Autox help...input needed
Today was the 3rd solo 2 even I've participated in and I seem to be stagnant. I ran a longer course today, but it was faster than the course I've previously run. I have figured out the tire pressure...45-50lbs in the front and 50lbs in the rear works well...anyone with a 6spd have any input on what gear they run in...ran good times in 1st gear because it kept me smooth and I didn't get myself into any trouble and I've got the power to grunt out of the corners...2nd is nice because I have a wide powerband to use, but find it a little low on the power...equivelant times in both 1st and 2nd gear...
2nd...what class are you guys running? i ran in street mod. 245/40-18s, tokico's and vogtlands, stb and rear sb, poly mm and shifter bushings, upgraded clutch and lines, intake, exhaust, underdrive pulley. I also have a CF hood...that is what as I understand puts me in SM. check www.cnyscca.com for today's event times and last mo's event times...look on pg 2 for the first event. i am the only maxima. i haven't looked at the times from today yet but they should be up momentarily. chime in and let me know what your thoughts are. thanks. i have a ltb to install too, but i think the falken 512's are the weak link at this point.
1. those tire pressures sound a bit high....at those pressures, you may not be getting all the tread on the road. I run about 40psi front and 45 rear these days, and my VQ30 is heavier up front than your 3.5....You might be overcompensating for the soft sidewalls of the 512's.
2. The 512's are a decent all-season tire, but NOT up to the task of autocross. I suggest you pick up some "summer" tires (UHP) or popular, inexpensive autocross tires (Hankook Ventus RS-2s or Falken Azenis), which will provide stiffer sidewalls and better grip. Also, you will destroy the soft-compound 512's in no time. Definitely your weak link for autocross.
3. 1st gear? That sounds odd, unless it's a REALLY small course. Most autocrosses I go to, the only cars that even try to run in 1st are the S2000's with their 9000rpm redline. I run almost all courses in 2nd (and I have a 5speed) - if you're a 6mt I suggest running in 2nd. The 3.5 definitely has enough torque to power out at mid-rpms when needed.
It would be useful if you could post a pic or video of the course - then we'd have a better idea of what you're looking at and how to approach future events.
thanks for the input. i appreciate it. i hate getting beat by a domestic turd 20yrs old!
how come you're running dsp?
more comp?
as for your feedback. I did go that high to prevent the sidewalls from buckling under. maybe a bit too much. last track day i had them at 45 and that seemed pretty good but chewed the tires up pretty bad. the pics I have are very limited. the track was pretty long, but the course design kept it from being really fast. it was faster than the last course. i have a few pics but have to upload them and i have got to get to bed...gotta work in the am
i'll try to get them up tomorrow
thanks again for the input
more comp?
i
CNY SCCA
Final Results, #2 - CNY NYS Fairgrounds 1 - 6/11/2006
Total Registered: 64, with Times: 63
'Super Stock' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 83 47.603 45.564+DNF 45.627 44.974+1 45.313 43.826 43.826 -
'A Stock' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1Tm 17 Mollura, Mike 2001 Porsche Boxster CNY 47.924 46.394 45.998 45.090 45.243 44.816 44.816 -
'B Stock' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1Tm 72 Todd, Eric 1991 Toyota MR2 CNY 48.153 47.287 56.579+DNF 46.294 45.558 46.925 45.558 -
'D Stock' - Total Entries: 3 Trophies: 1 Region Times Total Diff.
1Tm 941 Parrow, Chris 2006 Subaru WRX 48.554 49.099 46.907 46.457 46.408 46.226 46.226 -
2 m 68 Izyk, John 2003 Subaru WRX CNY 49.654+1 48.650 48.740 47.734+1 47.511+1 47.589 47.589 1.363
3 9 Sims, Dave 2004 Subaru WRX dns 47.589
'E Stock' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 8 Newton, Scott 1987 Porsche 944 51.432+DNF 51.069 50.107 48.509+DNF 49.614 52.182+1 49.614 -
'F Stock' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1Tm 7 Conway, Robert Infiniti G35 52.171 48.356 49.445+1 47.879 48.008 47.698 47.698 -
2 14 Kerestedjian, Paul 1968 Ford Mustang 60.089+DNF 61.967+DNF 58.139 57.110 49.792 56.138+DNF 49.792 2.094
'G Stock' - Total Entries: 4 Trophies: 2 Region Times Total Diff.
1Tm 11 Buchman, Brian 2005 Acura RSX-S 44.644+DNF 43.652 42.853 43.055 43.208+3 42.670 42.670 -
2Tm 91 Kramer, Joe 2006 Mini Cooper S CNY 46.678 45.403 44.400 44.277 45.931 45.510+DNF 44.277 1.607
3 m 14 Elve, Charlie 54.279+DNF 50.318 49.063 50.081 48.348 48.327 48.327 4.050
4 69 Poniros, George 2003 Nissan Altima 50.772 49.403 49.275 52.441+DNF 50.402 49.065 49.065 0.738
'H Stock' - Total Entries: 5 Trophies: 2 Region Times Total Diff.
1Tm 711 Bizzozero, Mark 2004 Mini Cooper CNY 56.633+1 46.327 46.529 46.014 46.822 46.491 46.014 -
2T 53 Quinn, Michelle 1999 VW Beetle WNY 51.816 49.294 48.781 49.896 48.480+1 48.275 48.275 2.261
3 m 73 Moreau, Dave 1973 Triumph GT6 54.308 50.683 51.670 49.303+1 49.601 49.326 49.326 1.051
4 86 Lecara, John 2000 Honda Civic 57.260+DNF 56.299+DNF 53.874+1 54.485+DNF 54.748+1 53.043 53.043 3.717
5 68 Ohlbaum, Paul 1997 Honda Civic HX 56.248 54.414 54.178 53.630 53.252 54.074+3 53.252 0.209
'C Street Prepared' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1Tm 85 Donofrio, Anthony 2004 Dodge SRT-4 CNY 46.865 43.546 43.681 44.194 43.985 43.480 43.480 -
2 m 91 Donofrio, Mike 1990 Mazda Miata CNY 44.279 44.093 43.539+DNF 44.512+1 51.949 47.258 44.093 0.613
'E Street Prepared' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1Tm 16 Phillips, Oliver C. 1987 Chevy Camaro CNY 55.628+1 51.651+DNF 50.506 44.169 49.601 48.262 44.169 -
2 m 88 Stojkovski, Ted 1988 Ford Mustang CNY 51.069 50.029 49.415 51.479 50.145 56.803 49.415 5.246
'B Prepared' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 11 Meyer, William 1965 FF Cobra 44.636 46.781 45.862 45.547 44.880 44.254 44.254 -
'E Prepared' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1T 42 Hughes, Karl 1884 VW Rabbit 44.855 43.876+ 44.510 44.082 44.135 44.011 43.876 -
2 m 142 Coffin, Jon 1984 VW Rabbit 45.317+1 45.341 44.912 44.888 46.517+1 44.346 44.346 0.470
'F Prepared' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 47 Darminio, Mike 1973 Porsche 914 53.128 49.639 48.464 47.692 47.932 47.190 47.190 -
'A Modified' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1Tm 4 Mogle, Richard 2006 Ram CNY 52.124+DNF 50.492+1 48.398+1 47.240 56.125 48.109 47.240 -
2 m 99 Hidy, Lee 1989 March Hare 63.130+DNF 53.002+DNF 53.864 51.854 55.627 51.428 51.428 4.188
'B Modified' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 17 Gressel, Steve 1992 Formula Renault 102.039+DNF 41.956+DNF 60.175+DNF 63.532 42.858 44.086+DNF 42.858 -
'E Modified' - Total Entries: 3 Trophies: 1 Region Times Total Diff.
1T 11 Riesbeck, Jason 1986 Mazda RX-7 44.765 43.963 43.764+1 42.818 43.393+1 43.073 42.818 -
2 m 22 franklin, rex 1962 MG Midget 44.859 45.119+1 44.601 47.445+DNF 44.077 43.698 43.698 0.880
3 m 122 Franklin, Tammy 1962 MG Midget 51.370 51.879 49.571 50.310 50.113+DNF 48.755 48.755 5.057
'D Modified' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 77 Sawyer, Leo 1989 Lotus 7 Repl 47.326 44.791 45.548 45.629 44.900 44.639+1 44.791 -
'F Modified' - Total Entries: 2 Trophies: 1 Region Times Total Diff.
1Tm 48 Ciarlei, Brian 1998 Red Devil F440 CNY 43.503+DNF 40.556 40.414 40.728 40.263 66.366+DNF 40.263 -
2 148 Ciarlei, Sara 1988 Red Devil F440 50.856+1 52.343 57.620+DNF 48.596 49.351 47.406 47.406 7.143
'Street Touring (Tire)' - Total Entries: 10 Trophies: 4 Region Times Total Diff.
1Tm 168 Hirschey, Pete 2000 Subaru Impreza 2.5 RS CNY 49.074 47.278 46.721 46.545 45.826 46.572+1 45.826 -
2Tm 43 Sager, John F. 1995 Plymouth Neon CNY 48.372 48.110+2 47.317+1 47.063 46.305 45.643+1 46.305 0.479
3Tm 27 Moseley, Garrison 2001 Subaru Impreza 2.5 RS NEPA 49.837 48.142 46.611 47.269 50.539+1 47.452 46.611 0.306
4T 90 Bauer, Erik 2004 Chevy Cavalier 47.879+1 47.684+2 47.278 47.884+1 48.618+2 47.948+1 47.278 0.667
5 9 Tran, Vinh 2002 Mazda Protege 50.096 48.667 47.911 48.414 48.040 48.277 47.911 0.633
6 311 Andrews, Deric 1998 Subaru Legacy 49.788+1 50.113 50.113 2.202
7 m 8 Marsden, Andrew 1995 Honda Civic EX 55.850 53.248 51.481 50.489 53.339+DNF 50.758 50.489 0.376
8 m 143 Sager, John W. 1995 Plymouth Neon CNY 51.621 51.354+DNF 49.227+DNF 51.072 53.247+1 51.976 51.072 0.583
9 7 Brkich, Richard 2003 VW GTi 57.503 54.651+DNF 53.222 51.102 51.102 0.030
10 m 14 Turner, Greg 53.483 52.175 52.776+DNF 52.053 55.892 52.469 52.053 0.951
'Street Touring X' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1T 11 Haas, Evan 2005 Subaru WRX 47.526 48.142 47.149 45.867 46.018 45.507 45.507 -
'Street Modified' - Total Entries: 3 Trophies: 1 Region Times Total Diff.
1Tm 79 Gravius, Mark 1985 Chevy Camaro CNY 45.784 45.315+DNF 45.914 45.036 71.484 44.435 44.435 -
2 2 Schorer, Wm. Cale 2002 Nissan Maxima 50.889 51.335+1 49.098 47.525 47.773 48.723 47.525 3.090 3 This is my bro in law...11 Lebied, Peter 2002 50.194 52.386 50.126 48.618 48.171 48.172 48.171 0.646 'F125 Shifter Kart' - Total Entries: 6 Trophies: 2 Region Times Total Diff.
1Tm 4 Heffron, brian Kart 43.226 42.020 60.438+DNF 44.954 42.312+1 40.400 40.400 -
2Tm 54 Heffron, Ed Kart CNY 41.651+ 40.801 48.323+2 45.502 40.716+1 40.001+1 40.801 0.401
3 m 5 Corey Heffron Kart 43.209 43.446 48.267 43.618 41.694+DNF 41.511 41.511 0.710
4 m 11 Cartini, Jay Kart CNY 44.024 48.444 51.321+1 42.371 43.195+DNF 42.042 42.042 0.531
5 57 Smith, Chris Kart 48.091+1 44.009 43.154+DNF 42.241+DNF 43.549 43.152 43.152 1.110
6 m 48 Nagle, George Kart CNY 58.995+ 53.532+1 52.264 50.702 50.022 48.462+DNF 50.022 6.870
'Junior Kart 1' - Total Entries: 1 Trophies: 1 Region Times Total Diff.
1Tm 3 Cartini, Hollie Kart CNY 72.562 66.998 65.509 64.570 63.614 62.681 62.681 -
'Junior Kart 2' - Total Entries: 3 Trophies: 1 Region Times Total Diff.
1Tm 18 Mogle, Caye Kart CNY 54.699 54.951+1 51.492 49.401 49.960 48.840+1 49.401 -
2 m 181 Mogle, Jonathan Kart CNY 52.407 51.903+1 60.438 53.297 57.936+1 51.371 51.371 1.970
3 3 Furco, Tara Kart 62.674 53.632 48.557+DNF 53.864 53.632 2.261
'Novice' - Total Entries: 5 Trophies: 2 Region Times Total Diff.
1T HS 8 Loudner, Michaael 2004 Mitsu Lancer 53.449 51.816+1 51.066 54.261+1 53.237 51.223 39.831 -
2T GS 55 Larson, Joshua 2004 VW Jetta 52.694+DNF 54.336 50.454 50.260 51.064 51.559+DNF 39.906 0.075
3 FS 41 Bizzozero, Don 2006 Mustang GT 53.268 53.087 56.121+DNF 51.017 51.229 49.854 40.132 0.226
4 STS 102 Abbatte, Gerard 1998 Subaru Outback Sport 53.329 52.258 51.245 50.670 40.384 0.252
5 FS 13 McCullough, Thomas 1997 Lincoln Mark viii 54.642 52.652 51.846 53.307 51.411 51.197 41.213 0.829
Top Times Of Day Time Class # Driver
Raw time 40.263 FM 48 Ciarlei, Brian
Pax 33.880 GS 11 Buchman, Brian
Stock 42.670 GS 11 Buchman, Brian
Street Prepared 43.480 CSP 85 Donofrio, Anthony
Prepared 43.876 EP 42 Hughes, Karl
Modified 40.263 FM 48 Ciarlei, Brian
Touring 45.507 STX 11 Haas, Evan
Street Modified 44.435 SM 79 Gravius, Mark
Kart 40.400 F125 4 Heffron, brian
Junior Kart 49.401 FJ2 18 Mogle, Caye
Novice 39.831 NHS 8 Loudner, Michaael
CNY SCCA
more comp?
more comp?
At events, it's a good idea to use white shoe polish (in the bottle) to make small marks along the edge of the tire tread, so you can see how far the tire is actually rolling over, and adjust air pressure to get it right.
I run DSP because its actually a bit slower around here. STX in this area is SUPER popular, and tons of fast, heavily-modded cars are in it - particularly Subaru Imprezas, Honda Civics, and several other fast types. DSP is usually a couple very quick Hondas and several larger sedans (Saabs, Maximas, etc).
I have no chance of finishing top-3 in STX (usually about 20 cars at local events in that class) whereas DSP usually has 6-10 cars, only about 1/2 of which are very competitive. Yeah, I'm weak for doing that, but a top-3 gets me tire contingency money from Hankook, so I have to go after that!!
you can see the shoe polish on the tires in this pic:
TonyJr
08-20-2015 12:14 AM
