Should I dyno with my oem 17's or lighter 18's?
Old Jul 26, 2002 | 10:03 AM
emax02's Avatar
I'm heading to the dyno today and I can't make up my mind which wheels I should use. On one hand my 17's are smaller and they have less rotational force. on the other hand my 18 inch SSR's are 5 pounds lighter but have more rotational force. I'm sure either way it won't make a big difference but what do you think will perform better? BTW the 18's are on right now
Old Jul 26, 2002 | 10:13 AM
Kevin Wong's Avatar
Heh at least you have the luxury to switch
I have the 17X8 Integrals, but I also have the Brembo Gran Turismo Kit. Can't go back down to 16's. I think it's easier to just leave your SSR's on. I'm getting my Max dyno'd on Monday at XS and I plan to leave my SSR's on...then again the Brembo rotors take a good deal of rotational mass off as well as the wheel.
Old Jul 26, 2002 | 10:14 AM
costcowholesale's Avatar
*dyno with whatever wheels u had last time on the dyno then we can compare!
*fixed
Old Jul 26, 2002 | 10:16 AM
Blu's Avatar
Blu
the tits
use whichever wheels you dynoed first in to get the 215 whp so we can get the exact gains from your udp and y-pipe If you have time change wheels during the dyno to see if it makes a difference
Old Jul 26, 2002 | 10:17 AM
SR20DEN's Avatar
VQ Wizard
Use the same rims you used for the last dyno trip. That was the SSR's right?
Old Jul 26, 2002 | 10:27 AM
Lordrandall's Avatar
Ditto the previous 3 posts
Old Jul 26, 2002 | 11:21 AM
emax02's Avatar
Ok, I will put the my 17's on the front then
Old Jul 26, 2002 | 11:25 AM
Nismo87SE's Avatar
Re: Should I dyno with my oem 17's or lighter 18's?
Dyno with the same wheels or get some light 15's to dyno.
Old Jul 26, 2002 | 11:28 AM
SR20DEN's Avatar
VQ Wizard
I wouldn't bother with it then. Just dyno with the wheels you have on now. Your probably more intersted in the total hp than the # of gain. Thw wheel and UDP difference isn't going to be alot anyways.
Old Jul 26, 2002 | 11:58 AM
emax02's Avatar
I just put the 17's on so.. My last dyno was with 17's too.
Old Jul 26, 2002 | 12:47 PM
xHypex's Avatar
Icm= MR^2
I is the rotational inertia of the system, M is the mass, and R is the radius. Plug in your info and whichever has the lower I is the rim that you want. Also remember this is only taking into consideration rims and not tires, and assumes that the mass is distributed evenly across the radius.
-hype
Old Jul 26, 2002 | 12:53 PM
Newman's Avatar
Originally posted by xHypex
Icm= MR^2
-hype
what measurement should R be in? or does it not matter what unit it is so long as both equations use the same unit?
Old Jul 26, 2002 | 12:57 PM
Newman's Avatar
same question for mass. doesnt matter just as long as both are the same, right? (when comparing)
Old Jul 26, 2002 | 06:31 PM
Blu's Avatar
Blu
the tits
waiting for those dyno results ewok post em up. its 8:30 here now
Old Jul 26, 2002 | 07:28 PM
Clayton's Avatar
I personally would want a dyno that reflects the car I drive everyday, not the car I "prep" for dynos.
Old Jul 27, 2002 | 07:46 AM
MaximaRider's Avatar
OT: Clayton ur rims are HOT!
Old Jul 28, 2002 | 07:50 PM
Clayton's Avatar
Yeah - I love em...although they show off my not too pretty stock brakes.
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
