Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   2 12's FG work in progress (https://maxima.org/forums/audio-electronics/568299-2-12s-fg-work-progress.html)
Orgullo Jul 31, 2008 12:43 PM
Taking on my second FG project. Here's a pic of my first. Just glassed and filled the rear deck. Slanted two 6.5's and I've got a tv that I am putting there for shows. It's a tear drop witha screen in it. Again it is only for shows that I put it in. I'll get pics of that up later.
http://memimage.cardomain.com/member...9_640_full.jpg
Here's the construction of my sub set up. I'll take a some more progress shots. I've got two separate pieces too. One for the back wall and one coming down the center to cover the channel. My ports will be in the channel and pushed right towards the cab.
http://memimage.cardomain.com/member...9_646_full.jpg
http://memimage.cardomain.com/member...9_642_full.jpg
Ran the fleece through the gasket and pulled it tight there. This way to cover all the sides.
http://memimage.cardomain.com/member...9_643_full.jpg
I've already saturated, matted and saturated again. I've layed about three layers of glass so far. I am going to mat it out again and lay bondo hair/glass today. Overall I'll have more then enough glass/matting/bondo to keep it from cracking under beat.
Orgullo Jul 31, 2008 12:45 PM
http://memimage.cardomain.com/member...9_644_full.jpg
http://memimage.cardomain.com/member...9_645_full.jpg
Orgullo Jul 31, 2008 12:46 PM
http://memimage.cardomain.com/member...jpg?101418-215
http://memimage.cardomain.com/member...9_654_full.jpg
I mixed bondo hair with FG resin and created some volatile ****. Not so much boom but it gets hot! Almost too hot to touch so I put the dryer on it and cooled it down. Once it dries though it's extremely tough. I coated both inside and out.
This is a learning experience. A piece of advice to anyone doing their own build I'd recommend tacking the bottom on create your design and resin. Once it dries then you can take the bottom off to get the inside saturated. It's a pain in the *** to resin the inside through the sub spot.
Orgullo Jul 31, 2008 12:47 PM
reserved again
meccanoble Jul 31, 2008 01:28 PM
nice looking project, btw your car looks extra sexy.
filtor1 Jul 31, 2008 03:04 PM
Nice bro. Did you ever get the PM I sent about my Q's? Should save you some dough. :)
nismos14 Aug 1, 2008 05:36 PM
Very nice, lookin forward to more.
Orgullo Aug 2, 2008 06:24 PM
Thanks... It's a process and I can see why some spots charge what they charge.
Filtor I am coming to you when my ends are right. I haven't forgotten about you and thanks for the deal.
I'll keep posting pics of this project from beginning to end.
I am also getting another rear deck lid to build. I am going to build this one up with two 8's and maybe a tv too. That one I'll sell though.
filtor1 Aug 2, 2008 07:21 PM
Cool,they are sitting in the office for ya. :)
And as i said before, great work!
Orgullo Aug 4, 2008 12:31 PM
This is a slow process... I am ready to get the low end back in. However, I've seen some other DIY projects where there wasn't enough layers and it started cracking under pressure.
I've got about 4 layers now on each. The part in the middle will only have two considering it will host a tv and maybe some 6.5's. My amp will sit under the ramp there in the channel where the air from the ports is coming through. I've got some sanding left to do and then I am going to finish up the back side. Pics to follow.
Torgus Aug 4, 2008 03:20 PM
Orgullo my friend you are giving me motivation do start to do my own custom trunk setup...
ROCK THE UCK ON
p.s. how are my side skirts doing?
Orgullo Aug 5, 2008 04:57 AM
Correction... my side skirts. They are sitting lovely... :D
GL with your project.
Orgullo Aug 10, 2008 05:06 PM
Update:
http://memimage.cardomain.com/member...9_656_full.jpg
http://memimage.cardomain.com/member...9_657_full.jpg
http://memimage.cardomain.com/member...9_658_full.jpg
http://memimage.cardomain.com/member...9_659_full.jpg
I've got a small section to fill the gap between the box. It'll hold a componet set. Actually two tweeters will rest in the lower center piece ( missing ) and a 6.5 going up. Then I'm going to put the tv above that. I am going to paint the triangle part the color of the car and everything else will be leathered out.
I've got about two more coats on the boxes themselves. Mainly fill in spots. And one more coat, some sanding, priming and a top cover for the triangle.
filtor1 Aug 10, 2008 06:26 PM
Is there any chance in you notching an area out for the motor structure for your drivers. I am not even sure you will get anything with a standard 12 spoke in there. With such big enclosures and so much space taken up for the boxes it would be a shame to be forced to use a shallow mount. Can you post up a picture with a tape measurer extended from the mounting surface to the bottom of the box? Basically straight back, 90deg from the baffle face.
filtor1 Aug 10, 2008 06:34 PM
Oh yeah, you may be able to invert the subs if they would clear that center piece.
Another thing I was thinking of is making a ring to give you enough spacing for the sub and mirror that on the tweeter mid combo in the center. :) Just brain storming a little.
Orgullo Aug 11, 2008 05:51 AM
Yeah... I thought of making another sub ring to give a little more space. I'd need to do that if I wanted to actually paint the sub boxes in the future. With it wrapped you'd see a lot more detail, which is straight.
I'll take the measurements today when I get home from work.
filtor1 Aug 11, 2008 10:08 AM
Sweet! I will be home today. :)
MrDave Aug 11, 2008 12:06 PM
Gees
Orgullo Aug 11, 2008 04:18 PM
Que? :gotme:
