For you VI 5sp owners modded 5sp vs same plus VI....what happens
With all the talk the VI and all the buzz we are all excited about owning one. I like many of you am looking forward to owning one, it is obvious you cannot dispute that the intake works.
When you look at the spread sheet it absolutely blows you away that it holds 40+ hp and torque well past 6K very impressive.....BUT.... the end result does not look as good as it does on paper 2more miles per hour quicker in the 1/4 or .2 faster in the 1/4. I am saying all this to ask what happens when two identical 5speeds line up with drivers with same skill when does the VI equipped start to walk away? I am going to guess at the top of third or is it not till the top of fourth? Or everytime the VI equipped intake opens at a pre deterimined RPM does it pull on the NON VI? Or a better example might be both cars are in 5th gear going 70 and then they both shift to 3rd
I assume this is where the VI shows it's strenght
I have run against a stock 5sp and thought I would immdiately pull him, I have the normal bolt ons and surprisingly I did not start to walk away until I shifted to third.............yes i know how to drive
It would probably show up better in a higher gear.
Say both a stock VQ 5sp and a VI Stock 5sp....both rolling in 3rd gear and say 20mph. Both go WOT. The VI car makes a tiny bit less on the low to mid rpm's, but so little less that it probably wouldn't make a difference. As the tach's of both cars sweep past 5K or so, the VI is suddenly going to walk away.
Mike S.
Mike S.
I've got just the answer you are looking for.
Myself vs. BriGuyMax:
Me= Y-pipe and Intake, and shorter diameter tires.
BriGuyMax= Intake, Ypipe, exhaust, UDP
From a stop I pull out a little because my car is lighter and I have shorter tires, probably on the order of 1/2-1 full car through first gear. 2nd gear I'm still pulling a little but not as dramatically, 3rd gear we are about even in acceleration and the distance between us holds constant. 4th gear he starts to SLOWWWWWLY pull back on me and pass me. 5th gear he's stretching his lead on me, probably 2 cars by 130mph. From a roll at say 70mph it's basically a dead heat until 100 and then Brian will start pulling slowly like I described above.
Me with MEVI vs BriGuyMax w/ Bolt ons
I have the same mods as above plus an MEVI, he has the same mods as above. From a stop or a roll it's all over for him. First gear I pull about 1/2 car, 2nd gear another car, 3rd gear 2 more cars, 4th gear I'm leaving him badly. By 130mph I'd probably have 6-10 cars on him.
Me with MEVI vs BriGuyMax with MEVI
All mods same as above, MEVI's for both of us. This is what we've done most recently, at both the track and a toll booth, and highway roll ons. We are basically dead even in every situation. No one's pulling anyone as long as we hit it at the exact same time.
Soon as Courtesy gets their head out of their **** I will find out what its like.
Just courious though. Before the MEVI's were added, what was giving Briguy the edge up top? His exhaust??
I have the same mods as above plus an MEVI, he has the same mods as and a toll booth, and highway roll ons. We are basically dead even in every situation. No one's pulling anyone as long as we hit it at the exact same time.
Da*n that is very impressive, great write up I am surprised that it made a difference so early.
Re: my main question
Originally posted by stevo
my main question it did your car feel any slower at all just driving around town? I noticed on most of the dynos there was a little bit of a loss in torque.
http://home.earthlink.net/~thunderlt...s/DCP_0014.JPG
Another thing I noticed. The intake isn't as loud, especially after 4000rpms (that's a good thing in my book).
Dave
Originally posted by Victim64
Wow. Being able to pull 6-10 cars to 130 on a modded 5spd is impressive for a NA mod.
Originally posted by BriGuyMax
Before the MEVI's, my car was probably making a little more HP than Neal's from the exhaust and UDP, so up top when weight difference was not as much of a factor, I would pull. Neal also had shorter diameter tires which help low end acceleration, but hurt top end.
Originally posted by mitch33x
what about the ACT clutch? and wouldnt the quaife help off the line?
Good write up Neal. At least you have someone to play with must be nice. Now if you pull on Briguy without him activating the VI, how many cars lenghts you think you ll put on him if you were SCed (Briguy nothing against you just a question)
ACT clutch and quaife don't help off the line to any noticable extent. The quaife is VERY noticeable accelerating through turns.
Jay25-do you mean me with MEVI and SC vs him with just bolt ons (no MEVI) or me with just SC? Either way I couldn't begin to tell you. I've ridden in only one SC'd max, dashingMax's I think hes running 8lbs or 10lbs and it was fast as hell, from a stop a bolt on Max might do OK for a second or 2, but after that it'd be all over. Even vs an MEVI car, he'd just leave it in the dust. His car hauls. I bet his car could trap 105mph So probably from a stop to 130, I'd guess he'd put 15 lengths on an MEVI car and a few hundred feet (like 25+ lengths) on a bolt on 4th gen.
Neal you got it right you been SCed as an example. Have you and Bobby and Briguy played around? Tell that clown he needs to go to the track . I am trapping 104MPH all the time whether it be at 13.8 or 14.6 my traps are always @ 103 and 104. I am awaiting the ME VI. I got the SAFC to tune that sucker at the lower RPMS. Ill post my Dyno numbers by Mid Feb of next year if there is no ice on the road.
NICE comparison! And you can test all the way to 130 mph?? Man, open highway must be plentiful in your neck of the woods.
DW
DW
BriGuyMax= Intake, Ypipe, exhaust, UDP . . .
Me with MEVI vs BriGuyMax w/ Bolt ons . . .
Me with MEVI vs BriGuyMax with MEVI . . .
Originally posted by JAY25
I was speaking for someone that got it. You may be correct about the Quaife, since I was told not to get it. I dont care much for turns but if thats the only use for it then I dont need to invest $1500 plus dollars on an expensive piece like that one.
IMO the quaife is a MUST for anyone putting down decent HP....it's MUCH MUCH stronger than the stock open diffy, and will be great for use with slicks. I busted my stock diffy...that's mainly why I have the quaife.
OMG...INTELLIGENCE!!!
Oh wait, I logged out of the Honduh forums. That's why!
Anyhow, here's some CarTest data.
So 0-60 there's almost no change. You lose a little in the low/mid-range, but what you lose you pickup at the top-end. CarTest gave 0.2s/2mph in the 1/4 mile in favor of the VI, but I think Dave B tested it out at about 0.3s/3mph, but this is still pretty close.
The biggest difference is on highway drags, as Nealoc and BriGuy were discussing. From looking at the 1/2 mile and full mile ET/speeds, the MEVI doesn't really push the car all the much faster (not much extra PEAK horsepower), but extending the power band allows you to hold the lower gears (higher power multipliers) for just a little bit longer than the OE manifold, and the MEVI just slowly walks away. 0.5s difference at 128 mph is probably somewhere around 6-10 cars, as Neal described.
Code:
Stock 95, 95+MEVI 0-60......: 6.5, 6.5 0-1/4 mile: 15.2@ 91, 15.0@ 93 0-1/2 mile: 23.9@111.5, 23.7@112.5 0-1.0 mile: 38.9@127.5, 38.4@128.5 Top Speed.: 137, 141
The ACT clutch would help if they have stock clutches which I believe none of them do. The ACT clutch will grip better and the Quaife will eliminate some wheel spin helpin you on take off.
Code:
Originally posted by brodaiga
hey man, once i get my car in order, we can have some fun playing, lol
doctorpullit
10-28-2019 10:58 PM
mkaresh
03-12-2018 06:48 PM
Forge277
06-13-2016 09:26 PM
