Interior carpet and upholstery cleaning?
Hi so i purchased a 98 Maxima CG2 it has the light colored interior.
I've had it for about a year now. I want to really give the seat and carpets a good cleaning. The carpet and seats are not in the worst shape but i know they could be better. What is a good chemical/cleaner/degreaser/deodorizer that i could purchase as a all in one. Or maybe a combination of house hold cleaning solutions. I rather not go through product after product testing, but i know sometime that is required. Would need to be able to clean coffee,blood, oil,grease for example. The tool on hand at the moment are a wet dry vac and some round drill attachment upholstery brushes. The previous owner was a smoker, i am probably nose blind and would like to get the cigarette smell out. Once the weather breaks i will be purchasing a steam cleaner. Thank you. |
I highly recommend the steam cleaner...
but until then, get this stuff called FOLEX. White bottle, purple writing on it. Best carpet / upholstery cleaner I've found, hands down. |
Carpet cleaner
Don't know if u found a solution but I highly recommend Tuff Stuff it comes in a yellow can and is sold at autozone or walmart. Under 5 bucks
Who owned the car before you? Dexter????
Well, Folex is the way to go. Spray the area and scrub a bit and suck it up….. Depending on the stain you might need it to sit a little bit. The thing about being sold on steam cleaners it depends what you are cleaning. Because to break certain bonds it has to be hotter then what a steam cleaner can deliver, which is why chemical cleaners are used rather than heat sometimes. |
The Meguiars APC is a good all around interior cleaning and for carpet. The Tuff Stuff for spot cleaning.
Originally Posted by carlem9
(Post 9029422)
2 Attachment(s)
Wow. How long did this take SR? What you use an industrial steam cleaner!?!?
Took me less than 5 mins really. Nope used the Bissell Spot cleaner Pro. Don't think the Machine will do all that work for you. I did soak the mat and scrub with a carpet cleaner solution and stiff brush. Came out pretty much brand new to me.http://ecx.images-amazon.com/images/...L._SL1500_.jpg
Steam cleaner with Megs APC will surely get the job done.
© 2024 MH Sub I, LLC dba Internet Brands
