Box build log: 12" Fi Audio Q
Old 03-11-2008, 06:14 PM
AscendantMax's Avatar
Figured I'll let it have its own thread instead of putting it in the big Audio Thread.
The design:
started construction on the box. it's going to be a little smaller than initially planned at 2.1 cu ft. it's really my first enclosure with kerf'ed panels. i reallllllly need to get some big clamps. that would have made things MUCH easier.
yes i'm using screws just to mess with Don
no clamps, so i had to ghetto rig it somehow. it works.
AscendantMax is offline
a tiny crack started to form. i put some glue on it. seems to help it from spreading.
starting to kerf the other port piece...
waiting to get bent into shape.
Old 03-11-2008, 06:17 PM
worked on the box a bit more today while there was still some light out.
pick up a clamp at home depot. works rather nice.
in the process of filling in the gaps with a paste of wood glue and MDF dust.
Old 03-11-2008, 06:19 PM
And here's the sub. Looks pretty nice. Only complaint is the CA glue was running over the edge of the spider landing, but it's no biggie.
flat leads that goes under the spider.
the *** shot.
Old 03-11-2008, 06:36 PM
filtor1's Avatar
The new leads are very nice. Box looks good to man!
filtor1 is offline
Old 03-11-2008, 08:27 PM
thanks chris
Old 03-11-2008, 09:48 PM
slickrick's Avatar
looks beefy
slickrick is offline
Old 03-12-2008, 12:27 AM
chinaonnitrous1's Avatar
In my limited experience...
THat is a fantastic looking slot port enclosure.
Super Props on the smooth port entrance.
chinaonnitrous1 is offline
Old 03-12-2008, 12:43 AM
Go BUCKS!!!
SEmy2K2go's Avatar
I approve the level of fine carpentership.
SEmy2K2go is offline
Old 03-12-2008, 06:01 AM
Play with my balls
Deckdout2's Avatar
That's a really nice build. I haven't seen a box of this quality in a long time. The kerfs came out especially good. Nice work!
Deckdout2 is offline
Old 03-12-2008, 06:43 AM
amomaxima's Avatar
how much does all that weigh
has to be about 50 plus pounds right
amomaxima is offline
Old 03-12-2008, 07:44 AM
it's pretty heavy right now. i still need to put the top panel in, as well as some bracing. it would be much lighter if i used birch, but eh....i had quite a bit of MDF laying around. it'll be even more heavy with the sub installed. the sub alone is ~30 pounds.
thanks for the props fellas.
Old 03-12-2008, 08:03 AM
jrpaytonAlpha06's Avatar
Very nice build!
jrpaytonAlpha06 is offline
Old 03-12-2008, 08:09 AM
amomaxima's Avatar
when you rolling a super sub like that birch is a BAD idea
MDF is the only way unless you are into fiberglassing
Which is always the best solution but who has the time and money right?
Old 03-12-2008, 08:25 AM
how is birch a bad idea? i've used birch in a lot of builds. it's much lighter and a bit stronger than MDF.
MDF is favorable since it's fairly cheap. birch is roughly twice the cost of a sheet of 4'x8' MDF.
Old 03-12-2008, 08:39 AM
slickrick's Avatar
ive hit around 140 db @ 40hz with 600 watts + a 15" Super sub in a birch box that was made like crap (made by me), and it sounded amazing.
Old 03-12-2008, 08:48 AM
Former Vendor
BLACKonBLACK98's Avatar
looks good bro. just had to port huh?
BLACKonBLACK98 is offline
Old 03-12-2008, 09:07 AM
travmaximas1998's Avatar
looks good man
travmaximas1998 is offline
Old 03-12-2008, 10:43 AM
Fast1one's Avatar
Thats a little missleading, birch is only stronger if its void free...
The stuff you find at home depot and such is usually NOT void free, and only 7-9 ply Vs. 13 ply for the good stuff...
Usually void free 13 ply birch ranges from 50-100 dollars for a 5 x 5 sheet...depending on location. Here in California I have seen prices hover around 70 bucks...
Fast1one is offline
Old 03-12-2008, 10:49 AM
§è~® f®ÈÄk
nismos14's Avatar
And you won't gain any extra db's from a birch box vs a mdf box.
nismos14 is offline
Old 03-12-2008, 11:55 AM
amomaxima's Avatar
last time i used burc h i spilt the front where the sub attaches
I dont trust it
i prefer MDF double layered even
Old 03-12-2008, 12:20 PM
§è~® f®ÈÄk
nismos14's Avatar
Haha just because YOU cracked it doesn't make it inferior. MDF splits all the time.
nismos14 is offline
Old 03-12-2008, 12:31 PM
Fast1one's Avatar
I dont trust it
Did you pre drill? Like noted below MDF will do the same thing...
You may have hit a knot (void) in the ply causing it to split...this is why I can't stress enough...if you are going to use birch for a subwoofer enclosure then do it right the first time and invest in quality wood...
Regular veneered birch is fine for low output enclosures for light duty or home projects...but thats it...
Fast1one is offline
Old 03-12-2008, 12:35 PM
slickrick's Avatar
http://www.youtube.com/watch?v=z8iRrsquzT8
what about cardboard?
Old 03-12-2008, 12:46 PM
Go BUCKS!!!
SEmy2K2go's Avatar
Press board is even bettar!
Old 03-12-2008, 12:49 PM
Fast1one's Avatar
Originally Posted by slickrick
LOL!!!
Fast1one is offline
Old 03-12-2008, 02:10 PM
filtor1's Avatar
I see they found a good use for those JLzorz...
filtor1 is offline
Old 03-12-2008, 02:55 PM
I R The Law
The Law's Avatar
Whats with the ****ty pics?
The Law is offline
Old 03-12-2008, 04:55 PM
tastey wheat
mendon99's Avatar
looks good. I may try kerfing on my next box..
whats the dead space for? couldn't have come up with some use for it?
mendon99 is offline
Old 03-12-2008, 05:05 PM
Fast1one's Avatar
Assuming for the outer flare, much easier to have dead space then to try to trace out the kerf for the upper and lower panels...
As far as use for it, what did you have in mind, a cup holder
Fast1one is offline
Old 03-12-2008, 05:58 PM
the home depot near my area have some 13 ply birch. you're right on the voids though. i've seen some home depot locations carry some birch that are knotted all over. i try to go through each board to find one that's actually worth the price.
Old 03-12-2008, 06:01 PM
as for the dead space, i wanted to flare both sides. and yep it's much easier than tracing out the kerf on the top and bottom pieces.
my old man took the camera again, so i snapped some pics with my phone again. got the top panel in. first layer of fleckstone is drying. i couldn't flush the sub. i didn't know the OD of the sub is 12.5"...the front panel is 12.5" tall not counting the top and bottom panel.
Old 03-12-2008, 07:42 PM
getting ready to drill the cutout
painted the port black.
Old 03-12-2008, 07:43 PM
the fleckstone looks pretty damn good. i'll snap better pics tomorrow. still need to carpet the top, sides, and back. then terminal cup. then bassssssssssssss
Old 03-12-2008, 07:55 PM
Fast1one's Avatar
wow, void free or not 13 ply at home depot is pretty cool...
Great looking box BTW...
Fast1one is offline
§è~® f®ÈÄk
nismos14's Avatar
Noice noice.
nismos14 is offline
Old 03-13-2008, 05:43 PM
update: took some better pics today of the fleckstone. got the sub in, and had a quick listen. the thing is a low end monster! there's zero port noise thanks to the flared opening, and the sub is pretty musical. response wise, it's a little warmer than the hertz, but it's keeping up with any music i throw at it. i'll need more ear time to give a better review.
closer shot of the fleckstone.
waiting to get wired and screwed in.
Old 03-13-2008, 05:48 PM
threw it in the backseat for a quick listen.
Old 03-13-2008, 08:25 PM
filtor1's Avatar
Nice job! Wait till that sucker opens up. You will notice a huge difference. If you think it is warm now, just wait.
I am loving the fleck man. It sets the sub and port off very well.
filtor1 is offline
Old 03-13-2008, 08:50 PM
Romster's Avatar
Looks nice. What is the box ported to?
I'm gonna start building one aswell next week, think I'll just use manufacturer recommended dimentions.
Romster is offline
Quick Reply: Box build log: 12" Fi Audio Q
