Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   Audio and Electronics (https://maxima.org/forums/audio-electronics-21/)
-   -   2 12" JL W6's and 1 Kenwood 1000 Watt KAC - 929 AMP, Question? (https://maxima.org/forums/audio-electronics/87681-2-12-jl-w6s-1-kenwood-1000-watt-kac-929-amp-question.html)
JetBlackMax May 10, 2002 10:26 PM
Knowing the amp is 2-ohm stable, is it possible in anyway, for me to Bridge these 2 Subs, without the Amp Cutting off?
Thanx
jmax May 11, 2002 07:19 AM
First of all the amp isn't 1000 watts. That's the max power consumtion. RMS output is 230 X 2 at 2 ohm stereo. And that's the lowest you want to go to avoid bad sound and the amp cutting off. It's fine because you have a stereo 3 ohm load. Or you could bridge it to 6 ohms. Your choice.
