do i need cap??
im running alpine amps and type r's through my stock bose headunit...sounds great but my amps are not constantly running at 14.1volts they dip down all the way to 12volts alot of time and stay around 13volts....now im ujst running a 300watt rms amp and im thinking i dont need a cap but do i? also maybe its cuz im runnign a 4guage power wire and 8 guage grond wire i dont kno any suggestions?
does your lights dim???? if it does i would get one. and bro pm me back with some info
thanks |
Grounding issues could cause such a problem (if your headlights don't dim but the amp's voltage drops 'n stuff, it could indicate a wiring problem on the amp side, power or ground)
Where are you getting those voltage measurements BTW? |
Re: do i need cap??
Originally posted by BlkMaXinMD im running alpine amps and type r's through my stock bose headunit...sounds great but my amps are not constantly running at 14.1volts they dip down all the way to 12volts alot of time and stay around 13volts....now im ujst running a 300watt rms amp and im thinking i dont need a cap but do i? also maybe its cuz im runnign a 4guage power wire and 8 guage grond wire i dont kno any suggestions? Some things you should test are your battery and alternator. Is your battery in good shape? Has it been asbused from cycling? Is it sulfated? Is your alternator putting out enough amperage/voltage to charge your battery adequately? |
brand new 2k3 wtih 2500miles on it running 1 12in type r's with 1 mrd m300 which shows the amps and voltage i am runnign at
Originally posted by BlkMaXinMD brand new 2k3 wtih 2500miles on it running 1 12in type r's with 1 mrd m300 which shows the amps and voltage i am runnign at The only concern I have is, the stock electrical system doesn't like to idle too low. So if you have a manual, make sure to raise the idle a bit to about 750rpm, as opposed to the 600rpm. If you have an auto, I wouldn't worry about it at all. |
blkmaxinmd can u please email me???? with the amp stuff i need to know bro well if i was u get a cap. and pm me or email
thanks |
© 2024 MH Sub I, LLC dba Internet Brands
