02 FWD VQ35DE Block + 2008 G35 VQ35HR heads Test fit, discussion, BUILD?
Here SurraTT comes with some more STUFF :D
I still have my old FWD VQ35 block laying around (191k miles) And i just picked up a set of 2008 G35 HR Heads complete with valvetrain and valve covers. Here is the good stuff, HR heads on my old DE block http://i173.photobucket.com/albums/w...IMG_BLOCKS.jpg If anyone remembers before i tested a HR lower intake on my 09 motor it didnt fit because the HR DECK height is different this throws stuff off. OK so who cares about the HR lower anyway? not me More like 2009 Maxima Lower So i took the lower intake off my 09 motor thats in my car, yeah it was a little work but turns out it was worth it! http://i173.photobucket.com/albums/w...116_173855.jpg What does this mean? Well confirms that 09 maxima heads are HR heads minus the nice valetrain. What else does this mean? Im not really sure more investigating needs to happen but so far this could be nice. Will have to use a 09 Max timing cover, might just try and find one of these.... Pic of my 5.7 gen just to show the lower i/m is gone, and the 09 max motor is still in there hahaah http://i173.photobucket.com/albums/w...116_173934.jpg Ideas??????? |
aackshun
hook me up with a 09 max timing cover |
Dun dun dun.
Need to really take a look at coolant, and oil flow stuff. This is just a preliminary. Because im sure no engine design builder person haha
AWESOME discovery.
Once new gen VQ's start blowing up and get common/cheap - this'll be waaay more cost-effective than head porting and intake/valvetrain upgrades for 5.5's and full swaps. |
Originally Posted by bamboomerang
(Post 8332321)
AWESOME discovery.
Once new gen VQ's start blowing up and get common/cheap - this'll be waaay more cost-effective than head porting and intake/valvetrain upgrades for 5.5's and full swaps. Only thing is gotta use a 09 timign cover, and its just not been tested enough yet to know how this is gonna work. My theory is its bascally creating a 09 maxima motor. But with the older block. |
Wow neat man! What year is block?
Originally Posted by Maximeltman
(Post 8332357)
juu gotz some time on ur hands...
Interesting.
But what about the 09 Maxima timing cover having variable exhaust timing? Youll need an ECM from an 09 to control the exhaust timing right?
mind=blown
Well we had confirmed that the L32 heads had the HR part number and that any fitments issues would be attributable to the taller HR deck height and greater distance between the heads. And the valvetrain between the two should be the same. Maybe you're thinking of the 2009+ VHR with VVEL?
In any case, good stuff man. Good to see them actually put together to be the final confirmation. BTW, which cams are installed there in the HR heads? From what I recall the cam trigger wheel is different on HR cams so how are those with DE ECU's running them? |
Originally Posted by nismology
(Post 8332930)
In any case, good stuff man. Good to see them actually put together to be the final confirmation. BTW, which cams are installed there in the HR heads? From what I recall the cam trigger wheel is different on HR cams so how are those with DE ECU's running them? The valve springs and cams are RWD specs, as in better. HR cams are different then 09 max cams, just more aggressive. Yes RWD HR cams are in these heads, the signal is going to be the same exact issue as my 09 max motor swap. Nothing new there, (well for me anyway) . So My theory seems to be dead on. 09 Maxima motor is a DE BLOCK, HR heads, (even EVT like HR) with a FWD style Timing cover that has EVT also. Its "de tuned" through less aggressive FWD cams, and a single TB. What im trying to figure out is if you can take a OLD FWD DE, use RWD or FWD "HR" heads, use a 09 max timing cover and components. use 09 max intake manifold system all that will = A 09 maxima motor like i have. Would be perfect time to do a minor build. |
Ahhh.....
HR Heads vs. DE heads comparison? I can always throw this into my build for :lol: because the mech still hasn't started on my motor yet.... Then.... I would need a 09 Maxima LIM+UIM.... oh boy this can get more expensive really fast.... |
Originally Posted by SurraTT
(Post 8332959)
Originally Posted by aackshun
(Post 8333136)
Ahhh.....
HR Heads vs. DE heads comparison? I can always throw this into my build for :lol: because the mech still hasn't started on my motor yet.... Then.... I would need a 09 Maxima LIM+UIM.... oh boy this can get more expensive really fast.... HR heads = " better flowing then the ported DE heads" I havent really seen any info on ported HR heads, i can only imagine they would be pretty nuts! And ive got a spare set :D:D Yeah youd need 09 max OR 07 altima LIM+ upper. It just depends on parts availability really, if you can by a 09 max motor for ~2g or build one for ~800-1200 depending. Then thats that or its a good time to UPGRADE some parts, cams/pistons/rods And if you DIDNT care about EVT then the 07 altima timing cover could be a option. |
(Post 8333199)
I havent really seen any info on ported HR heads, i can only imagine they would be pretty nuts! And ive got a spare set :D:D Yeah youd need 09 max OR 07 altima LIM+ upper. It just depends on parts availability really, if you can by a 09 max motor for ~2g or build one for ~800-1200 depending. Then thats that or its a good time to UPGRADE some parts, cams/pistons/rods And if you DIDNT care about EVT then the 07 altima timing cover could be a option. But this is very interesting... We will see later in the year when I'm feeling frisky for another 3.5 (maybe I can finally get the L32 altima motor + haltechzorz). Keep doing all of the great research, that way I'll have to do none :D when it comes to my fun. |
(Post 8333234)
You know I don't care :D
But this is very interesting... We will see later in the year when I'm feeling frisky for another 3.5 (maybe I can finally get the L32 altima motor + haltechzorz). Keep doing all of the great research, that way I'll have to do none :D when it comes to my fun. haha yeah thats y you like the Alti VEE Q. ohhh yeah! ill keep playing around! I wish work where you do! They dont let you play do they? hahaah |
(Post 8333199)
And if you DIDNT care about EVT then the 07 altima timing cover could be a option. Pshaw, get an 07 alti motor (almost new) for 1200 then profit??? :) I wanted to go that route, since I can get the motor for a decent price, but with the cam sensor and crap being different... :( Unless you plan to make some custom drop in parts :P |
(Post 8333649)
I wanted to go that route, since I can get the motor for a decent price, but with the cam sensor and crap being different... :( Unless you plan to make some custom drop in parts :P Yeah if your wanting a drop in, like i done with my 09 motor thats a good way to go. But if your wanting to do a build also then this might be good too. Yeah im on it for some parts, esp since i'm the 5.7 gen creator and all ya know? hahah i'm just veryyyy slow, wiring is my thing, not custom machined parts. |
(Post 8333659)
Found a 09 maxima motor for $950.... this may be covered already but if one was to messwith the cams in the 07+ alti or 09 max motor, what cams would be ideal? AM DE cams or HR cams andwhich would be less complicated?
(Post 8333972)
Ask for pictures of the car it came out of, then ask why does a car w/ a higher stock # and unreported miles is at a higher price. |
I think I have the 09 Maxima engine bug! I would love to build one for my 92 Maxima. :) Any updates on fitting the 09 timing cover on an old VQ35DE block with HR heads?
Originally Posted by Aaron92SE
(Post 8637198)
Need a 09 Timing cover setup to really see how things fit. I think the older block, with HR heads and newer HR style FWD timing cover will work just fine. I'm really wanting to see what a built 09 motor can do, ive got some parts together but its still a long ways out for me. |
(Post 8637396)
I think the older block, with HR heads and newer HR style FWD timing cover will work just fine. I'm really wanting to see what a built 09 motor can do, ive got some parts together but its still a long ways out for me. I wouldn't mind going the route you talked about in this thread. It should save me some money. I can easily start with a FWD DE short block and build it from there. Or I can try to find a cheap 09 Max engine. One that would require a rebuild anyway. There's just not many of those engines out there just yet. I think I would prefer to start with an 09 engine if I can find one for under $800. Right from the start, I would have all the pieces I need as far as timing chains, cover, sensors, etc. |
Interesting thread!
As we are talking about cams I would love to see what some really aggressive cams would put down in a 09 engine. That other guy put down what like with 320-330 with a 'dumb' 02/03 block and C9 cams? |
What are the compression ratios of a DE, HR, and 09 max motor? So If I wanted to run a RWD HR enigne in my DE G35, I could use the maxima intake setup to run single throttle body.
DE bottom end will not rev as high as a HR though. |
Originally Posted by CLyons0203
(Post 8637814)
DE bottom end will not rev as high as a HR though. 14.0 showed 0 gains on the dyno supposedly. Just increased engine response. I think you would have to get to 16 or greater to see any gains which means racegas or E85. the DE bottom end revs out to 8k just fine...If you race and play in the 8k range alot it probably will not last but for 1/4 mile & highway runs you should be ok. |
Originally Posted by FastnFuriousMax
(Post 8637858)
They are all pretty close. Unless you do a crazy high compression build you will not gain 1 hp.
(Post 8640757)
Who did 14:1 CR with minimal gains? Is there a thread about that build somewhere?
"At this point we built the block with high compression pistons, switched to race fuel and installed eagle rods. Surprisingly the compression difference did not affect the engine output at all, but at least now I would safely be able to rev the engine above 8000rpm. The next step to make more power, and to rev higher, was to swap out to the revup lower intake manifold. This manifold lost torque at lower rpm, but gained horsepower higher up." Unless I am mistaken they were at 14:1 It's somewhere on their webpage... again a stock 02/03 max block hit 330 at the wheels...his proof + SG makes me think you just need crazy aggressive cams NA. |
(Post 8640797)
Actually 0 gains: http://www.sg-motorsport.com/?p=1110
"At this point we built the block with high compression pistons, switched to race fuel and installed eagle rods. Surprisingly the compression difference did not affect the engine output at all, but at least now I would safely be able to rev the engine above 8000rpm. The next step to make more power, and to rev higher, was to swap out to the revup lower intake manifold. This manifold lost torque at lower rpm, but gained horsepower higher up." Unless I am mistaken they were at 14:1 It's somewhere on their webpage... again a stock 02/03 max block hit 330 at the wheels...his proof + SG makes me think you just need crazy aggressive cams NA. http://my350z.com/forum/na-builds/48...comp-time.html |
(Post 8640923)
Yeah, SGM had 12:1 JE pistons for that run. They did run race fuel, but I don't know if he retuned his entire ignition timing map based on the new CR with race fuel. According to the thread below, the only thing that was changed between the two dyno runs were the pistons, rods, race fuel, and racing spark plugs.
(Post 8640931)
Are you ever planning on running more aggressive cams? What are you putting down now in your 3rd gen?
Right now, I'm putting down 275whp SAE corrected and 290whp uncorrected in cold weather. My next dyno session will probably show I'm doing about 285whp now with my tuned 3.5" MAF and new converter. But I want to have an 09 Max VQ35 in my 92 that puts down over 340whp NA easily! And that will most definitely involve some big cams from JWT, headwork, custom IM, and huge TB! And it will probably involve higher compression, as well as, a 100mm bore. I'm not sold on the high compression just yet. Right now, I'm thinking I can get an extra 15whp with 13:1 CR and a race fuel tune. But I don't know. I can't find any good testing results that anybody has done. |
race fuel gets expensive! can you just run straight E85 or a mix?
Any plans to move up to a 4'' intake? Sounds like you got some serious stuff going on! 340whp in a gutted 92...what a blast to drive! |
(Post 8640960)
Any plans to move up to a 4'' intake? Sounds like you got some serious stuff going on! 340whp in a gutted 92...what a blast to drive! And I do have plans to test a 4" intake tube. But I want to do before and after dyno tests on my 92 Maxima first with the 3.5" tubing. Once I confirm those HP gains to myself, I will then see what the 4" tube does on this engine. We have confirmed it to work on the 09 Maxima motor testing on Darren's car. But, I don't know how it will respond with my older VQ35DE. |
(Post 8640944)
I have to finish testing these prototypes Edge Racing Torque Converters. Right now, I have what I think is the world's only and first 245mm high stall converter for a Nissan. I hope it will give me a stall of around 4500rpm. I hope to test it out within the next few months.
Right now, I'm putting down 275whp SAE corrected and 290whp uncorrected in cold weather. My next dyno session will probably show I'm doing about 285whp now with my tuned 3.5" MAF and new converter. |
Originally Posted by ABIGBRAIN
(Post 8640980)
Does Edge need any other testing mules? I am down for 3500-4000 stall.
And once our testing is complete, these 245mm converters will be made available for purchase more than likely. |
Aaron, I will pm you tomorrow as I don't want to further hijack SurraTT's thread. Suffice to say that given our current difference in HP, this same converter that your hoping for 4500 RPM with would be between 3800 and 4000 for me. Any anti-ballooning plate in this prototype?
© 2024 MH Sub I, LLC dba Internet Brands
