What aftermarket mufflers do you have on your Max's and describe the sound ?
??? I tryin to get an idea for my Mazda 929 3L V6
I have a Pace Setter muffler combined w/my Stillen Y-pipe it is low and deep.....just rigth for me....:p
Greddy SP catback. Very deep and argressive sound at a cruise and at WOT.
Ant |
most of them go burrrrrrrrRRRRRRRRR
some go bwahhhhhhhhhhh |
Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Infiniti G ??? I tryin to get an idea for my Mazda 929 3L V6 |
having owned a few mazdas (a 323, 626, and a 929) DON"T DO IT the mazda 3l engine sounds like crap through loud exhaust, like a gokart with a hole in the muffler
Re: Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Craig Mack Just cause your '89 Mazda has a 3.0L V6, doesn't mean it's going to sound the same as the Maxima. How many cams? How many valves? What's the firing order? By the way, I really loved my 88 929, except for the timing belt. Rear wheel drive made up for that, though. But a lot heavier and only auto transmission = slow. |
Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Stephen Max More stroke makes for a deeper sound. A Mazda 929 has 3.54" bore and a 3.05" stroke (just happen to have my old 929 FSM in my office). Anybody know what the VQ bore and stroke is? |
Apexi N1 with no resonator, and custom B pipe.
http://www.imagestation.com/album/?id=4290634291 |
Link dont work.
Re: Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Craig Mack I'd like to know what the Maxima's bore/stroke is too. I am pretty sure the VQ's bore/stroke is different then the VE/VG's. |
Re: Re: Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Stephen Max I just remembered I had my Maxima FSM in my car. Turns out the VQ bore and stroke is 3.66 x 2.886 Pretty oversquare. That would explain the fairly high rev capability. |
Re: Re: Re: Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the sound ?
Originally posted by Craig Mack So it's going to have a slightly deeper sound to it then the Mazda? |
Originally posted by SonicDust187 Link dont work. |
Re: Re: Re: Re: Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the sou
Originally posted by Stephen Max No, the 929 has the longer stroke, it's going to have the deeper sound. But not by much since we're only talking about a 6% difference. |
Originally posted by 1FSTMAX fixed |
Re: Re: Re: Re: Re: Re: Re: Re: What aftermarket mufflers do you have on your Max's and describe the
Originally posted by Craig Mack Yeah, it's not even enough to increase the liters by even .1, so you probubly couldn't tell the difference in deepness (aka the setup you have will be the judge). Is that correct? |
My engine is SOHC 18 valve:( , alot of you guys seem to be running Apexi N1's ??? you think tht would sound alright on my car ?? which N1 ??? 115mm tip or the 90mm tip ???
Originally posted by Infiniti G My engine is SOHC 18 valve:( , alot of you guys seem to be running Apexi N1's ??? you think tht would sound alright on my car ?? which N1 ??? 115mm tip or the 90mm tip ??? |
Actually my exhaust sound very mellow, and it's not that loud. Under full acceleration my intake drowns out my exhaust. The only reason it sounds that way on the video's, because the camera is really close to the muffler. I chose the N1 becuase I always liked the canister look and the sound. If you are going to get a Apexi N1 make sure get a real one, not a fake ebay one.
which N1 do you have ??? the bigger one (115mm) or the smaller one(90mm)
Originally posted by Infiniti G which N1 do you have ??? the bigger one (115mm) or the smaller one(90mm) |
I dont have a Y pipe, the 2 manifolds join before the down pipe and then it flows into the cat then down into a smaller muffler (resonator), over the axle an into a RV sized muffler. If I were to change the set up I think I just want to bolt on the rear section and leave the resonator. What would you do ?? Should I change the whole set up from the cat back with 2.5" piping then get rid of the resonator and have the pipe go under the rear axle in to a N1 ?? I want power gains in the low and mid, not the top cause I dont plan on ripping around and staying around 6000 rpm. I want something like this but not loud, possible ????
what about the <$300 mufflers
Would putting 100-150 down on a generic muffler be worth it? I don't wanna have that buzzing bee sound, but I hate how quiet my exhaust is and want a deeper sound w/o the GReddy or HKS price tag.
-95SE |
Re: what about the <$300 mufflers
Originally posted by skuccio's max Would putting 100-150 down on a generic muffler be worth it? I don't wanna have that buzzing bee sound, but I hate how quiet my exhaust is and want a deeper sound w/o the GReddy or HKS price tag. -95SE Do you want a slim hidden style muffler that will give you a unique raw, hollower rumble with more bark? Flowmasters. Get a 40 series muffler on ebay for ~$55. I guess everyone here likes to sport bummmmming fart cans. :gotme: |
Originally posted by metallic97gxe I have a Pace Setter muffler combined w/my Stillen Y-pipe it is low and deep.....just rigth for me....:p |
Originally posted by fierostetz most of them go burrrrrrrrRRRRRRRRR some go bwahhhhhhhhhhh |
I jus recently removed the large RV sized muffler and Im only running the smaller muffler (resonator) an WOW, it sounds deep and freed up proly 10-12 HP (my car is alot faster) all I plan on doing now is putting a pipe in place of the muffler and finishing of with a resonated tip to quiet some of the resonance
more like 1 or 2 hp since mufflers have no effect on a car's power rating...
not when you have 2 set of mufflers and how would 1 or 2 HP make my car way faster ?
Greddy SP full catback with Cattman SS Ypipe and it sounds PrrrrrrrrrFect... :-)
Apexi World Sport catback with Stillen Y..sounds deep..sounds just right;)
I just got a $50 muffler off ebay and a 2.25" non-resonated b-pipe and it deep. More of a vhrooooooo. hard to explain in words, but its nothing like a civic.
Anyone know the diameter of the Budget Bpipe? I thought it was 2.5", but im not exactly sure.
Originally posted by Infiniti G not when you have 2 set of mufflers and how would 1 or 2 HP make my car way faster ? mufflers don't add mad HP, 1-3 at most |
my car has 2 stock mufflers, I deleted the biggest one and Im currently gonna put a tailpipe in its place. When that is done I would like to replace the 1 smaller stock one with a more free flowing unit but dont know what to use, Im concerened with back pressure and not having enough.
the Lexus LS400 has a somewhat similar set up and with removing 2 of the 4 stock mufflers it gained about 12 HP to the wheels on a dyno, i dont see why doing the same thing on my car would free up at least 6-8 HP it sure feels like it |
| All times are GMT -7. The time now is 11:38 AM. |
