Brahma 15's in the rear deck
Nismo, you cable modem frier.
Basically two won't fit. Unless you are willing to cut the steel frame that is the structure of the rear deck. A single 15 will fit in the middle. Or, possibly angle the drivers. This has potential. I will have to play around with it a little to find out how much angle is needed and where the cone will end up faceing. |
just so long as i can get them to fit...i dont really care about cutting, as i would have to cut the deck for them to sit in there anyway :)
eric |
Well don't order the brahma's yet. It could take a bit of tweaking to get this angle thing correct.
Originally posted by jmax Well don't order the brahma's yet. It could take a bit of tweaking to get this angle thing correct. eric |
Go IDMAX and youll get better SQ!!!!! LOL.
And if you do end up with the Brahma's be carefull they dont excurt out enough to hit your window! LOL |
Originally posted by Jr'sMaxima Go IDMAX and youll get better SQ!!!!! LOL. And if you do end up with the Brahma's be carefull they dont excurt out enough to hit your window! LOL |
Guys,
You should be able to get two 15s to fit, you just need to be a bit more creative. You should consider slot loading them. The two drivers fire into a slot that then mounts up to the rear deck. The drivers are still infinate baffle, or free air. I've personally never tried this, but have heard of it done. I guess the only question is if the slot that you build needs to be tuned. |
why not just cut out ur whole rear deck, and rebuild using MDF ... this will get you a side on your box...and also will eliminate some rattles...2 15's should then fit...or maybe im undersizing the size of a 15 i only got 2 12's i kno those would fit easily
Originally posted by ThumpinMaxima why not just cut out ur whole rear deck, and rebuild using MDF eric |
Originally posted by nismo240sx NOW somebody's talking my language...except id use birch ply, cuz its stronger and lighter. eric |
Originally posted by jmax My entire rear deck is cut out. It is only wide enough in the center for the fifteen. You might be able to put two in but they need to be butted up against each other. Even then they won't be able to be mounted flat. That's what I was saying about the frame of the rear deck. If you take your rear deck apart there is a hollow steel frame around the edge. Right behind the rear seat and up under the glass. Between this area is just thin sheet steal which is easy to cut and replace. But cutting the hollow frame section would jeopardize the vehicle. you wouldnt happen to have some pics of your rear deck, would ya ;) thanx, eric |
Originally posted by nismo240sx is there any way to reinforce the edges? i dont care about resale value, cuz im'a drive the wheels off...i wanna run a (preferably) ported, or sealed box--which is totally sealed off from the trunk, but id like to be able to get to the top of the rear suspension. i dont mind angling them or whatever needs to be done, so long as it wont look totally forked up. :D you wouldnt happen to have some pics of your rear deck, would ya ;) thanx, eric For a couple pics of my deck check: http://www.dcmax.org/photo.htm |
well, my friends dad does car restoration/metal work/fiberglass work for a living. he took a split window vette from the doors not shutting (mistfitting) to as good or better than factory, with perfect panel gaps--$16k worth of body work :D
as for box size, its either ~3 cubes (each) sealed, or a little over 6 ft3 plus ports. and no i dont wanna lose access to the trunk or spare, so innovative thinking is a requirement. my only concern is how to get to the top of the rear suspension. i know id like to tie into them for strengthening the rear rigidity, but i dont have a clue how to...unless there could be some way of doing it thru the rear deck?!?! thanx again, eric |
Well, I have never seen a pic of the RSTB. So I can't comment on how much it would get in the way. But a creative box could take it into account, or act as the RSTB. The Brahma can sound good with 2.5 ft cubed, especially with generous high quality fill material. The vented enclosure is big even before you account for the vent dimensions. Decide asap if you want max spl or max sq. Because the differnce between the two will be drastically different boxes.
i was hoping to use the box AS the rstb, rather than including it...as for sq/spl--i have heard a little over 6 ft3 @ 30 hz in an s10, and i loved the sound, so thats probably what ill do. i thought about a removable port, but decided that was a bad idea :D
eric |
btw, that 6 ft3 is total ;)
eric |
Originally posted by nismo240sx i was hoping to use the box AS the rstb, rather than including it...as for sq/spl--i have heard a little over 6 ft3 @ 30 hz in an s10, and i loved the sound, so thats probably what ill do. i thought about a removable port, but decided that was a bad idea :D eric |
Okay, just remember that the smaller box means a longer port for the same tuning frequency. And you can run into trouble fitting the port in the box real quick. I don' know how accurate winisd is, so I would double check any box the program comes up with. But it looks like having the subs share a 6.0 cubic foot chamber might solve a lot of these issues.
The box can definitely serve as a rear stabalizer. If it is well made. And baltic birch is the flimsiest material I would consider for this driver. But it may boil down to if you can afford to pay your friends dad $16,000 for a custom sub enclosure. And if he has any experience building speaker boxes. |
ive been talking to dan wiggins about what to use. he suggestests baltic birch ply for its rigidity, and for being lightweight...otherwise, ill probably use trupan.
eric |
I picked up some baltic birch for the first time about a month ago. I am very impressed by it's strength/rigidity. And screw holding power looks as though it will be very good.
| All times are GMT -7. The time now is 12:09 PM. |
