Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   02 maxima where's a good ground? (https://maxima.org/forums/audio-electronics/678279-02-maxima-wheres-good-ground.html)
maximasicilian123 May 26, 2014 10:45 PM
I got an amp going in protection mode and I can't figure out why. I replaced all wires and speakers are good. Right now I have my amp mounted in back of the fold out seat. Its grounded in the trunk, right behind if u were sitting in the back seat driver side. There's a bolt and nut there.
Fakie J Farkerton May 27, 2014 03:41 AM
Strut tower makes a great, if not the best ground.
Pearl96Max May 29, 2014 08:29 PM
I would disagree, too much friction.
Fakie J Farkerton May 29, 2014 10:03 PM
:wtf:
http://www.caraudio.com/forums/wirin...ing-point.html
http://www.stevemeadedesigns.com/boa...-ground-wpics/
:gotme:
I know plenty of people, including myself, with a strut tower ground for years and never an issue.
Local audio shop also recommends either frame or strut tower.
Pearl96Max May 30, 2014 12:35 AM
Originally Posted by Fakie J Farkerton (Post 8956305)
:wtf:
:gotme:
Because someone does something it makes it right ? Or proper ? Because it works (for some) makes it right ? Or proper ? If I just shoot a self tapper through painted sheet metal in the trunk and it 'works' does that it make it correct or something that should be recommended ?
Others will also say seat belt bolts, and they 'work', but hey are also covered in loctite/teflon/etc. also doesn't make it right.
Where are the measurements both still and moving shown ? I would definitely be interested in the read.
Fakie J Farkerton May 30, 2014 09:51 AM
Originally Posted by Pearl96Max (Post 8956326)
Because someone does something it makes it right ? Or proper ? Because it works (for some) makes it right ? Or proper ? If I just shoot a self tapper through painted sheet metal in the trunk and it 'works' does that it make it correct or something that should be recommended ? Others will also say seat belt bolts, and they 'work', but hey are also covered in loctite/teflon/etc. also doesn't make it right. Where are the measurements both still and moving shown ? I would definitely be interested in the read.
Did you read the links I posted?
Both are reputable sites with several people with very high powered systems stating that the strut tower is a great mounting point.
Why you mad?
You can post links showing what you're talking about. I'm done with the homework.
Pearl96Max May 30, 2014 10:18 AM
Why you mad?
Did You read my post ? Apparently not, since there were questions in it that you ignored. I guess ignorance Is bliss ..
Mad ? I am laughing ! Keep being the sheep, I'm fine with that.
Fakie J Farkerton May 30, 2014 10:26 AM
Originally Posted by Pearl96Max (Post 8956443)
Did You read my post ? Apparently not, since there were questions in it that you ignored. I guess ignorance Is bliss .. Mad ? I am laughing ! Keep being the sheep, I'm fine with that.
I'm reading disagreements without proof to merit and no suggestions. :lol: is right.
Pearl96Max May 30, 2014 10:36 AM
Oh, so you're reading the same post I read and you made. I get it. Yea, I'm still laughing too. I figured you wouldn't reply with any actual evidence.
Fakie J Farkerton May 30, 2014 10:45 AM
:facepalm:
Thanks for all your help.
Pearl96Max May 30, 2014 11:27 AM
Originally Posted by Fakie J Farkerton (Post 8956452)
:facepalm:
No problem. Thanks for actually providing credible responses. :rolleyes:
The_Fixer May 30, 2014 02:18 PM
Actually the strut tower is a very good grounding point just remove one of the 14mm nuts then sand down to the metal apply some dielectric grease then bolt your ground down tight.idk what this other guy is talking about but the strut tower does not move! If you want to do it differently buy a ground block locate a area then drill a hole sand the area then use nuts and bolts to fasten it to the car.
Fakie J Farkerton May 30, 2014 02:22 PM
:ben:
