2k2 6 Speed Transmission Fix/Upgrade (picture heavy)
Disclaimer: If you attempt any of what you see from my post, you do so at your own risk. The following is a summary of my experience.
The Car: 2002 Maxima SE Transmission: 6 speed, HLSD, RS6F51A Mileage: 174,000 mi. (approx.) Situation: November 1st, 2014. I jumped in the Maxima, running late to a funeral in Tennessee. Pushed clutch to floor and started it. I could not get gear shifter out of third gear no matter how hard I tried. Something was obviously broken in the transmission. After a lot of online research, I purchased a 29,066 mile 6 speed, HLSD transmission from a 2006 Nissan Sentra Spec-V (p/n RS6F51H) from http://car-part.com/. Kindly gentlemen cargo shipped it from a junkyard in Arkansas to my door step in North Alabama for $XXX (will update when I remember it). The following were the only differences in the two transmissions: (1) bellhousings were different, (2) final drive ratio were different (3.812 vs 4.133), (3) Maxima – 1st & 2nd gear dual synchro, SpecV - 1st gear dual synchro, 2nd gear triple synchro. To Do List: (1) DOCUMENT EVERYTHING WITH PICTURES!!! (2) On RS6F51H transmission, swap to Maxima bell-housing (3) On RS6F51 transmission, swap out SpecV final drive for Maxima final drive (4) While I’m at it, install Fidanza Lightweight Flywheel and RalcoZ Lightweight Underdrive Pulley Resources: MT.pdf http://www.nicoclub.com/FSM/Sentra/2006_Sentra/ http://www.nicoclub.com/FSM/Maxima/2002/ Sentra SpecV Transmission As Received: https://www.dropbox.com/s/fsilxcvgrf...ved1.JPG?raw=1 https://www.dropbox.com/s/vin8md02tq...ved2.JPG?raw=1 https://www.dropbox.com/s/8c2daywvtx...ved3.JPG?raw=1 https://www.dropbox.com/s/k5kx6kgczm...ved4.JPG?raw=1 https://www.dropbox.com/s/vdl8ionzs1...ved5.JPG?raw=1 |
Work Setup:
- Set each transmission on cardboard covered work bench side by side (cardboard to protect mating surfaces on transmission and soak up any grease/oil/fluids) - For fasteners, blow up and print out FSM pages and glue to cardboard. Poke fasteners through on board where you take them out of transmission - Take off parts from each transmission at same time, label in Ziploc bag - For large parts, label and place in its own cardboard box - Clean as you go (scrape off gasket material, use acetone/cloth) to clean - Follow both factory service manuals for breakdown/buildup Maxima https://www.dropbox.com/s/99uhviscdr...ion1.JPG?raw=1 https://www.dropbox.com/s/hmthqwkt24...ion2.JPG?raw=1 https://www.dropbox.com/s/knbkc4gmfl...ion3.JPG?raw=1 https://www.dropbox.com/s/v20amqvmo7...ion4.JPG?raw=1 SpecV https://www.dropbox.com/s/qkhgd23qv6...ion1.JPG?raw=1 https://www.dropbox.com/s/lefsq4espf...ion2.JPG?raw=1 https://www.dropbox.com/s/vzbyk6om72...ion3.JPG?raw=1 https://www.dropbox.com/s/bmp0rvrss8...ion4.JPG?raw=1 |
Maxima – Reverse Tilt Mechanism Removed
https://www.dropbox.com/s/rw2x53qbna...ved1.JPG?raw=1 https://www.dropbox.com/s/vsdsjjovtb...ved2.JPG?raw=1 https://www.dropbox.com/s/897x6nli4j...ved3.JPG?raw=1 Maxima – Re-test fitting reverse tilt mechanism (to make sure I understood its reassembly) https://www.dropbox.com/s/eavw2qgfzm...ing1.JPG?raw=1 https://www.dropbox.com/s/j5heqxbhly...ing2.JPG?raw=1 Maxima – Reverse shift fork and rod https://www.dropbox.com/s/r0e2i2gbvz...0Rod.JPG?raw=1 Maxima – Reverse Gear Stack https://www.dropbox.com/s/gxrsx28i7f...tack.JPG?raw=1 Maxima – Re-test fit reverse shift fork https://www.dropbox.com/s/906feobna4...0Fit.JPG?raw=1 Maxima – Shifter bracket Detail https://www.dropbox.com/s/irb6n6w85l...ail1.JPG?raw=1 https://www.dropbox.com/s/yy6er4y1e2...ail2.JPG?raw=1 https://www.dropbox.com/s/88zxymc36p...ail3.JPG?raw=1 |
Maxima – Gear Stacks and Differential
https://www.dropbox.com/s/66p8c1pk6b...ial1.JPG?raw=1 https://www.dropbox.com/s/wcwqifh0w8...ial2.JPG?raw=1 SpecV – Gear Stacks and Differential https://www.dropbox.com/s/ewba0hb8ci...ial1.JPG?raw=1 https://www.dropbox.com/s/mal3cq5hnn...ial2.JPG?raw=1 Maxima – Input, Main, & Reverse Shafts and Axels https://www.dropbox.com/s/zy0folzxk0...xels.JPG?raw=1 https://www.dropbox.com/s/4phc4ylh41...aft2.JPG?raw=1 Maxima – Final Drive & HLSD https://www.dropbox.com/s/iu6z0aijjm...HLSD.JPG?raw=1 https://www.dropbox.com/s/bras8cxvwv...LSD1.JPG?raw=1 SpecV - Final Drive and HLSD https://www.dropbox.com/s/jlqfv2uizh...LSD2.JPG?raw=1 https://www.dropbox.com/s/bwelrzea5o...LSD3.JPG?raw=1 https://www.dropbox.com/s/tc1sr1agop...LSD4.JPG?raw=1 https://www.dropbox.com/s/jss3yd7u80...LSD5.JPG?raw=1 SpecV – Reverse Gear Set https://www.dropbox.com/s/yaixkkn2v1...Set1.JPG?raw=1 https://www.dropbox.com/s/6u1yoqpukh...Set2.JPG?raw=1 https://www.dropbox.com/s/d90uiwqiae...Set3.JPG?raw=1 |
Assembly tomorrow. That's all for today.
Originally Posted by 6spd_Hayes
(Post 9113672)
Well crap. None of the pictures worked. I'll have to figure that out tomorrow.
(Post 9113705)
Nice! I would like to have spec v final drive and use that custom longer 6th gear that someone had made. Maxima final drive is too long, but spec v 6th is too short with its final drive.
Picture links are all fixed. Let me know if anyone has any questions.
New Upgraded Transmission Assembly (SpecV Guts in Maxima Bellhousing)
Cleaned Maxima Bellhousing (Used acetone and cloth) https://dl.dropboxusercontent.com/u/...llhousing1.JPG https://dl.dropboxusercontent.com/u/...llhousing2.JPG https://dl.dropboxusercontent.com/u/...llhousing3.JPG Cleaned Differential Side of Bellhousing https://dl.dropboxusercontent.com/u/...ellhousing.JPG Maxima Final Drive and HLSD from SpecV https://dl.dropboxusercontent.com/u/...%20Spec-V1.JPG https://dl.dropboxusercontent.com/u/...%20Spec-V2.JPG SpecV Reverse Gear Set https://dl.dropboxusercontent.com/u/...ear%20Set1.JPG https://dl.dropboxusercontent.com/u/...ear%20Set2.JPG SpecV Gear Stacks and Maxima Final Drive in Bellhousing https://dl.dropboxusercontent.com/u/...llhousing1.JPG https://dl.dropboxusercontent.com/u/...llhousing2.JPG https://dl.dropboxusercontent.com/u/...llhousing3.JPG https://dl.dropboxusercontent.com/u/...llhousing4.JPG Maxima Final Drive Meshed with SpecV Mainshaft https://dl.dropboxusercontent.com/u/...0Mainshaft.JPG SpecV Mainshaft Meshed with SpecV Input Shaft https://dl.dropboxusercontent.com/u/...ut%20Shaft.JPG SpecV Input Shaft Meshed with SpecV Reverse Gear Set https://dl.dropboxusercontent.com/u/...Gear%20Set.JPG Detail SpecV Main and Input Shaft https://dl.dropboxusercontent.com/u/...ut%20Shaft.JPG SpecV 5th/6th Shifter Fork with Maxima 5th/6th Shifter Fork Rod Detail The SpecV 5th/6th Shifter Fork Rod had a pretty significant burr on it, and wouldn’t actuate properly. So I used the Maxima version. https://dl.dropboxusercontent.com/u/...Detail%201.JPG https://dl.dropboxusercontent.com/u/...Detail%202.JPG https://dl.dropboxusercontent.com/u/...Detail%203.JPG |
SpecV Check Ball and Spacer for 5th/6th Rod
https://dl.dropboxusercontent.com/u/...06th%20Rod.JPG SpecV 1st through 4th Shifter Fork with SpecV Rod Detail https://dl.dropboxusercontent.com/u/...%20Detail1.JPG https://dl.dropboxusercontent.com/u/...%20Detail2.JPG https://dl.dropboxusercontent.com/u/...%20Detail3.JPG SpecV 1st/2nd Shifter Fork Detail https://dl.dropboxusercontent.com/u/...%20Detail1.JPG https://dl.dropboxusercontent.com/u/...%20Detail2.JPG https://dl.dropboxusercontent.com/u/...%20Detail3.JPG SpecV Reverse Bracket Detail https://dl.dropboxusercontent.com/u/...%20Detail1.JPG https://dl.dropboxusercontent.com/u/...%20Detail2.JPG https://dl.dropboxusercontent.com/u/...%20Detail3.JPG SpecV Reverse Shifter Fork Detail https://dl.dropboxusercontent.com/u/...%20Detail1.JPG https://dl.dropboxusercontent.com/u/...%20Detail2.JPG SpecV Reverse Tilt Mechanism Assembly https://dl.dropboxusercontent.com/u/...0Assembly1.JPG https://dl.dropboxusercontent.com/u/...0Assembly2.JPG https://dl.dropboxusercontent.com/u/...0Assembly3.JPG SpecV Check Ball and Spacer for Reverse Rod Mechanism https://dl.dropboxusercontent.com/u/...0Mechanism.JPG https://dl.dropboxusercontent.com/u/...Mechanism1.JPG https://dl.dropboxusercontent.com/u/...Mechanism2.JPG |
Fully Assembled SpecV Guts and Transaxel Case on Maxima Bellhousing
https://dl.dropboxusercontent.com/u/...llhousing1.JPG https://dl.dropboxusercontent.com/u/...llhousing2.JPG https://dl.dropboxusercontent.com/u/...llhousing3.JPG https://dl.dropboxusercontent.com/u/...llhousing4.JPG https://dl.dropboxusercontent.com/u/...llhousing5.JPG SpecV Shifting Mechanism https://dl.dropboxusercontent.com/u/...0Mechanism.JPG Fully Assembled Transmission on Hoist https://dl.dropboxusercontent.com/u/...n%20Hoist1.JPG https://dl.dropboxusercontent.com/u/...n%20Hoist2.JPG https://dl.dropboxusercontent.com/u/...n%20Hoist3.JPG https://dl.dropboxusercontent.com/u/...n%20Hoist4.JPG |
excellent thread
Great thread. Thanks for all the pics. I'm obviously a little late to the party just finding this now......curious on this:
Is there any reason why you went with a sentra gearbox instead of a 6th gen gearbox? It's my understanding they have the same gear ratios, both have hlsd, and the same final drive ratio (4.133)...... but the 6th gen can be dropped straight into a 5.5 gen without modification. Perhaps I'm mistaken on that? |
Originally Posted by TSelanne
(Post 9131074)
^This.
Sentra trans runs around $300 and are plentiful, A +04 6spd maxima trans......:noes: Internally they are the same transmission the only difference is the bellhousing is different because VQ vs QR. |
Just a little thread bump, any chance you can fix the photo links 6spd_hayes?
I'm swapping around a spec v and max trans and liked the photos you had. |
Originally Posted by murphys_law
(Post 9146299)
Bump for pics, trying to get a Maxima FD in my SpecV transmission as well.
https://maxima.org/g/album/7330788
I uploaded all of my pictures that were above in that link. Maybe someday I can resort the thread so the pictures are in the right place. |
Ok, getting dropbox sorted out. I'll slowly get this updated.
thinking about doing this in my '03...
1 Attachment(s)
Anyone know of a cheap bearing puller for these trans? Im trying to get all the special tools I need for the job.
Looking for a consumer version of this I suppose: J39856-Kent-Moore-Gear-and-Bearing-Removal-Kit- |
Did you re-shim it before assembly? What sort of special tools are needed for the job? Did you have prior experience with rebuilding transmissions or did you just follow the FSM?
(Post 9219825)
(Post 9219827)
I did all of the measuring but did not have to reshim it. The existing shims were good. I needed no special tools whatsoever I also had no prior experience rebuilding transmissions. I simply followed the fsm.
(Post 9219835)
Wow, that's very impressive! I'm considering doing something similar with a 6 speed, but am unsure if I can tackle the job myself. I got a quote from a local trans shop and they estimated it would cost $600-$1000 in labor, and for that amount I'm wondering if I can do it myself. So the FSM is really that detailed? How has the transmission help up since you installed it?
(Post 9219836)
It was flawless till the day I sold it. Got several more years out of it. The guy I sold it to, and the guy he sold it to never had any trouble out of it. Yes, the fsm really has everything you need.
© 2024 MH Sub I, LLC dba Internet Brands
