1 Attachment(s)
I'm seeing what's going on here.
And I like it. Proceed. |
x2 looking good
2 Attachment(s)
Thanks guys. I'm also looking into coating the headers with one of these: http://www.vhtpaint.com/products/flameproof/ or http://www.ebay.com/itm/370730995856
Right behind the flex is a Vibrant 3" ultra quiet resonator. I'm looking forward to see how this affects the drone zone. Attachment 62039 Attachment 62040 |
2 Attachment(s)
Almost done, just need to weld in the o2 bung, hanger, and then coat it. I'm really happy with the way this one turned out.
Attachment 62027 Attachment 62028 |
nice
(Post 8720309)
https://i.imgur.com/293tF6k.jpg https://i.imgur.com/5UvNhWQ.jpg Finally!!!! somebody else who's not cheap and actually using v-band flanges on their headers :) love not having to change gaskets/re-rtv the 3-bolt flanges every 3 months. I totally approve, and looking forward to that quiet resonator too. |
@schmellyfart, was wondering, I'm limited in my knowledge of header theory so bare with me. We all know the 3" catback makes more power, however i guess you're basically making a stepped header to meet your 3" catback, was wondering though......what do you think about the following?
just as how you used the 2.25" pipes for the "y", my theory suggests each pipe from primary is stepped 1/8th at a time so three primary 1.75"/(1 6/8) pipes when stepped merges to (2 1/8 i.e. 1 6/8 + 3/8) however the common pipe one size up is 2 1/4(2 2/8) so thats satisfactory, for two (2 1/4) pipes to merge and maintain velocity it would step up by 2/8 so it would be 2 4/8 or 2.5. that would be a upgraded choke without having a drastic shift in exhaust volume and velocity meaning going directly to 3". so right from the 2-1 merge a 2.5" to 3" transition cone could be used. so its not to knock your setup but just a silly whymsical thought that i had. meaning i see cattman's with exhaust cutout put down numbers and they have a 2.5 choke/final merge of two pipes before catback |
Nice Job. That's plenty far from the LCA, much easier to swap out than cattmans, and it would clear a 3.5 drain plug if you went that route.
Originally Posted by vipervadim
(Post 8721058)
Originally Posted by Hadou-kai
(Post 8721538)
just as how you used the 2.25" pipes for the "y", my theory suggests each pipe from primary is stepped 1/8th at a time so three primary 1.75"/(1 6/8) pipes when stepped merges to (2 1/8 i.e. 1 6/8 + 3/8) however the common pipe one size up is 2 1/4(2 2/8) so thats satisfactory, for two (2 1/4) pipes to merge and maintain velocity it would step up by 2/8 so it would be 2 4/8 or 2.5. that would be a upgraded choke without having a drastic shift in exhaust volume and velocity meaning going directly to 3". so right from the 2-1 merge a 2.5" to 3" transition cone could be used. so its not to knock your setup but just a silly whymsical thought that i had. meaning i see cattman's with exhaust cutout put down numbers and they have a 2.5 choke/final merge of two pipes before catback I would have to use a different merge collector in order to retain the vibrant resonator, and I've become quite fond of this flowmaster merge.
Originally Posted by 95naSTA
(Post 8721541)
I used 3.5 upper and lower pans on my 1st gen 3.5 hybrid swap with a 3.0 CPS. The lower pan has the drain plug pointing to the rear.
2 Attachment(s)
Interesting, I see there's conflicting info on the two guides on VQPower
Attachment 62011 Attachment 62012 |
I know the guides say that but I for sure ran the 3.5 upper with a 3.0 CPS. The 3.5 CPS hole is larger and the 3.0 sensor had play to clock a few degrees either way before you tightened down the 10mm. If the sensor was clocked wrong or loose, it would intermittent hard start. But with the sensor where it should, no problems. This was with a '03 auto max 3.5 upper oil pan.
Oh ok that makes more sense. Thanks for the info!
(Post 8721549)
I have hotshot headers on mine (anyone else still have Hotshots??), I never liked the 3.5L lower drain spot, so i reused my 3.0L lower oil pan with 3.5L swap. (i did use the 4AT 3.5L upper oil pan and spliced in the 3.5L CPS to the 3.0L sub harness, I did not use the 3.5L 'oil cooler' since it's more like an oil warmer if anything -- using 200* coolant to cool the engine oil?? no thanks.. with the oil warmer it doesn't clear traction bars [anyone here use traction bars?]) I don't even take off the tire when changing oil, just drive onto a curb with the pass front tire and i have all the clearance i need :cool: |
More pics :) I removed the cat 'section' so this bolts straight to the catback.
http://www.flickr.com/photos/schmellyfart/8448795121/ http://www.flickr.com/photos/schmellyfart/8448795117/ http://www.flickr.com/photos/schmellyfart/8449879752/ |
your y-pipe is what size now 2" or 2.25"?
2.25" into 3"
How much $$$ do you have into this final setup? As in, if you had built the headers and y-pipe this way from the start.
Andy |
http://img62.imageshack.us/img62/3664/collectord.jpg
Schmelly this is the type of collector I was thinking about, raceprovenparts on ebay is selling two for $83 shipped. its used but its stainless steel. I love shopping from the v8 crowd because buying the same style true merge 2-1 collector is $100 a piece elsewhere |
take note of the choke and transistion cone. Thats the idea i was refering to.
Mmmmm, that's not so equal length though :(
Originally Posted by ABIGBRAIN
(Post 8722031)
Andy eBay Altima headers: $135 (they are now about $220 on eBay) SS o2 bung: $8 Mandrel Bending Solutions 2x 2.25" SS Vband clamp & flanges: $84 shipped Amazon Vibrant 3" Ultra Quiet resonator: $94.80 ( I only paid 67.91 after rewards points) Flowmaster Merge Y214300S: $53.99 ( I got it for free after rewards points) SiliconeIntakes.com 2 x 2' Extra Thick Stainless Steel 180° Bend, 2.25" (SIL001637) = $47.98 1 x 3.0" Stainless Steel Exhaust/Intake Flex Section - 6" Long (EXH000868) = $17.99 + $18 shipping My Total: $378.87
(Post 8722045)
Originally Posted by aackshun
(Post 8722069)
Good to see people modifying them to fit. Always need people to experiment!
Now the question is whether the larger piping will actually nets gains, I'm not too sure right now. |
The cell phone mic can't handle it, but here is a vid nonetheless.
Sound clip under load.
(Post 8721859)
http://farm9.staticflickr.com/8217/8...9410d2f9_b.jpg http://farm9.staticflickr.com/8076/8...d4a275b5_b.jpg http://farm9.staticflickr.com/8375/8...7d1363c3_b.jpg http://evilengineering.com/gallery/d...r-troopers.jpg Good Sh1t Man...:ben: |
(Post 8721603)
Cattman headers that have the skid plate are really bad with the 3.5L lower oil pan. The location of the 3.5L drain plug drains the oil right onto the skidplate (hot headers + engine oil = bad smelly combo)
I have hotshot headers on mine (anyone else still have Hotshots??), I never liked the 3.5L lower drain spot, so i reused my 3.0L lower oil pan with 3.5L swap. (i did use the 4AT 3.5L upper oil pan and spliced in the 3.5L CPS to the 3.0L sub harness, I did not use the 3.5L 'oil cooler' since it's more like an oil warmer if anything -- using 200* coolant to cool the engine oil?? no thanks.. with the oil warmer it doesn't clear traction bars [anyone here use traction bars?]) I don't even take off the tire when changing oil, just drive onto a curb with the pass front tire and i have all the clearance i need :cool: schmelly that y looks fantastic, did my hot shot measurements help at all? It's not fully equal but better sounding than it just going straight into the collector like bolt on y pipes. When you get time grab a nice cam and make a nice video, sounds pretty mean though |
I totally forgot about those. lol I think I was using them before I ordered the piping, so yes they helped.
Free time and a nice camera? Maybe in a few years hahah. |
yo, I so like the sound has more of 350z/G35 tone to it.
(Post 8726739)
well, after all these compelling arguments and some nice sounds scmelly i'm sticking to another warpspeed y cause i don't have a shop around here that can do all that and money's tight. i would however like to do a different cattback and was wondering what you have cause i really did'nt read all the data you posted. it's early and i'm tired so i was thinkin about a flowmaster 40 with the monza resonator and b pipe i already have, thoughts? seen some vids, sounds ok to me.
(Post 8940236)
© 2024 MH Sub I, LLC dba Internet Brands
