Using a LOC for RCA's
Old Jun 26, 2005 | 06:12 PM
wanta02max's Avatar
Where should I use the LOC to get my preouts for the amp? can't I do it in the trunk with the wires to the factory bose sub?? if so, which wires should I splice into??
Old Jun 26, 2005 | 08:48 PM
kcidmil's Avatar
Well with the 3rd gens, we have to use the signal wires before the amp to get the best sound. But from what I heard, the newer Maxs' you can either go before or after the amp in the trunk.
Old Jun 27, 2005 | 06:03 AM
wanta02max's Avatar
yeah that's what i was concerned with, doing it before or after the amp in the trunk.
Old Jun 27, 2005 | 06:38 AM
kpr10is's Avatar
Connect it to the wires going to the Bose sub after the Bose amp that powers that sub.
Old Jun 27, 2005 | 07:00 AM
wanta02max's Avatar
there should be no sound problems doing it that way right kpr? do you know exactly which wires go to what? on my LOC i've got 2 whites (+,-) and 2 grays (+,-) which do these go to on the sub wires?
Old Jun 27, 2005 | 07:42 AM
kpr10is's Avatar
Nope, there will be no sound problems. As for colors, Im not sure off the top of my head. The two positive wires should go to the positive wire of the bose sub, and the two negative wires to the negative of the bose sub. An easy way to test is take a 9 volt battery and touch it to the terminals of the bose sub. If the sub moves outward like normal then your polarity according to the battery is correct. If it moves inward then its reversed.
Old Jul 17, 2005 | 04:34 PM
wanta02max's Avatar
i hooked the wires up to the purple and yellow wires going into the sub but i'm not getting enough signal from that i don't think...anybody got any ideas?
Old Jul 17, 2005 | 09:36 PM
kpr10is's Avatar
You hooked up your LOC after the amp, correct?
mrc00l88
Jan 25, 2024 01:14 PM
9aj9
Apr 5, 2020 12:11 AM
Matt93SE
May 24, 2019 02:58 PM
ivorton23
Sep 28, 2015 09:08 PM
WizzaMax
Aug 28, 2001 11:14 PM
