Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   I'm going to give this sub/midbass a shot (Free-air 8") (https://maxima.org/forums/audio-electronics/552082-im-going-give-sub-midbass-shot-free-air-8-a.html)
Deckdout2 Jan 28, 2008 10:29 AM
JL Audio has this out for 2008, and I'm going to give it a shot. It's the Evolution ZR800-CW Midbass 8" Sub. Goes down to 40Hz so that sounds like it'd do the job I'm looking for.
http://mobile.jlaudio.com/products_amps.php?amp_id=256
I don't have any reviews for it or anything to go off of so I figured I'll be the guinea pig for everyone that's looking to do a Free Air replacement on their rear deck for the 5th gen.
I'll probably pair it with the 500/5 from JL Audio as well, using that to push the Rainbow SLC265's.
Hopefully, I won't be disappointed in this setup but we will see.
I've got 2 12's ready if the 8" needs more ummmpf. Currently, don't need low pounding bass, just low enough with excellent sound quality.
nismos14 Jan 28, 2008 01:04 PM
Your link doesn't work, and that 8" will prob leave you wanting more. The SLC's would most likely have more to them bass/midbass wise than the JL, IF you're doors are properly setup.
burnurass Jan 28, 2008 01:33 PM
If you're used to 2 12's....I wouldn't do it. =P
I tried this also..it was nice but it wasn't enough. Save your monies for buying a REAL AMP (non JL). =P
Deckdout2 Jan 28, 2008 01:37 PM
Really? That's odd, it seems to pull up the page for me. Try this one, the first link was for the amp, but I'm having second thoughts about that one.
http://mobile.jlaudio.com/jlaudio_pages.php?page_id=215
O, I'm sure you're absolutely right. I just wanted to test this and see the outcome. There's not much out there for choices on Free Air.
What's the best setup you have found for the doors on my particular car with the SLC's? I have yet to tear apart anything and play around until now.
nismos14 Jan 28, 2008 02:26 PM
Seal up all wholes, deaden the outer and inner and the door panel. You can use any sub free-air, they will just perform differently. I suggest you find something with a larger voice coil, higher power handling, and plays lower than 40hz.
Deckdout2 Jan 28, 2008 03:05 PM
I'm trying everything I can for the moment to save space in the trunk. I really need it right now because I do a bit of traveling and there's always something in it. I just might have to bite the bullet and revert back to my original plan of glassing.......
Deckdout2 Jan 28, 2008 03:06 PM
Ok, that was the direction I was headed. Thought you meant doing something else I was aware of. Preesh!
burnurass Jan 28, 2008 03:45 PM
YEAH....I went through that phase also. I was then disappointed with the results. I just got a box that was skinny depth wise but was the width of my trunk between the wheel wheels. I still have a decent amount of trunk space. :D
AscendantMax Jan 28, 2008 06:19 PM
:sprint:
get a sub that works well in a small sealed enclosure and you should have a decent amount of trunk room left over. here's my current setup. the box have since been carpeted.
http://img.photobucket.com/albums/v4...o/IMG_0499.jpg
nismos14 Jan 28, 2008 06:23 PM
Or a nice fiberglass enclosure : http://i178.photobucket.com/albums/w...00/BLAU004.jpg
Deckdout2 Jan 29, 2008 07:40 AM
I'm going to have to end up going this route. It sucks that there's not a good setup that will work for this, at least not up to par of what we're expecting. I might as well listen to you guys that have already been there so I don't waste my time and money on it.
Seemed like a good idea huh? :(
Deckdout2 Jan 29, 2008 07:41 AM
Life would be so much easier if there was already one fabed up just like this for my application. I guess it takes the fun out of doing it yourself. Thanks for the visual.
Deckdout2 Jan 29, 2008 07:48 AM
Originally Posted by AscendantMax (Post 6215610)
:sprint:
simplicity at it's best! :thumbsup:
filtor1 Jan 29, 2008 04:37 PM
Fi just started making IB subs. For now they only come in 15" and 18" but with the proper baffle and the sub firing into the back seat (seats down being optional) There would only be the basket and an amp taking up room in the trunk. All you wold ned to do is seal up the trunk to eliminate stading waves from the rear of the driver. If I wasn't such a bass head, his is what I would be doing.
http://www.audiojunkies.com/blog/866...fle-subwoofers
If the link doesn't work, search for Fi IB on www.audiojunkies.com
mendon99 Jan 29, 2008 04:52 PM
link worked fine filtor, very interesting. I was wondering when Fi was going to be doing something more (not that they need to)
filtor1 Jan 29, 2008 06:46 PM
Indeed. I was planning on doing a small OB home audio project with them before my desk top took a crap on me. I will play with them at some point in the future. I want some people who want to go IB to try them out though. I wish I or Kevin could do an IB install here too. Oh well, can't always have what you want. :)
