Can't chirp tire on the 1-2 shift anymore!
Hey,
I recently installed a short throw shifter and new tires, and now I can't chirp my tires on the 1-2 shift:mad: Would this be due to the new tires, which I think are a little heavier and have a lot more traction, or the fact that it's a little more difficult to shift fast with the new short throw shifter? What do you think? Thanks. |
Re: Can't chirp tire on the 1-2 shift anymore!
Originally posted by 2KxSEx Hey, I recently installed a short throw shifter and new tires, and now I can't chirp my tires on the 1-2 shift:mad: Would this be due to the new tires, which I think are a little heavier and have a lot more traction, or the fact that it's a little more difficult to shift fast with the new short throw shifter? What do you think? Thanks. I thought a STS was supposed to make you shift faster??? :gotme: Slipping clutch?? what kind of tires do you have?? what kind of tires did you have? |
It does, but sometimes the shifter gets stock a little on the way down when I try to shift fast now. This didn't happen with the stock. I have Dayton Daytona RZ Z rated 225/50/16 tires, pretty good for 109 a pop from a local tire dealer.
Now that I think about it, maybe it's a combination of the fact that the sts shifts a lot faster than stock, so there isn't enough time for the rpms to fall to cause a chirp, it's like one continuous motion. And the fact that the new tires are prolly heavier, they look heavier anyway. When I engage 2nd gear while 1-2 redline shift, the whole car jolts with a lot of force, like it's trying to chirp, but there's something stopping it from doing so. I'm assuming that it's not good for the car Peace. |
What were your previous tires?
My Z rated ones are nearly impossible to chirp compared to my ****ty stockers. |
Originally posted by 2KxSEx It does, but sometimes the shifter gets stock a little on the way down when I try to shift fast now. This didn't happen with the stock. I have Dayton Daytona RZ Z rated 225/50/16 tires, pretty good for 109 a pop from a local tire dealer. Now that I think about it, maybe it's a combination of the fact that the sts shifts a lot faster than stock, so there isn't enough time for the rpms to fall to cause a chirp, it's like one continuous motion. And the fact that the new tires are prolly heavier, they look heavier anyway. When I engage 2nd gear while 1-2 redline shift, the whole car jolts with a lot of force, like it's trying to chirp, but there's something stopping it from doing so. I'm assuming that it's not good for the car Peace. |
my new S-03s dont chirp. they spin but they just make a rubbing sound on the ground and give me a little bit of wheel hop. i could roast the tires going into 2nd with the stock tires but no so much as a squeek from the new ones.
isnt chirping tires bad anyways :gotme:
Originally posted by Jamsan isnt chirping tires bad anyways :gotme: If the RPM's are high and you shift fast if your rpm's fall before the clutch engages, sounds like a worn or HOT clutch. But if it puts you into your seat and the tires break traction, I think the clutch has done it's job. But, I do agree with you, I would rather have no chrip during my shifts. I want traction and no slipping. |
how high do you rev it to? :D
I only chirped the 1-2 shift 3 or 4 times now.. actually, only 1 was a 'chirp' the other times i got some pretty good wheel spin damn goodyears :mad: |
Redline baby!:D I used to have the stock toyo proxys and I didn't even have to bring it to redline on the 1-2 shift to get a huge chirp out of them. Now I only get a tiny chirp if I try really hard. Ohwell, atleast now I have much better traction.
Chirp on everybody! |
Originally posted by Jamsan isnt chirping tires bad anyways :gotme: |
chirping tires
it is also harder on the drive train.
i was forsaken to drive my mom's 96 auto TL over the weekend, and well, lets just say i gave that tranny hell :D
i shifting it manually pretty much all day, except on the highway...the friggin thing chirped 1st and 2nd all day long.....it was great....cept i raced my friend's teg, and he smoked me....which is usually an easy kill in my max |
less chirp = more traction= better accel
only if ur car is working like it always does. and isnt slowing down. :)
| All times are GMT -7. The time now is 04:02 PM. |
