| mrloyd |
Oct 23, 2000 11:35 PM |
correction
What dude said about rms is correct. But dynamic power is not the same as max power. The term dynamic power is used by some amp companies that rate their amps conservatively for competition use. Mtx for example does this. Dynamic power is power at (i think) 14.4 volts, which is average output for an alternator when the car is at idle. The lower power rating is for at 12 volts when the car is not running. This conservative rating is so you can enter lower classes at comps. The power output jumps the same way your lights get brighter when you start the car. Max power is mostly unimportant. Rms is very important. Dynamic power is important when you are comparing something like an mtx or alpine v12amp, both measured at 12v, to something like a pioneer, kenwood, rockford, sony, ect amp. It it is only a valid comparison using the same voltage, which most amps are rated at 14.4. Crutchfield catalog has a good comparison chart. By the way dynamic is rms power, its just the difference in source power voltage. hope this helps.
