Where's the trunk trigger?
I can't find the trunk trigger wire(violet/yellow) in the kickpannel. Does it only come on cars equiped with electronic trunk release? I got a 98 GXE.
if i remember it is located
at the factory security alarm near the clutch pedal if u have the keyless entry model there is two plugs i think it a gray molex plug just unplug it and test ur factory remotes .... did u get an alarm that has a bouble pulse unlock
I don't have a factory alarm, nor a keyless entry. My alarm works fine exept I can't find the trunk triger wire.
trunk wire
there is a short and the long way
the short way is to run a wire from the brain of ur alarm that is connected to the trunk sense to the negitive side of the trunk lamp the long way is to check in side the wire loom that is running from the left side of ur door sill it usally running on that side |
| All times are GMT -7. The time now is 08:18 PM. |
