Firestone Complete Auto Care-Dunedin FL-lousy
I had my 01 Maxima towed here back in 2014 after it just would start up then just die.
At the time I suspected the Alternator but I didn't have a jack to get the car up at the time. I did buy my 3.5 ton racing jack a year later but at the time I would've been getting it up with the emergency jack. If you are using the emergency jack definitely break down and get the 3 1/2 ton jack you wont be sorry. anyway I had it towed in and they said "no problem, alternator, no problem, Maxima no problem". we'll have it done in a few hours. So I gave em the job. $80 for a tow that was about a block from my house too. I got the car back after paying the $450. I immediately realized they blew a fuse and some of the lights were out. then I was getting a battery light and brake light too occationally at start up but assumed it was just from before. Car ran fine so I just really trusted them because they have the ASE affiliation and the Motorist Assurance agency affiliation. a few years later I was removing the compressor and alternator to get down to the water pump leak. as I began removing the alternator I realized the upper bracket was not even attached to the place where its supposed to be bolted to. It was a headless bolt. then I began to remove the pivot bolt and the nut was way too tight. So tight I had to cut it off with a Dremel tool. took me three days because it was in my driveway under the FL summer sun. Almost two bottles of Sunblock 50 too. make a long story short I got the bolt drilled out and installed a time sert I had left over from some stud holes I stripped out. https://cimg4.ibsrv.net/gimg/maxima....e233d77e74.jpg https://cimg6.ibsrv.net/gimg/maxima....c85871b5f4.jpg If you need your Maxima fixed I'd avoid Firestone Complete Auto Care in Dunedin FL. |
© 2024 MH Sub I, LLC dba Internet Brands
