Looking to buy a scan tool, recomendations?
I am looking to buy a scan tool, no I don't need it right now but who knows what the future holds, I have done some research and I am looking at the Actron 9180 simply because it is update-able. I am really looking for 3 things, Fairly easy to use, Update-able via internet (Free updates are better), and a nice tool, I am prepared to spend the right money for the right tool I don't want to cheap out as if its update-able it will last a long time. Please let me know what you guys are using.
Thanks,
Vik
Thanks,
Vik
After my last experience with Actron scanners I refuse to buy them again. Plus there is a whole host of software based scanners out there that will cost you about the same amount of money, work on whatever platform of mobile computer you have including iPhone and Android platforms and will give you much better data logging capabilities.
Oh yea and what pissed me off about them was the one I have was supposed to be upgradeable which meant purchasing an $80 cable and drivers and look for an update that never came. It was also supposed to work with ODB-1 and doesn't which is one of the main reasons I bought the little POS.
Oh and the Actron 9180 comes with a usb cable
Looking into it, $200 though. I can get the standalone that can connect to my other cars, this seems to be Nissan only? My question is, is this worth the extra money for just one car or should I save 50 bucks and go with one of those battery powered plugins?
I bought this Innova 3160 from Amazon.com:
http://www.amazon.com/Equus-3160-Pro...4451366&sr=8-1
$200
$200
http://www.accecity.com/obd2-elm327-...13a_p1008.html
Haven't tried anything else yet since my junk for the most part stays working and my scanner also decided to start working for now. Guess the last time I threw the fargin thing jostled something causing it to work again.
I have an Android phone (Evo) and use the Torque application, as well as a bluetooth obdII adapter from ebay($20-30). It works amazing, basically reads everything a $300 scanner can read including saving logs to excel sheets, reading codes, pending codes that arent showing yet, etc... I have used it on a 02 corolla, 99 gs300, 99 Lincoln continental, and have worked on all, didnt work on my maxima for some odd reason (I think my ecu is messed up, not 1st time it happens with a scanner).
Nsider, I havent used that exact one. My friend bought one off Ebay, and when he gets back from Iraq I can get more information.
I have used his for a quick scan, but I havent used it for anything else.
S
S
Now if I could get my hands on Nissan's PID list to get a little further into the ECU I'd really be happy.
Does anyone know which can Protocol/wires Nissan broadcasts the sensor messages across. I just bought a scangaugeII which is pretty nice for $159. I am trying to use it to request standard sensor data from the can bus, and tap the wires to log the data using a separate CAN logger. Its totally a project for an EE and I am an ME, so we are struggling a bit. Currently I am tapped into the 2284 bus, but despite my DBC file I am not getting any data in. Let me know if someone can help.
http://pinoutsguide.com/CarElectroni...s_pinout.shtml
If it's just for Nissan apps, I've been using the Blazt/Datascan software with the consult interface for 4+ years and works great. Logging, map trace, real time data display (12 simultaneously IIRC), code reset, self learn clearing, active tests (shutting off cylinders, changing IAVC, cooling temp values etc), even a 0-60 function. Was under $100 when I bought it I think...
I use the Torque adroid app with a bluetooth Elm327 OBDII device
$5 for app, $22 for the OBDII device (Be careful though, a LOT of fake/nonworking elm327's are floating around. Especially the cheaply priced ones.)
newlauch is the eBay seller I got mine from. Good experience from that seller
04-16-2020 05:15 AM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
