experiances with power loads on type r 12's
so i just got the first of my 2 type r's bumping since i got my first of 2 amps. im running 460 watts rms to the speaker and let me say that it sounds awsome, but as we all know they are meant for 300 rms, what has everyone fed them and their experiances at that level, neone blow them? if you did what was the power range they where getting?
my friend had 1 type r 12 off 600 watts rms and he blew it a few times but got it replaced for free. i convinced him to get another and now he has 2 12's with 300 going to each and he gained alot of spl and hasnt had any problems with the subs at all.
whats the internal cuft of the box and i hope you set gains right with all the power. :) |
well im running probly about 4 to them with the amps turned down and i keep the remote bass control on 0 though when flipped to +6db (the first jump followed by +9 and finally +12) it makes a load of differnce, thats when the bass really comes alive
is that remote bass control connected to the amp or are you talking about something in the h/u?
i had one 12 inch type r with the jbl 600.1, with the gain set about 3/4. Now i have 2 12 inch alpine type r with 300 watts rms going into each with the jbl 600.1
the remote bass is conected to the amp, its one of those little dial things, opti did you blow the sub with the 600 watts going into it?
no, the sub was fine and i'm still using it.
awsome.....im only running 460 and ive got my gains turned down a bit, so i shouldnt have a problem good to know, thanks for the help
if your really paranoid about it try this... put it up to the highest volume you will play it at with the car on and pop the trunk and look and listen the sub. if you hear any popping or cracking lower the gains. or if you hear anything that just doesnt sound right lower them.
you should be okay. just follow slickrick's advice to be safe. |
| All times are GMT -7. The time now is 03:06 AM. |
