RSB install - ramps or jack stands??
I'll be installing my Addco this Sat. I've read the how-to's. Some say use ramps, others use jack stands. Is one better than the other?
Kinda nervous about backing up the ramps with my MT, but I'm thinking it would be better to install the RSB with the weight of the car on the tires/axle...or doesn't this matter? |
use jack stands... taking your rear wheels off will give you more space to work with.
^^^^ he's right but ramps are much safer...
I'd have to agree with UMD_MaxSE. I just did my RSB last weekend and after my wheels were off It was easy. You have some much more room to work with.
I did mine without any of that. Granted it was probably harder that way but i was young.
I too was a little iffy about backing up onto the ramps with the MT because I hadn't been driving stick that long when I got the RSB. But after a few tries and a little clutch abuse I got it up there okay. The install was very easy. I remember hearing somewhere that the suspension should be under load when installing one of the bars, but I can't remember if its the RSB or the FSTB, or both.
Originally posted by JeffesonM I too was a little iffy about backing up onto the ramps with the MT because I hadn't been driving stick that long when I got the RSB. But after a few tries and a little clutch abuse I got it up there okay. The install was very easy. I remember hearing somewhere that the suspension should be under load when installing one of the bars, but I can't remember if its the RSB or the FSTB, or both. |
I just did this install last weekend. I used Rhino ramps from Wal-Mart ($30). I did not have any problems using the ramps. Granted with the wheels off you have a much easier time getting to the ABS stuff. Either way is fine. Do whatever makes you comfortable.
Can I use a lift to do this?
O of course your site has info.:D
go with jackstands...
I jacked the rear of my car up, then put blocks under the weels so the rear suspension could be 'under load'. No worries about backing up on ramps.
Pics on my homepage. <-- |
Jack Stands... You need to undo the brake line from the frame to get the clamp adjusted right (at least on a progress bar). You'll need to adjust and re-tourque after putting it bak on the ground anyway.
A LOT more room to maneuver on stands rather than a ramp. (Don't forget the E-brake) |
Only when doing the RSB should you use ramps, the rear suspension needs to be under full load in order to get the RSB properly calibrated to be efficient....
Originally posted by Ramius83 Only when doing the RSB should you use ramps, the rear suspension needs to be under full load in order to get the RSB properly calibrated to be efficient.... |
About 50/50
on using ramps or jack stands. Thanks for all the input. I think I'll go with the ramps to keep the suspension under load. Probably take more time, but that's ok.
Thanks for all the links to pics and how-to's!! |
Originally posted by Shaydz You mean the Rear TOWER Support Bar (mounts inn the trunk between the Strut Towers), right? Not the bar that mounts underneath the car. |
Originally posted by 96BLUMAX O of course your site has info.:D |
© 2024 MH Sub I, LLC dba Internet Brands
