need help detailing. thanks
Can anyone help me identify what this is. Is it swirl marks or scratches. How should I go about removing them, if I can.
https://cimg6.ibsrv.net/gimg/maxima....87739ce381.jpg |
Hard to tell from the pictures, but I would try compound before anything else to see if it lightens up any bit
Originally Posted by AT978
(Post 9070263)
I'm at a loss. It looks pretty bad if that is after compound.
Originally Posted by follyburr
(Post 9070403)
I previously used Meguiar's G17216 Ultimate Compound. Previously, the hood, as seen on the pic, was really faded. It seemed as if it had accumulated a lot of oil or something of that nature. I used this compound. It effectively restored the paint to some extent. However, underneath that layer was these swirl/scratch marks.
Thats sun damage...only way to fix that is to get repainted and re cleared.
Given I havent washed it in 1-2 weeks,, there still seems to be clear. I've read 1 or 2 posts where it is suggest to wax immediately after applying compound. When I used compound, I got too lazy to apply the wax.
(Post 9069771)
https://cimg6.ibsrv.net/gimg/maxima....87739ce381.jpg My 07' red max was all most this bad and the only way I was able to remove them was sanding and polishing. My Roof is even worse and I haven't had time to do that yet.. https://maxima.org/forums/detailing/...ml#post9073775 Post more pictures lets see the whole thing.. |
Apparently it gets worse after a wash. and here is another angle. you can ignore the trash on the hood, dumb trees.
https://cimg1.ibsrv.net/gimg/maxima....b8e2afc36a.jpg
Originally Posted by SR20Power
(Post 9075062)
WOW! Well, to clear something up, swirl marks are scratches but I see your concern. At this point, those are deep *** scratches in your car. Post more pictures at different angles if you can.
My 07' red max was all most this bad and the only way I was able to remove them was sanding and polishing. My Roof is even worse and I haven't had time to do that yet.. https://maxima.org/forums/detailing/...ml#post9073775 Post more pictures lets see the whole thing.. https://cimg2.ibsrv.net/gimg/maxima....f252a3b5f0.jpg https://cimg3.ibsrv.net/gimg/maxima....ec800a36ce.jpg https://cimg5.ibsrv.net/gimg/maxima....bcb83bfe45.jpg https://cimg6.ibsrv.net/gimg/maxima....2a7e821bce.jpg https://cimg7.ibsrv.net/gimg/maxima....55fcd98c84.jpg https://cimg8.ibsrv.net/gimg/maxima....418758b758.jpg https://cimg9.ibsrv.net/gimg/maxima....5200f7fa24.jpg https://cimg0.ibsrv.net/gimg/maxima....2ba50bacf4.jpg https://cimg1.ibsrv.net/gimg/maxima....903afd187b.jpg https://cimg2.ibsrv.net/gimg/maxima....c62cdd2f0f.jpg |
(Post 9075062)
Clay down the paint and do a test spot. Use the least abrasive method. Try using a light cutting pad and m105.
Update please!!! :)
© 2024 MH Sub I, LLC dba Internet Brands
