Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   General Maxima Discussion (https://maxima.org/forums/general-maxima-discussion-1/)
-   -   has anybody's heated seat switch light burned out? (https://maxima.org/forums/general-maxima-discussion/159251-has-anybodys-heated-seat-switch-light-burned-out.html)
Frank Fontaine May 23, 2003 04:59 PM
On my driver's side, the orange lamp does not turn on. The passenger side does. But I am almost positive the seat is still heating up. After a while it's hard to tell because I think the thermostat turns off the seat heater.
I don't think there's any correlation between the orange lamp and whether the heater is on or off--it turns orange in 2 of the 3 switch positions. Anybody's burn out? It doesn't seem logical to replace the switch, seems like the whole center console has to come out. On my Volvo the switch slid out for replacement or access.
Black95Se May 23, 2003 07:07 PM
Yeah mine is burnt out as well. I opened the switch and there is a small led inside but I dont know where to get that size. Mabye someone can shed some light on this subject?
Ian
robocop199 May 23, 2003 08:57 PM
My driver side switch light burnt out too, but I'm pretty sure the seat would still heat up. You can use a small screwdriver and pop the switch out, they're expensive to replace.
96BLUMAX May 23, 2003 09:28 PM
Mine did when i did my 5speed conversion. I put it back together and bam the light wasnt on on the passenger side. Dont know how it happened.
mAdD MAX May 23, 2003 10:36 PM
Re: has anybody's heated seat switch light burned out?
Happened on our car a few months after we bought it. Got it fixed under warranty..and its been fine every since :)
btw, the seat still heated up even though the light wasn't on.
emax02 May 26, 2003 08:46 PM
My last car (98 I30) had the same problem, the heated seat switch burned out. I was told the bulb was a real PITA to replace so typicaly the switch just get's replaced. I think the switch is cheap.
Anachronism May 27, 2003 04:34 AM
The heated seat switches just pop into place. If you need to get to them from underneath you can just pull the cupholders out (97-99). If I remember right they have little plastic tabs that can be squeezed in to make them easier to remove.
If anyone does replace there heated seat switch (or finds a good price on them) I want the old one - WTB - Heated Seat Switch, Drivers side - Broken OK.
http://images.cardomain.com/member_i...73_34_full.jpg
