Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   tv's in my headrest (https://maxima.org/forums/audio-electronics/73406-tvs-my-headrest.html)
hockeyghst Feb 21, 2002 10:40 AM
tv's in my headrest
ok well i got the tv's mounted im my headrest but here is my problem i dont knwo how to run the wires through the top of the seat all the way to the bottom of the seat....if u look on the abck of a seat in the 4th gen amxima it seems as if there is a thin board going down the abck of the seat.....is there anyway i cna get this peice off??? if so this will make my job a lil easier.......
thanx, Tom
max'n out Feb 21, 2002 12:58 PM
You run the wires down through the metel brackes that lock them in and then you can pop off the back side of the seat there held in by some snaps, just be carefull the break easy. Then take it the whole way down.
hockeyghst Feb 22, 2002 07:53 AM
the cable comming off my tv is not thin enough to be fit through those metal poles in the headrest...is that wha tu mean by metal brackets??? my main concern is getting the back of the seat off.....can you or someone else give some more details....how many clips r holding in the back of the seat??? where r they located... things liek that.......thanx guys, Tom
max'n out Feb 22, 2002 10:11 AM
Yeah the metel poles. Can you drill um out? There are 4 plastic cheap clips 2 on each side at the edge and a set metel brackets at the top. Pull up and out from the bottom and you will feel them start to pop then pull down so the metel peices let it drop. Be very carefull there cheap.
hockeyghst Feb 22, 2002 09:09 PM
ok i understnd how to take the abck of the seat off but i dont think i understand the metal poles u r talking about....r u taling about teh metal poled on teh headrest itself...????even if i drill tehm out the tv cord wont fit through it.......thanx for the info!!!!
max'n out Feb 22, 2002 09:59 PM
Yes the metel poles that hold the headrest to the seat. If you don't run the wires down through there your gonna see the wires. Why woun't they fit more others always seem to?
hockeyghst Feb 23, 2002 09:49 AM
ok i see whjat ur saying now. ur talking about the mtal poles in the seat correct???.....the reason it wont fit is because there is a fat plug on the end of the cord that connets into my lcd screen so what plug wont fit thtough the metal poles
BLACKIE Feb 25, 2002 02:24 AM
Headrest Monitors
Did you do all the work yourself? Did you just take of the cover cut the foam in the haedrest the mount it with the shroud. On a scale of 1-10 how difficut is it to install the TV's. Thanks Charles
hockeyghst Feb 25, 2002 09:49 AM
Re: Headrest Monitors
well at first i was gonna call a shop to install them but i said the hell with that and i did it myself......it is VERY easy
hmmmmm im gonna say 1 being the easiest and 10 being the hardest...
def. a 1
i took the cloth cover off....then i took the headrest bracket and made some measurments on the foam b4 i cut.....then after making sure everyhting is straight i started cutting using a razor blade.....very easy....then i took out enough foam out so the headrest bracket will fit in nice and snug....after this was done i cut 2 lil slits on the bottom of the headrest so i can shove 2 small thin peices of wood behind the headrest bracket so i can screw the headrest into something to secure it from falling out.......its kinda hard to explain i guess and i dont have any pix....sorry........basically in the end it took about an hour to do the first one only because it was my first time trying this when i start the second one im sure i cna get it done in about 30 min....liek i said not hard at all!!!
BLACKIE Feb 26, 2002 12:26 AM
Re: Re: Headrest Monitors
THANKS
def. a 1
pawn Feb 26, 2002 08:36 PM
what kinda tv's did you use...how much were they, where'd you get them!
BLACKIE Feb 26, 2002 11:56 PM
I purchased them from Partsexpress.com also from Kenwood.
hockeyghst Feb 27, 2002 09:41 AM
well i dont have that much money for expensive tv's but i bought 2 tv's from ebay at 89 $ each. it came with the headrest bracket and its a 5 inch lcd screen....the picture quality is good but with a kenwood tv or a good name brand like that it will be much better......
pawn Feb 27, 2002 10:27 AM
i just bought 2 5.6" tv's :D
hockeyghst Feb 27, 2002 10:36 AM
from where????
is ur car photoshopped in that pic or air ride or coilovers????
looks nice and low
pawn Feb 27, 2002 10:41 AM
from where????
looks nice and low
Ebay...in the pic its on Coilovers, but the air suspension is being installed!
hockeyghst Feb 27, 2002 09:51 PM
do u have a link to the tv's that u bought???
pawn Feb 27, 2002 09:55 PM
maybe, why?
hockeyghst Feb 28, 2002 07:53 AM
maybe, why?
cuz i wanna see what they look like.......thats all
