221.55 WHP / 207.52 WTQ VQ30DEK Swap
Figured I would dyno the DEK swap again to see what power its at.
http://i5.photobucket.com/albums/y17...stDyno7-09.jpg SAE corrected 4th gear pull DEK swap, OEM DEK cams '95 fed spec ECU SMT-6 tuning Adjustable FPR - return style OEM NGK platinum plugs index matched OEM DEK white dot coil packs Amsoil intake & HTPerformance MAF adaptor with Frankencar midpipe 70mm Pathy TB Port matched 2K VI (switch over around 4800 rpm) 5th gen lower with no swirl valves Blehmco grounding kit OEM flywheel & crank pulley with all ancilleries hooked up 2001 AE clutch setup Cattman headers with the y-pipe part header wrapped Resontated 2.5" test pipe wrapped with header wrap 2.5" LSS mandrel bent catback with it's resonator wrapped with header wrap 2.5" Remus muffler section Amsoil engine and gear oil 51 pound tire/wheel combo - 17 x 8 MOMO arrows with 235/45/17 Falkens SMT-6 tune @ 12.7 ~ 13.0 A/F and +10 timing Conditions: 88.36 F, 29.70 in-Hg, Humidity: 23%, SAE 1.01 (500ft elevation) |
damn I think thats the highest dek dyno #'s I've other than dandymax, do you plan to extend teh rev limit since that thing was still making power
btw great job on the engine bay |
I'm thinking cuz it was tuned with SMT-6 instead of an S/VAFC.
Dandy runs an EU (and so will I soon :) ). Nice numbers! What's next for it? |
I'm waiting on those biki rom boards to come out so I can raise the rev limiter and re-tune with it. A 7200 rpm rev limit would help me alot.
The SMT-6 gets better results because it can advance timing as well as tune the A/F ratio. The EU is capable of doing the same and more. For the future I may header wrap the secondaries and gasket match them, convert to a returnless fuel setup, and try those intake manifold spacers NWP is selling. |
Yeah i agree i bet you have a extra 10 hp hiding still.
But those are some awsome #s for 3.0 |
Very good numbers for the setup Joe, that's about what I had with my DE+00VI.
Definitely needs more revs, and I'd be interested to see where the peak is... a lot of DEK dynos tend to peak a little lower than DE+00VI from what I've seen, but of course as you know there's more to it than just the cam difference. |
:eek: beautiful from the DE-K
damn go 3.0L
Joe.....Amazing however I am not surprised that motor has always been strong, I will catch up with you next time your in the area maybe you can take me for a spin.
damn thats solid, lol @ those torks its pretty much a line not even a curve
(Post 7111430)
Originally Posted by Zack342
(Post 7111404)
wow very good numbers
Originally Posted by 98SEBlackMax
(Post 7111734)
It is funny the TQ on this car makes it feel slow. Since there is no sudden surge of power the car feels slow and smooth on highway pulls, then the speed gets into the triple digits pretty quick. :laugh:
how easy is the SMT-6 to use and install, this is the first time im hearing about it, ur AFR is dead on through the whole powerband, it might be easier for people like me who dont want to go through the complications of the EU. |
(Post 7112519)
haha, thats what alot of people dont understand with the VQs i love it when people sit there and say 350Zs are slow and go on and on but its the power comes on soo smooth.
how easy is the SMT-6 to use and install, this is the first time im hearing about it, ur AFR is dead on through the whole powerband, it might be easier for people like me who dont want to go through the complications of the EU. SMT-6 is limited in timing advance and it only works when the engine is not in closed loop. I only tune from 3500 rpm to redline and use the AFPR to tune fuel below that rpm range. |
That means I am making more than you right now :noes:
Nice numbers.
man that 00vi flows, wish I had the patience to get it working on my 3.5 but i'll just put one on my turbo 3.0 instead hehe. awesome numbers.
Ahhhhhh the good 'ole 3.0. :cool:
Great #'s! |
nice numbers hopefully im somewhere around there
Thats what I love about the 00vi/dek. It just begs for more revs:)
Nice numbers
man, if companies paid as much attention to the VQ30DE-k motor like they did the VQ35... beautiful numbers buddy, i just come in this thread to just look at the sheet just because lol
This engine never ceases to amaze me. Had a two day track event at New Jersey Motor Sports park in some pretty harsh conditions and the DEK held up nicely. The oil level didn't move at all and it felt good all thru the event. Now if I can get the rest of the damn car to hold up as well.
(Post 7120960)
cam it + extended redline would be win. your already sh1tting on 3/4 the 3.5's.....
(Post 7122495)
taurus SHO, what? lol
Wow, those are impressive numbers. I've always been curious about removing my swirl valves, but have never had a good enough reason to do it. Were you pleased with the results?
What is the chief reason for removing the swirl valves
© 2024 MH Sub I, LLC dba Internet Brands
