I have remote starter in but a/c won't come on
I put my remote starter in and everything works fine except........my a/c turns on the fan turns on but no air is blown out. anyone else experienced this and what was your solution?
Hmmm.....did you leave the AC in the on position? You also will need to turn the dial that indicated what speed you want the blower to operate at. When I get out of the car I leave it at 2 and make sure the AC and/or Heat is on (weather dependant of coarse). If it is left on then it has to turn on when the car is remote started.
Just curious, are you using the factory remote?
what rs are u using?
http://forums.maxima.org/showthread.php?t=399176 repost! :)
anyway did u get this fixed or what? Silver, You could use your factory remote. |
make sure the accesory wire is hooked up to the heater a/c unit
How do you use the factory remote for a remote starter?!?
| All times are GMT -7. The time now is 10:37 PM. |
