what's the difference
what's the difference between a 2 way speaker, 3 way speaker, 4 way speaker and component speaker?
Re: what's the difference
Originally posted by redzero what's the difference between a 2 way speaker, 3 way speaker, 4 way speaker and component speaker? 2-way: midbass = 60hz-3khz tweeter = 3khz-25khz total = 60-25khz 3-way: woofer = 40hz-1500hz midrange = 1500hz-4000hz tweeter = 4khz-25khz total = 40-25khz This allows you to break up the frequencies to come off different speakers. One advantage to a 3-way or 4-way is you have more speakers on each channel and allows you to apply more power. Also, some crossovers will let you adjust those freqs and tweak the sound for your hearing. Component speakers separate these "components" into seperate packages as where a 2-way speaker they are one package(mounted together).;) |
It's mostly a marketing ploy and bragging rights for the non-informed (as in "I just got some awesome 5-way 6x9's"). I could make up a 47-way speaker but that does not make it any better. What was said above is mostly correct in theory. However, in reality most speaker manufacturers do not provide crossovers for their speakers (other than high pass filters for protection of the tweeters). This means that at high frequencies (and sometimes even upper-mid range on multi-way speakers), multiple speakers are trying to produce the same sound. This makes for muddy sounding music. Properly installed components or high end 2-ways (with external crossovers) are usually the best. I would stay away from the other crap.
Originally posted by bahmax It's mostly a marketing ploy and bragging rights for the non-informed (as in "I just got some awesome 5-way 6x9's"). I could make up a 47-way speaker but that does not make it any better. What was said above is mostly correct in theory. However, in reality most speaker manufacturers do not provide crossovers for their speakers (other than high pass filters for protection of the tweeters). This means that at high frequencies (and sometimes even upper-mid range on multi-way speakers), multiple speakers are trying to produce the same sound. This makes for muddy sounding music. Properly installed components or high end 2-ways (with external crossovers) are usually the best. I would stay away from the other crap. |
| All times are GMT -7. The time now is 05:18 PM. |
