Custom intake manifold thread. Build, dyno gains.
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Since my other thread was cluttered with theory/etc, I'm making this one to start fresh.
Basic idea behind the manifold: Make a SSIM that has much more plenum volume, a 3.5" elbow with a 3.5" MAF and intake to go with it. Theory behind the 3.5" piping is to make the 3" TB act as a venturi and flow better than it normally would with 3" piping on both sides of it.
Result: This gained power starting at 3000 RPMs, all the way to redline. Made nearly 20whp peak, and right at 50whp at the 7000RPM redline.
Pictures of progress from start to finish of the "prototype"
Dyno gains versus Vias deleted stock IM and stock MAF/intake within 15 minutes of each other, same dyno, same day, same all else. The custom IM/3.5" tune could use work. It goes into the high 11s around 3500-4000, and is mid 12s otherwise. Stock manifold tune is absolute perfection. 13.5 at 3000, settling down to 13.0 by 4500 and sitting at 12.8-13.0 to redline.
Closer view on SAE smoothing 5 of the top end gains.
Dyno video:
Full dyno thread:
http://forums.maxima.org/dyno-discus...ml#post7938417
Next step is to clean and pretty it all up then have it all thermal dispersant coated (ends up black).
Dyno video:
Full dyno thread:
This one has around 80 hours in it all said and done.
Plus, as I said earlier in the thread, I have 3.5" piping in front and behind the TB in order to promote a venturi effect. It may actually make more power this way than with a 90MM matching TB.
Next question... Can I haz?
Great work man, I may end up copying you but for the 3.0, depends on how much free time I have of course (i have easy access to USIM's, since people nearly throw them away nowadays).
Pioneering is paramount in the tuning world for me. keep up the good work.
Very impressed!!
Velocity stacks welded on the runners inside the plenum as future step... like cosworth's Z33 upper IM...might find something else there...
Already uber-good gains from custom fabbing. The 5.5th gen UIM will always be impressive on a design point of view, in any ways it is used or modded (SSIM, Vias delete, sparks custom-modded...)
Very impressed!!
That is amazing. Now you just have to market it to the 350 guys.
Also, if you are making these things let me know, I wouldn't mind gaining more hp.
Very impressed!!
Very impressed!!
My biggest issue with this darn plenum is the runners being staggered. You can't really tell from the pictures, but I actually aligned the plenum and elbow at an angle that hopefully feeds both banks equally.
One day I would like to get a 350z LIM (for the much more circular runners) and make a full UIM with runners and velocity stacks included. With our LIM, it would require transitioning mandrel bent piping to the weird oval shape of our lower runners... not easy.
OK, I understand. Sometimes minor details make things go off-ballpark rather than getting it spot-on. So, making a mix between Z33 UIM details and A33 UIM design would make a well rounded final result.
thumbs up. Ill follow your thread. Great stuff.
Yeah would just be using the 350z LIM for the round runners, the actual UIM would be a single plenum box towards the back of the engine just like the stock IM is (due to hood clearance). I could make both the box and the runners much more pretty that way...
Like I've been preaching for as long as I can remember now. Plenum volume goes a long way on a bolt on 3.5. This is also the reason why an 00VI on a 3.5 WILL choke it up (compared to even a stock 3.5 IM). Maybe people will listen to me now.
Thanks for coming through with the results sparks.
I hope this stops the idiocracy of that crap about 00vi on 3.5.
I think this should also be said about the heads too. 3.5 heads on a 3.0 just isn't a good idea nor are 3.0 heads on a 3.5
I'm with you there, I always agreed with the right bolt-ons and good tuning this would be possible.
Yep... And just for some stats, this intake manifold measures around 270 cubic inches, not including the elbow or runners. That's roughly 130% more than engine volume. I did not attempt to measure the stock intake manifold, but rough estimation puts it below 200 cubic inches.
Quick question, I'm planning on making an intake setup like yours minus your new manifold of course. Would it be beneficial to use 3.5" piping on a setup w/o your custom manifold or just stick with 3"?
I'm still sticking to my theory that an '00vi properly portmatched to a 3.5 would make jaws drop, and this is why, add .5 liters & vtc to this:
That graph is tiny, can't see numbers. You would need to make 300 peak whp with a curve shaped like that to equal my 280 whp in real world conditions. It's damn near flat from 5500 to 7000, which is the main power band through the gears. Power under the curve > sharp peak at red line (unless you're a dyno queen).
A flow bench is not very effective for an intake manifold since most of the gains/losses and actual flow characteristics stem from the order of intake valves opening, resonance, harmonics of that resonance... etc. In 99% of cases, flow benching an IM is just a marketing ploy to sell it and has no real bearing on its performance. An open pipe 2" off the head would give best results on a flow bench, but I can guarantee you it would see giant power losses.
Very impressed!!
Very impressed!!
That same thought has crossed my mind as well but with a manifold that's centered in the Valley with individual velocity stacks and an Oval plenum.....But Sparks has broke new ground for us all! Jaypee what's your secret???? You never show us bottom feeders your brainiac Maxima practices that will allow us to grow and be faster.....Sparks good job no matter how we fued at times this was superbly executed......A+
I believe jay_pee's "secret" is making the right selection of mods that work well together, having a healthy VQ35DE, and properly prepping his car for the track and dyno. One thing we both have in common that not many others have is a LW flywheel, which I wouldn't have expected to give gains... However, numbers suggest otherwise.
Also weight reduction, power steering disconnected, lightweight DRs that give optimal gearing, and extremely fast no-lift power shifting are important parts of the equation. His race weight at the track is lower than most 5.5 gen maximas curb weight without a driver.
When I talked about jaypee disabling power steering, I was (obviously) referring to removing the belt. lol
yeah i drove a week straight with out power steering, and it sucks in the parking lots, but i was used to it by the end of the week.....but i dont think anyone makes a manual rack for the maxima
If you really want to delete the PS, just pull the PS belt and take off the PS pump. Good luck with that.
That was dandymax's dyno, you should know that
You can convert your rack to manual, it doesn't have the gear reduction of a true manual rack but it is MUCH better than disabled PS. You have to pull the rack & make a few modifications so you aren't fighting the fluid in the rack. http://www.flyinmiata.com/tech/depower.php
:Thumbsup: I've decided I'm moving down south next winter, we've been having highs of 25-30* & lows of 10*.
On the back plate, how did you make the radiused hole.
Underneath the piping in this pic, middle right:
