Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   I'm needing some tweeters..... (https://maxima.org/forums/audio-electronics/353928-im-needing-some-tweeters.html)
BRINKLEY May 12, 2006 10:52 AM
any suggestions, I would really like to stay under $100 for some good ones. I will be powering them with 40 watts RMS with a built in crossover. thanks. I found some titanium lanzar at a local shop marked for $150, said he'd take 120 for them, but I've never been a fan of lanzar. Currently I have:
Alpine 9825 head unit
Soundstream 405 Amp
15" DVC 2ohm ARC sub
6 1/2 CDT mids
fosgate tweets gave out on me... so don't mention these to me again, lol
thanks
JB
nismos14 May 12, 2006 12:05 PM
They gave out on you, then you were gonna go with lanzars? What did you think they would do? You need a crossover thats capable of the right frequencies. If you're using the 405 to xover the tweeters expect them to blow out alot. You need a hpf of most likely arond 2000 - 3000 if not higher depending on the tweeter.l
Bollwerk May 12, 2006 01:08 PM
IMHO, you'd be better off buying a set of seperates that come with a passive crossover. That's gonna run more than $100 though. But, you get what you pay for.
If you just want to get tweeters again, then buy a passive crossover for them, so you at least don't kill them.
BRINKLEY May 12, 2006 08:02 PM
are you talking about components when you say seperates? and I had resistors on the fosgates. I would have thought between that and the crossover in the amp it wouldn't hurt my tweets.
1996blackmax May 12, 2006 08:33 PM
Yes he is.
adampit May 13, 2006 08:08 AM
I have a set of JL VR tweeters that would work for you. PM me if you are interested
nismos14 May 13, 2006 08:31 AM
Resistors are a no no when it comes to amps/speakers. Are you sure you didn't mean capacitors? Even still a passive x over that comes with a set of components is much better, unless you have the capability at crossing over at high frequencies from your amp > 2000hz with a minimum of 18db/ octave.
