohm,10 watt resisters together to replace the EGR solenoid but didn’t say which one. Trying to find out from him. |
(Post 9204707)
https://cimg9.ibsrv.net/gimg/maxima....1c4f74ada.jpeg Oh I see. That’s what Krismax meant then by “having the entire EGR system in the engine bay” this is what the 95 Fed spec has then if I’m not mistaken. I’m using a 95 Fed ecu and did the Egr delete in Nistune. I have to check and see what code is coming up when I have the car back. Last time I remember it was EGT code in Nistune but I didn’t have an EGR temp sensor plugged in at the time. So I think it was that, I have that plugged in now and hanging in between the engine. Thanks for clearing that up, I thought they were the same. Can you tell me how you have your evap canister connected and the evap canister purge control valve? I think they still need vacuum if 3.5 swapped. Included a pic of it. I’m missing the black purge control valve, I’m trying to find one. Not sure if I even need it to not throw a code. I know that green EGR solenoid needs vacuum too, I have that plugged in too. Why does Evap stuff have to be connected if the 95 ECU doesn’t monitor that? How will it throw a code if it doesn’t monitor that Evap stuff or know it exists? He ( krismax) also said he wired in 2, 100 ohm,10 watt resisters together to replace the EGR solenoid but didn’t say which one. Trying to find out from him. I don't know how many times i have to say this.Ditch the EVAP and put it on your bicycle ,maybe it will work on that. And the EVAP is all in the engine bay from a 95 max. This isn't this way on a 96-99. |
© 2024 MH Sub I, LLC dba Internet Brands
