Ranma's 2002 Nissan Maxima build
Decided t take Roc's suggestion and do a post about my progress on my engine build. This is for a 2002 Nissan Maxima SE 6-Speed. At this point I have Cattman headers, fast cat, 3" catback exhaust, from the headers to the muffler is ceramic coated by JETHOT, Stillen UD Pulley, NWP Spacers, and NWP BOP. I also have fidanza flywheel and SPEC Stage 2 Clutch.
Suspension: Eibach Pro Kit Springs, Tokico Blue shocks, FSB, ES Shifter bushings, control arm bushings and subframe and motor mounts. What I plan on doing now is getting a custom intake Manifold from SFR and getting the elbow made to fit the 2009 Maxima TB. The 09 Maxima TB is 75mm and stock 02 Maxima TB is 70mm. To do this I had to order a 2009 engine harness because the connectors on the 09 TB are totally different from the 02 TB. Tomorrow I am going to cut the pigtail off the 09 harness and use the 09 and 02 Maxima FSM's to wire them up correctly to test the 09 TB. I also plan on using the 90mm LRMAF and 3.5" intake piping with an AEM filter and V stack! I plan on tuning using the 350z Haltech Platinum Pro. It's getting late and I need to go to sleep...I'll report more later but here are some pics: SFR Custom Intake Manifold: http://www.speedforceracing.com/publ...n0026b_enl.jpg 350z Haltech platinum Pro: http://www.speedforceracing.com/publ..._1a387_enl.jpg 09 TB and LRMAF: http://farm7.static.flickr.com/6052/...d5a9b7baf5.jpg LRMAF outer Diameter: http://farm7.static.flickr.com/6118/...803164b9ba.jpg LRMAF connected to 09 TB: http://farm7.static.flickr.com/6230/...aca485b479.jpg 09 Engine Harness(thanks to aackshun): http://farm7.static.flickr.com/6051/...e6bb07b799.jpg 09 TB pigtail: http://farm7.static.flickr.com/6102/...c24b776c78.jpg Plan to have everything installed, dynoed and tuned by Mid November......we'll see how much hp I'll make!! Hoping for about 280hp.... |
What is this??? Maximas are being really tuned these days?!?! 90mm OD AFMzzz??!!! THIS IS MADNESS :run:
In for updates.
What have you purchased already? |
Originally Posted by Shift_Max
(Post 8232817)
In for updates.
What have you purchased already? Going to order this week: SFR custom Manifold, 350z Haltech Platinum Pro wired up for PnP for Maxima. Then I'll need to find a gasket for the 09 TB and get a stock 02 Gasket for where the lower mani and upper mani connect. Wont be able to close the hood using NWP upper mani spacers there. I believe it will still fit using the NWP lower spacers though, they are not as thick. Once I get the manifold in hand then I can start to measure for the 3.5" intake tubing. |
I approve! hahah nice man!
Originally Posted by ranmas2004
(Post 8232828)
Unless it's just THAT big where you can't even reasonably do that... |
Originally Posted by aackshun
(Post 8232861)
Use nuts (or washers) to space the hood out accordingly.
Any idea what the actual volume on that IM is, or at least in relation to the stocker?
Originally Posted by NmexMAX
(Post 8232929)
(Post 8232867)
I will see if I have the clearance. I know 1swtmax has this manifold and he told me with the spacers he could not close his hood so he ended up getting an aftermarket vented hood. Tim from SFR said not to use spacers because there is already enough plenum volume and runners are longer so I really don't think I'll need the sapcer there, who knows. If I don't need it I will just sell the 3 piece NWP spacer kit (TB, elbow and uppermani) with my stock 02 intake. I think I'll be able to get something for it!!
ALso one mooorreee tinngggg... more air = moar fuel.... I have stock 09 injectors here w/ 7k miles on em... just sayin :cool: |
(Post 8232789)
What is this??? Maximas are being really tuned these days?!?! 90mm TB'z??!!! THIS IS MADNESS :run:
Q45TB is 90mm... |
Originally Posted by McSteve
(Post 8233037)
?! I thought he said the 09 TB is 75mm vs the 70mm stock....
Q45TB is 90mm... |
(Post 8232940)
No such thing as having too much air for a VQ35.
(Post 8232929)
---------------------------------------------------------------------------- OK I finally got the 09 TB wired up just to test and see if it works, IT DID!! I thought I recorded a video of it but somehow it did not record. So I'm not going to take all that electrical tape BACK off again and re-connect the 09 TB just to re-record, forget it! Man was I pissed :mad: Next time make a note to actually CHECK the video before I put everything back. You'll just have to believe me...lol. I did get some pics though: 09 TB connected: http://farm7.static.flickr.com/6094/...f3c3048cb2.jpg Labeled 09 TB pigtail: http://farm7.static.flickr.com/6173/...e891f6d175.jpg I also placed the order with SFR for the intake manifold, Haltech, their custom engine cover and they will powder coat the manifold and engine cover with a polished coating...similar to the JET hot coating on the exhaust! I can't wait. I also have to mail them the 09 TB so that they can match it up with the new IM. I need to find a place around here that can just do a base dyno...want to know how much I'm putting down now and compare it with later! |
(Post 8233157)
What's their flow rate @ 3.5 bar??
http://www.m2race.com/product_specs.asp?ID=65# |
(Post 8233406)
Dunno but I'm going off of this (compare it to OTHER "high performing" motors), and other things other N/A-Samas have told me.
(Post 8233408)
VQ35 engines have TONS of potential! I seen a dude on the 350z forum with a custom manifold, 90mm TB, and 3.5" piping with nismo cams, headers full 3" exhaust and a tune make 327whp!! No head porting, no high compression pistons, STOCK motor, only NISMO cams. 327hp!! Imagine if he got heads ported, and some higer CR pistons and some more aggressive cams! Don't forget SPARKS made 285hp with NO CAMS and a stock TB!!! TONS of potential in these engines!!!
Originally Posted by shrek
(Post 8233443)
that "dude" is Sasha Anis from SG motors...they have the record for stock block HP....they later got higher C.R. and other stuff and i think they got 346 HP
Even though the curves are godawful, the peak #'s are there. |
(Post 8233463)
This.
OK...today setup a DYNO appointment, NO TUNE, just to see what numbers I'm putting down for Monday at 430pm!! I'm thinking probably about 240hp un-tuned, we'll see. I will post the dyno sheets later that day.
In other news I mailed off the 09 Maxima TB to Speedforceracing today so they can match it up with the manifold and the AEM filter came with the BIG 6" opening today, this thing is massive! Now I'm waiting for the V-stack from BPI: http://farm7.static.flickr.com/6225/...97a9f7f473.jpg http://farm7.static.flickr.com/6163/...63fceb7b0f.jpg |
1630 = FTW..
Detail's... Dynojet? Mustang? :Popcorn: |
(Post 8235189)
1630 = FTW..
can i ask...how much did it cost ?? i want to get one to do my 3.5 intake with q45 maf on 4th gen ECU :D
(Post 8236769)
http://www.bpinitiatives.com/stacks.php |
Well went to Advanced Auto and finally bought an OBD II Scanner because it's the 4th time I went up there asking them to check the SES light that I throw messing around with my car. So I figured I'd just buy one to avoid having to go there all the time. It's not Cipher but it'll do.....
http://farm7.static.flickr.com/6167/...2ede0e95a4.jpg Tomorrow is the BIG DYNO DAY!!!! Can't wait!!! |
OBD II great to have handy.
OK FINALLY got the DYNO BABY!!! I was SHOCKED the car made so much power.....I was thinking 240hp.....but NOT 259hp!!
MODS: Cattman Headers, Fast Cat, 3" catback exhaust, Stillen UD Pulley, NWP Spacers, Custom Short Ram intake, AEM filter w/ BPI Vstack....NO TUNE! http://farm7.static.flickr.com/6238/...fbbf6f1d_b.jpg Run 1: 256hp & 250 ft-lbs. Run 2: 258hp & 249 ft-lbs. Run 3: 259hp & 251 ft-lbs. Run 4: 256hp & 247ft-lbs. Got videos of the runs too......they just taking all day to upload on youtube and I will post them later. The guy told me with a tune I would make 280hp easy. The tuner said the car took a SHIZNIT around 5200rpms and that was hurting the power AND that is NOT including the LRMAF and 3.5" intake tubing OR the custom manifold with 09 Maxima TB. I probably would be close to 290ish with all that!!! The tuner there is named STEVE and he is a master at Nissans. I spoke with him about my plans to sleeve the engine and bore it out and everything. He told me that if I decided to go turbo they can make me a custom system and I can boost 6 PSI and I would get 360 hp easy with a tune on a STOCK motor and would not have to touch anything. He also tole me I can run 8 PSI daily too and that would push me close to, if not, over the 400hp range. He said they can custom design a system that would work with the Cattman headers and it would go really good with the custom manifold I'm getting. He said making a custom turbo would cost about HALF of what I would spend building an ALL MOTOR car and it would give me about twice the power and be totally reliable. He told me that they design and build turbos for 350zs, Altimas, G35s....etc. He told me that he could get me a smaller turbo so it would spool up quicker and it would be good up top as well and that way I can have more fun driving it around as a daily driver......SOOOOOOO TMEPTING!!!!! |
Seeing all these threads, I'm starting to feel really confident when I finally start building mines. Good job :thumbsup:
Nice numbers.
:Popcorn:On board, keep the updates coming.
Whats up with that plateau at 5k rpms?
I bet a map of the AFR/Timing table will tell the tale
OK thanks to a fellow Maxima org member I now know how to embed the video.
Here is a video of the last 2 runs, cool down was about 15 mins from the last run: Man she sounded soooo good!!! |
(Post 8239203)
Originally Posted by essential1
(Post 8239636)
Stock cams + stock IM = that plateau
Cant wait to see the results. Any ETA?
(Post 8240011)
Very nice work. Impressive numbers and the car sounds great. Can't wait to see what she puts down with the manifold / Haltech.
Any idea what your SAE corrected numbers were? Also, were those runs in 3rd or 4th gear?
| All times are GMT -7. The time now is 01:43 AM. |
