12 12's or 18 10s?
im rebuilding my maxima this winter and im trying to piece together everything
so far im going to be running either 12 12's or 18 10's im leaning towards the 10s because its alittle more cone area and its more of a "wow" factor...also the design is a sealed clam shell... im buying cheaper subs to start me off because i gotta be my car painted and do afew more electrical upgrades... Once everything is set in stone ill be running 12 Fi Qs or 18 Fi SSD 10's pros of the 12s are: -less woofers to wire -cheaper than 18 10's -easier to wire (6 gp3000ds 2 woofers per amp) cons -little less cone area -heavy to mount(remember i be laying on my back installing 6 woofers) pros of the 10s are: -more cone area -lighter to mount upside down cons -cost more :( -more weight over all -more wiring (3 woofers per amp) |
Wow. That will be loud. I say go with the 10's. They have a bit crisper sound. My buddy has 24 10's in an Astro van. Keep us posted...
Originally Posted by 321VQ35MAX
(Post 7123436)
BTW my buddy randy aka assman has 24 10s in his asstro also :) |
No, a guy here in Sanford that owns a stereo shop.....
10s won't sound 'crisper' than 12s.
but if you want loud, go with more cone area. but do you have enough power to power the additional 10s compared to the fewer 12s? |
Whatever you do, post pics.
Originally Posted by AscendantMax
(Post 7123469)
but if you want loud, go with more cone area. but do you have enough power to power the additional 10s compared to the fewer 12s? the 12s can handle 1500wrms and the 10s can handle 1000wrms..so everything works out about perfect..
Originally Posted by nismos14
(Post 7123505)
Damn. Where are you gonna fit so many subs?
Isn't that loud enough to break glass haha |
Originally Posted by exsjulio
(Post 7123514)
Isn't that loud enough to break glass haha and we shall soon find out... |
Nice ride man. Goodluck on that setup.
the FI's weren't loud enough for ya?
Why don't you don't use both? Say four 12's and twelve 10's...that should help you cover some frequencies better depending on what music choice you've got selected at the time...
(Post 7123582)
Anyway, I'd say go with the 12's...either way, get more batteries I think :) |
Originally Posted by MadMax07SL
(Post 7123688)
I would personally prefer less subs of better quality. I also prefer the SQ of 10's over 12's given the same sub.
Originally Posted by Virus
(Post 7123752)
(Post 7123436)
I say go with the 10's. They have a bit crisper sound..
Originally Posted by JEXTEL
(Post 7123512)
for sure! i cant wait to tear out the system and start on a new one..
Can I borrow just a small amount or your time, energy and will ? :laugh:
(Post 7123688)
(Post 7123752)
I'd just go with whats cheaper, that way if something goes wrong or you miscalculate cost its not as bad (or does it add up to the same amount?). Either way, if done properly it will slam, I love Fi woofers.
18 ssds RMS: 14,400w 12 Qs RMS: 12,000w The amount of 12s require less power. |
Originally Posted by mendon99
(Post 7124229)
12-12's Ftw yeah you gotta post pics must see this Lol
Originally Posted by SteveB123
(Post 7124258)
To do what? Listen to sine waves?:laugh:
thanks for the input fellas..
and yes i have 2 Fi BTLs 18s now..there "ok" i want louder/air mover!! far as the power going to the woofers it will be the same "18kwms" (6 gp3000d pros) and 11 batteries (and yes i know its alittle over there RMS :) ) and to clear up some responses to the whole 10s sound better or 12s sound better..etc im pretty sure its 80% install and 20% equipment..yes the 10s are smaller meaning less "actual" mass to move.meaning a quicker response but i dont think that would make that big of a difference for a human ear to pick up..maybe a 10 compared to an 18? |
How does the math work out for enclosure size?
whats about 10 10's and 4 12's???
(Post 7123714)
not a good mixing different size speakers...
i think mixing subs of the same brand but different sizes is perfect just because you will here all the tight bass without sacrifising the boomy volume,
(Post 7125330)
I dunno whatchu guys are talking about. I got 3" subs in my dash, 4" subs in my kicks,2 5", 6", 7", and 8" subs in my doors, then 15 super tweeters per door, and 2 8", 2 10", 2 12", 2 13", 2 15", 2 18", and 1 32" (for the low lows) in my trunk.
mmm 15" super tweeters
(Post 7125382)
Why you dissing on my setup? Everyone knows not to run 15" super tweeters, I run 15 1"ers per door not 15"ers, jerk. :kiss: |
win.
(Post 7125251)
im also considering 4 18s "ported" also..(i know for a factill be in the 155 dB range with this setup) |
(Post 7125366)
(Post 7125504)
for the 12s it about 1.4 per woofer and the 10s its .46 per woofer..thats after dispalcement
(Post 7125504)
(Post 7125504)
(Post 7125551)
How do you know this for a fact?
theres a expo doing mid 56's with 4 18 btls and 4 gp3000d and only 4 hc2400 batteries.. also the maxima cabin is alot smaller compared to the expo so its less room to pressurize but you are right there are many factors to acutally be 100% sure..but im a good 75% sure it'll be in the 155 dB range "hopefully" :) |
(Post 7125504)
im also considering 4 18s "ported" also..(i know for a factill be in the 155 dB range with this setup) How on earth are you going to fit that in a Maxima? |
(Post 7125945)
well a good rule of thumb is you double everything(batteries, subs and amps) it should raise 3-5 dBs..
10 db change is 100 times the power, etc...on the drawing board, anyways. Once you start getting to the physical limits of amps and drivers, all bets are off. |
IMO i would go with 4 18s. the whole 12 or 18 subs is kinda nonsense TO ME to have that many subs. steve meade from youtube is my reason for saying 4 18s take a look at his tahoe he also has a civic with 2 18s walled off like ur car im sure is.he built an escalade with 8 18s as well
| All times are GMT -7. The time now is 11:06 PM. |
