Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   Wpuld it be worth it to put in an amp to power my 6.5's? (https://maxima.org/forums/audio-electronics/272815-wpuld-worth-put-amp-power-my-6-5s.html)
ManualMaxima Dec 30, 2004 10:40 AM
I have a pioneer headunit and it puts out 200 watts. Well my brother gave me an amp that he did not care about cause he upgraded and it is a 200 watt punch amp that he gave me. would there be any reason for me to use this over my headunit? or would i just be wasting my time?
Micah95GLE Dec 30, 2004 10:44 AM
It will be better than the HU amp. Which model is the amp?
filtor1 Dec 30, 2004 12:53 PM
Add the amp. Your HU does not put out that much power. Garaunteed. Which punch amp is it?
slickrick Dec 30, 2004 11:06 PM
yes. amp your speakers if at all possible. i used to think i didnt need to amp my cdts but boy was i wrong.
CO2kmax Dec 31, 2004 11:49 PM
I would say run the amp, but rember there is alot 2 do, unless you have it installed. Power, ground, remote, rcas, tap into the speaker wires. Is it a 4 channel amp?
suprropmp Jan 1, 2005 06:50 PM
i also have a pioneer head unit.. they put out about 19-22 rms per channel
killcrap Jan 2, 2005 02:26 PM
your headunit is probably a 50x4 = 200watts max with mosfet. most likely you are getting 13.5watts or 22watts rms. so i'd suggest you to amp them.
Scope Jan 2, 2005 03:22 PM
You can get a two channel and get some of these bad boys http://www.thezeb.com/p-Audiobahn-AC...ers-100304.htm
Then wire a 0ga power and a 4ga ground and run a power/ground block so it can feed off of that.
Micah95GLE Jan 2, 2005 04:46 PM
The power and ground cables should be the same size.
2 Da Max Jan 2, 2005 04:48 PM
uhm first of all make sure there components lol. and yes why not since you have the amp use it! it will sound good. you dont need 0 or 4 awg for that amp. 8 is fine
