267.4hp/252ft lb Auto 5.5 Gen
1 Attachment(s)
http://forums.maxima.org/picture.php...ictureid=365927k Rev limit 3.5 Maf over 3 inch 6650 Rev Limit
http://forums.maxima.org/picture.php...ictureid=36591Peak Run http://forums.maxima.org/picture.php...ictureid=36590Untuned Vs. Initial UTEC Tune Changes since the 267hp/252ft lb dynos are Haltech Level Ten Trans Level Ten Torque Convertor Level Ten Valve Body 75MM TB 4 Inch Maf is the newest addition ;) |
BRO!!! Yo stuff RUNS HARD!!!! Nice job!!
NICE!
Top end gains look really good, but man that is a CRAPPY PIC. So from the last run (262) you done the elbow port, 09 TB, and 3" testpipe? that was 267 now. |
3.5 inch maf
09tb elbow 3inch test pipe mounts yeah peak carried to 267 and change. but from 5500 its picked up nicely up to about 14hp in higher revs. lost some on lowend but it flattened out the tq curve some. My ssim is opened up really well, and the new changes may have called for too much flow. may have them make another for the other elbow and change that on the dyno to see the difference if the porting helps, but im actually happy with how it sits for now. My main look was to get more on top as playing with the vmanage will dial in low and midrange. still on the lookout for a resonably priced used unit. The next "great big" thing will be the addition of a vmanage, a 75 shot, then retuning for olf and calling it a day. think ive peaked with this motor setup, take some time to enjoy it, and get the minor maintenance issues corrected that have been niggling at me. |
Nice numbers..:D
(Post 8399604)
Nice numbers..:D
Nice numbers! Those are my next mods too, minus the t/b. I just need to find time to put everything on. In your pictures the dyno is so small....is that showing your new dyno compared to your last dyno? Do you have cams?
Originally Posted by Cant_Get_Ryte
(Post 8400124)
thanks bro.
Originally Posted by cardana24
(Post 8400504)
Didnt realize that the pic that I linked wasnt expanded. Ill put the bigger one up tonight. it came up to about 15hp from 5500-6500rpm. Kept the same shape of the curve all the way up top. Peak I only picked up 3 or 4 additional horses. Although i did have some lowend losses its not noticeable at all even with the high stall. Going with an install of a v manage as soon as i can find one decently priced to see exactly how much more can be dialed in with that addition. as we know the ivt control will afford mid and lowrange adjustments which may make it worth it. Jime recommended it for a dd when i asked, so im on the hunt.
(Post 8400505)
No problem, especially since I'm AT also, giving me hope, got any vids on youtube....:D
wish u was on a dynojet tho!
DynoDynamics is 10-15 % lower then dynojet?????? Manny? edit: it depends on factors entered into the dyno too? drag, weight, stuff like that? |
Gratz Doug, this si awesome.
I need to get off my asz and hit the rollers soon very soon too.
Originally Posted by SurraTT
(Post 8401045)
DynoDynamics is 10-15 % lower then dynojet?????? Manny? edit: it depends on factors entered into the dyno too? drag, weight, stuff like that? But, either way, it was a solid gain for Doug. I do think, at this power level, it's fitting to get it on a DJ so we can compare ... ahh, dynos. Yeah, Dynos. Heck I'd even cover some of the costs because this would essentially show me the gains of the 09TB and other items add, as closely as humanly possible. Holy hell, I've been out of town for a while, I got some catching up to do on the forums ...... whew!!! :reading: :faint: :mrgone: |
Originally Posted by NmexMAX
(Post 8402020)
I need to get off my asz and hit the rollers soon very soon too. Heck I'd even cover some of the costs because this would essentially show me the gains of the 09TB and other items add, as closely as humanly possible. Holy hell, I've been out of town for a while, I got some catching up to do on the forums ...... whew!!! :reading: :faint: :mrgone: 09TB's are in like mad now. Everyone is doing them!
(Post 8401045)
DynoDynamics is 10-15 % lower then dynojet?????? Manny? edit: it depends on factors entered into the dyno too? drag, weight, stuff like that? Doug - There are no Dynojets around that way up there in MD?? |
These number are dynojet converted as were his last numbers.
^ oh ok good to know
@javon issue is the shp tuning runs a dd, so i get mine on a dd.
@manny lls, still searching for a reasonably priced v manage to dial the low end bk in "/ Thats the plan at least |
DOUG - anyway you can make that pic of the graph bigger? Tried downloading it and zooming in and it just turns to squares......
bring it in and scan it tommorrow. lol. YOU ACTUALLY SAT UP AND LOOKED AT IT IN PERSON CONYO lol.
(Post 8406066)
Originally Posted by ranmas2004
(Post 8406173)
Lil half azz tiny dyno strainin my eyeballs!!!
just want to make sure so the only thing different between the red and blue is tb or tb elbow and 3inch tp
The elbow, test pipe, throttle body, bigger maf. 3.5 interior diameter over 3
nice numbers! you should 6 spd swap it!
Originally Posted by FastnFuriousMax
(Post 8698865)
Originally Posted by datdude20
(Post 8701539)
i been tryna convince him...he has been talking about it if he can find a nice DD
I think I have my swap priced rather well... |
(Post 8701576)
You can swap it in a weekend no problem. If you have a friend you could probably get it done in one day if you both know what you are doing...you get a boost in HP to the wheels, better mpg, and a faster trap by doing the swap. Also the car is alot more fun to drive...
(Post 8701691)
Yea I kno...my last 5.5 was swapped
LOL im plenty happy with my setup. After buying the level ten trans, convertor, and valve body, no need now lol.
(Post 8741665)
(Post 8741711)
DAMN IT>>>:eek:
© 2024 MH Sub I, LLC dba Internet Brands
