Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   reccomend some 12's, amp (https://maxima.org/forums/audio-electronics/316967-reccomend-some-12s-amp.html)
max723 Aug 14, 2005 04:46 AM
i have an extra box to hold 2 12's and lookin to put it in my other car, 97 taurus. Im looking for something inexpensive but loud that wont blow. what do you guys think i should go with? i was looking at infinitys or the alpine type e's
SEmy2K2go Aug 14, 2005 05:16 AM
You should research the specs of certain sub models in relation to the dimensions of this box you have in mind to use.
max723 Aug 14, 2005 05:30 AM
true, just measure to find the dimensions right and volume? dont know anything but its a q logic dual 12" box. also its sealed
1996blackmax Aug 14, 2005 06:46 AM
If there is a sticker on it you may be able tell what the model # is or also what type it is, such as type 1, 2, or 3. Type 1 is .88 cubic feet, the other ones are bigger.
max723 Aug 14, 2005 07:46 AM
ok, ill check. mine has 2 blocks of wood in each side glued in. is this to change the volume?
max723 Aug 14, 2005 07:48 AM
1.25 cu ft.
slickrick Aug 16, 2005 08:50 PM
stay away from type E's please.
PerfectVQ I30 Aug 17, 2005 12:02 AM
i love my perfect vq, VQ = variable Q. It comes with 3 inserts to adjust for anybox size from .6 cu all the way up to free air. If you want to go cheap u can get refernces for 50 bucks each, had good expiriences with those too.
max723 Aug 17, 2005 06:33 AM
ok, forget the type e's. ill prob go with infinity references.
slickrick Aug 17, 2005 04:35 PM
me personally... id spend more than $50 each for a 12 but what do i know?
max723 Aug 17, 2005 04:43 PM
i was looking to spend a little more than that but its just something for my beater, not max.
AscendantMax Aug 17, 2005 06:27 PM
:sprint:
invest in good subs now so you don't have to regret your purchase later on down the road.
PerfectVQ I30 Aug 17, 2005 06:47 PM
Originally Posted by AscendantMax
:sprint:
wow yall are some haters, i had references from 1999 from cartoys buy one get one for 100 and they lasted 3 years till i sold em and they made my rear view mirror drop one day at a light. It was quite hilarious but still....
AscendantMax Aug 17, 2005 07:21 PM
eh? my comment wasn't directed towards ya, it was just a general statement. :)
slickrick Aug 17, 2005 07:23 PM
nobody is knocking the subs...but until your system does this...
http://img.photobucket.com/albums/v4...o/DSC02989.jpg
ill stick with my recommendations. :)
kcidmil Aug 17, 2005 07:28 PM
*cough* Memphis. :lol:
jigga123 Aug 17, 2005 08:15 PM
Well it doesn't seem like you have a large budget so I would recommend either Comp Vr's or Alpine Type R's. Both are decent woofers and can be had for very cheap on Ebay.
1996blackmax Aug 17, 2005 09:01 PM
For a little more than the Comp VR's you could get some TC Sounds 12's (TC2+ drivers) from O Audio. They are the same subs that Sound Splinter has, but they only carry the 10" and 8" sizes. I own the 10" version of the TC2+ (it is an RL-i from Sound Splinter), and it has good clean output. Those 12's have a little over 19mm of Xmax.
http://www.oaudio.com/TC2_PLUS.html
For a little more than the type R's you could get some RL-p12's from Sound Splinter. This is the big brother to the first subs I mentioned. I can only imagine how darn loud a pair of those would sound. Those things have 24.2mm of linear excursion.
http://www.soundsplinter.com/rlp_pre...subwoofer.html
AscendantMax Aug 17, 2005 09:40 PM
^^^ :sprint:
here's a vid of a SS RL-p in action:
http://www.soundsplinter.com/images/...ter_RL-p15.wmv
1996blackmax Aug 17, 2005 10:31 PM
Quite a bit of movement there :). Earlier today I actually showed my son what the little RL-i10 could do. I opened the trunk and turned up one of songs on the Gorillaz cd with a little bit of bass (Dare I believe). Pretty cool to see what 20mm of linear excursion looks like :). I did tell him that I do not crank the system that loud to protect our ears (mostly his).
AscendantMax Aug 17, 2005 10:36 PM
i've yet to get see my sub in action lol. been mostly inside the car testing out buncha cds and what-not.
