Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   Amp won't turn on anymore (https://maxima.org/forums/audio-electronics/589252-amp-wont-turn-anymore.html)
Kevlo911 May 1, 2009 12:39 PM
My amp blew a fuse about 2 weeks ago. I replaced the fuse and it worked fine. Today, on my way home, the audio cut off randomly. The fuses are fine but none of the lights come on the amplifier anymore. I checked all the wiring 2 weeks ago and it was fine, I do not thing anything happened between then. I have a US Acoustics 4 channel amp.
Any ideas? This sucks. Finals just ended and I have to drive 4 hours home in 2 days :(
slow_n_low May 1, 2009 01:25 PM
and you checked all fuses both under the hood and left of the steering wheel?
Kevlo911 May 2, 2009 01:45 PM
Why would I check those? It is an aftermarket amp, it has its own wiring.
AscendantMax May 2, 2009 01:57 PM
i would check the main fuse on the power cable again. i had instances where the fuse looked fine but the middle metal piece somehow broke off from the end caps. did you check the fuses on the amp itself? (if any)
maybe there's a wire accidently grounding itself somewhere?
slow_n_low May 2, 2009 03:03 PM
check them because two days ago i was working on the car a cut 2 wires together by accident and puff there went the fuse. amps shut off . checked every fuse and it was one under the hood. my problem solved.;
AscendantMax May 2, 2009 10:47 PM
how would that affect an aftermarket amp with its own wiring though?
nismos14 May 3, 2009 01:05 PM
Even a fuse that looks okay can be blown..
Did you ever figure out why the amp blew a fuse?
Kevlo911 May 3, 2009 06:02 PM
Don't know why it blew a fuse, fixed the problem; had to clean the fuse contacts on the amp some reason :noes:
Working great now though.
Fast1one May 3, 2009 06:10 PM
Interesting, what was on it?
Kevlo911 May 4, 2009 09:56 AM
Old plastic from the blown fuse
