SFC's soon SCCA SP legal
Ok, lots of abbrevs in that. Means SCCA is in process of allowing SFC's into the D Street Prepared autocross catagory and it wouldn't force us into the E Prepared class. No X-bracing though :banghead: Think of it as a 1.6sec time drop (60sec course)
The following previously-published change proposal has been reviewed and recommended by the SPAC, is being recommended to the BOD by the SEB, and is published here again for member reference: Insert new section 15.2.E after 15.2.D and re-label subsequent sections of 15.2 accordingly: “E Longitudinal (fore-aft) subframe connectors (“SFCs”) are permitted with the following restrictions: 1. They must only connect previously unconnected boxed frame rails on unibody vehicles. 2. Each SFC must attach at no more than three points on the unibody (e.g. front, rear, and one point in between such as a seat mount brace or rocker box brace). 3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in between. 4. No cutting of OE subframes or floorpan stampings is permitted. Drilling is permitted for mounting bolts only. 5. No cross-car/lateral/triangulated connections directly between the driver’s side and passenger’s side SFCs are permitted. Connections to OE components such as tunnel braces or closure panels via bolts are allowed and count as the third point of attachment. No alteration to the OE components is permitted. 6. SFCs may not be used to attach other components (including but not limited to torque arm front mounts or driveshaft loops) and may serve no other purpose.” http://www.scca.com/_FileLibrary/Fil...full-final.pdf |
wow...that is GREAT news.
too bad the Warpspeed and Truax SFCs attach in 4 points. grr. |
Originally Posted by Bufflomike
What if you are a newb, will they still let you run in an amateur class? I want to try "pine cone racing" (what the wife calls it) and I dont want to embarass myself
You won't embarrass yourself, it's only much later when you've done it a while that you realize you sucked when you started. However, when you see other new guys out there, you won't tell them, if anything you'll encourage them and tell them they did fine. As a newb, you're going to over drive your car, or underdrive it, you can't understand what I mean until you start doing it. Even on a real track going 100mph+, same thing, motions are different at 100, but thought process is the same. I can honestly say that only one season did I see a "newb" kid out there that was really, really bad. He was embarrassing for a couple reasons. Although people gave him credit for trying to run his Geo Metro, he never went out and memorized the course. That fact would frustrate the instructors he would ask to ride with him because he would go off course almost every run. Here is where it would be embarrassing, I remember getting in the order right behind him for a heat, where as the runs (at Ripken) are 45-60seconds, he would go off course, hit cones trying to get back on course and in general screw the course all up, AND he would take 100 seconds to do it. So I would have to wait another 2-5 minutes after he finished to start. |
this is interesting...but I have the x brace too...oh well...
[/URL] |
Originally Posted by gdmaxse
GREAT... too bad I am 5 seconds behind the nationally prepared DSP BMWs in my region. And that is when I am driving at the limit of my car.
I'm lucky, no one who runs in DSP ever shows up in my region...sometimes there'll be an ae86 or mustang...
but you should just run EP as per irish's suggestions... |
Gabe, you're running DC this year instead of Philly, right?
How is the DC EP group? Was pretty weak for Philly (and DSP at Philly is fast)..... that's why me and you have all these pint glasses :grinno: |
http://forums.maxima.org/showthread....23#post5783323
There's a set of nice SFCs for sale, the redesigned ones... |
How is the DC EP group? Was pretty weak for Philly (and DSP at Philly is fast)..... that's why me and you have all these pint glasses :grinno: That is with me driving good lines and close to the limit of my car... so basically, I will never catch the bimmer. there is also an e46 323 that is 1-2 seconds ahead of the e30 EP is about 3-4 seconds behind me so it may be possible to take that class on street tires, there is a caged honda crx on RA1s and a gutted datsun 510 with 10" slicks The courses at FedEX are much more wide open than ripken and the lot is easier on tires. The only problem is there is about a 15 minute window when you can sign up otherwise you are on the waiting list. I will most likely do the events at ripken as well. |
may be until August-Sept timeframe before I run this summer, thanks to the moving and 3 weddings to got to....
in other news, the GT6 was prepared today to be towed up, as soon as I get the new house with garage I'll be taking a buddy's Titan down with a trailer to pull it :woot: |
If anyone wants a set of sfcs with only 3 mount points Pm me I can make some really easy for the 4th or 5th gen. Josh Your New X bracing should be on its way tomorrow.
This is pretty good news to a sfc builder. -Sean TMS |
But what about:
"3. SFCs must be bolted or welded, but welding must be to the OE subframe stampings, not to the floorpan in between." Do the factory frame rails count as "subframe"? |
Originally Posted by VQuick
But what about:
There is now a GB for 3 point tie in SFCS for $150 plus 25 for shipping in the Gb forum. There will be D street prepped legal.
-Sean TMS |
| All times are GMT -7. The time now is 11:58 PM. |
